    • Log Masuk
    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    Scheduled Pinned Kunci Moved Plugins
    447 Kiriman 110 Posters 473.9k Lihat 110 Watching
    Memuatkan lagi kiriman
    • Lama ke Baru
    • Baru ke Lama
    Balas
    Log masuk untuk balas
    Topik ini telah dipadam. Hanya pengguna dengan kuasa pengurusan boleh melihatnya.
    • H Luar talian
      Headmade
      Hi, iI installed the latest version of the plugin and it does not work on mac os ((
      1 Reply Last reply Balas Petikan 0
      • samuel_tS Luar talian
        samuel_t
        @joshtays said:
        Maybe this has been asked, I tried to search it just in case, so apologies if it has been answered already... Is there any plan to support PDF in the future? Lack of PDF import to Windows Sketchup boggles my mind.
        There's no plan to support PDF in future. ๐Ÿ˜•
          samuel_t
          @kostiaarh said:
          Hello. Importer Error. What does that mean
          https://sketchucation.com/forums/download/file.php?id=158465
          Problem comes from model encoding. I've manually fixed "222.obj" and "222.obj.mtl" with a text editor.
          I've attached fixed model:
          222-fixed-model.zip
            samuel_t
            https://sketchucation.com/forums/download/file.php?id=158468&t=1
            Hi. What version of macOS are you running?
            • E Luar talian
              Einstein
              Would it be possible to implement support for TGA format of textures? You can often download models textured with TGA files.
                samuel_t
                Yes. It's possible. ๐Ÿ˜‰
                • D Luar talian
                  db11
                  Thanks for the great work on this extension Samuel. It's so useful, and I appreciate the rapid iteration / evolution to address user feedback.
                  Fantastic job!
                    samuel_t
                    1.1.5 version adds TGA and TIFF support for textures.
                    Download latest Universal Importer plugin from SketchUcation PluginStore.
                    • PixeroP Luar talian
                      Pixero
                      Thanks you.
                      I agree with the previous poster that PDF import would be awesome.
                      • O Luar talian
                        olaydigitaldesign
                        **This is a huge game changer for game developers like me. It is almost up to par with the Skimp plugin's importer which comes with a pretty heavy price tag. The reason why this plugin is so valuable is that I can import models into Sketchup while preserving the UV map, and then export them back into the game engine (Unity in my case).
                        The only thing it's missing is the ability to preserve the scale and position of imported models, which is the only thing Skimp has on you at this point.
                        Thanks a ton!** ๐Ÿ‘
                        • E Luar talian
                          Einstein
                          @samuel_t said:
                          @einstein said:
                          3. When I import a model with multiple textures, I can only select one texture file and that texture is applied.
                          Sometimes I can but another time I cannot have all textures included. Some models may be badly textured but I'm almost sure that I tried importing the same chair as TutorialsUp did with success, while I didn't get both textures (only one).
                          Einstein, your issue has been fixed with 1.1.3 version of plugin. ๐Ÿ˜‰
                          [attachment=1:2pw66q0f]<!-- ia1 -->Rudolf Chair.jpg<!-- ia1 -->[/attachment:2pw66q0f]
                          Hi!
                          Can you tell me how you imported this chair with both textures? I downloaded the latest version of your plugin and tried to import OBJ model. It asked me a few times for textures, I indicated one map (green leather), then the other (wood) but still it'll only be mapped with one of them.
                          What's more, I cannot remesh any model. Every time it splashes this error:
                            samuel_t
                            [attachment=1:1a6tfze3]<!-- ia1 -->Rudolf Chair.jpg<!-- ia1 -->[/attachment:1a6tfze3]
                            Hi!
                            Hi!
                            I specify a leather texture, nothing for plastic (because it's a color) and a wood texture then it's OK.
                            https://sketchucation.com/forums/download/file.php?id=158502&t=1
                            Try to follow these steps:
                            1. Download opengl32.dll (Win64) from this direct link.
                            2. Move downloaded opengl32.dll to this folder: C:\Users\DELL\AppData\Roaming\SketchUp\SketchUp 2018\SketchUp\Plugins\universal_importer\MeshLab\Win
                            3. Reduce polygons with Universal Importer plugin.
                            • E Luar talian
                              Einstein
                              @samuel_t said:
                              [attachment=1:213cpcm1]<!-- ia1 -->Rudolf Chair.jpg<!-- ia1 -->[/attachment:213cpcm1]
                              Hi!
                              Hi!
                              I pasted the library as you advised, relaunched SketchUp (maybe I should restart my PC) but still the same error pops up as I press the violet swan ๐Ÿ˜ž
                              How do you specify textures? If I pick them one by one during import, only one texture is put onto whole chair. Surely, I can manually repaint a part of it but it looks like no UV map is assigned. If I pick the other texture from "In Model" material palette, say leather, and paint the chair top, the texture has wrong scale and orientation.
                                samuel_t
                                Do you use SketchUp through a remote desktop? ๐Ÿ˜ฎ
                                I specify textures during import process (dialog box).
                                • OxerO Luar talian
                                  Oxer
                                  macos 10.13.6 & SU2017
                                  The v1.1.5 gives an error when I try to import an obj format model, with previous version v1.1.4 the model was imported right.
                                    samuel_t
                                    https://sketchucation.com/forums/download/file.php?id=158504
                                    ๐Ÿ˜ฎ Could you please upload your model here or to a file hoster?
                                      samuel_t
                                      About remesher, you can try to reinstall your graphics card driver. Let me know if problem persists.
                                      Also, be sure to import FBX version of "Rudolf Chair" model since OBJ version is badly textured. ๐Ÿ˜‰
                                      • OxerO Luar talian
                                        Oxer
                                        Excuse me, the problem was that the obj.mtl file was missing, I deleted it accidentally, the Plugin works fine. ๐Ÿ˜ณ
                                        • E Luar talian
                                          Einstein
                                          OK, I managed to import FBX model properly textured ๐Ÿ˜„ Thank you for your help!
                                          You mean I should totally reinstall NVIDIA drivers? (I'm actually afraid to do it because NVIDIA does problems with driver installation. Plus I'm an amateur and don't want to mess up with my computer.) Or should I just reinstall one of MS Visual C++ Redistributables or some other package?
                                            samuel_t
                                            ๐Ÿ˜‰ ๐Ÿ‘
                                            Yes, you should totally reinstall NVIDIA drivers.
                                            • 22
                                            • 23
                                            • 8 / 23
