    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    453 Posts 112 Posters 629.0k Views 113 Watching
    • samuel_tS
      samuel_t
      @joshtays said:
      Maybe this has been asked, I tried to search it just in case, so apologies if it has been answered already... Is there any plan to support PDF in the future? Lack of PDF import to Windows Sketchup boggles my mind.
      There's no plan to support PDF in future. ๐Ÿ˜•
      • samuel_tS
        samuel_t
        @kostiaarh said:
        Hello. Importer Error. What does that mean
        https://sketchucation.com/forums/download/file.php?id=158465
        Problem comes from model encoding. I've manually fixed "222.obj" and "222.obj.mtl" with a text editor.
        I've attached fixed model:
        222-fixed-model.zip
        • samuel_tS
          samuel_t
          @headmade said:
          Hi, iI installed the latest version of the plugin and it does not work on mac os ((
          https://sketchucation.com/forums/download/file.php?id=158468&t=1
          Hi. What version of macOS are you running?
          • E
            Einstein
            Would it be possible to implement support for TGA format of textures? You can often download models textured with TGA files.
            • samuel_tS
              samuel_t
              Yes. It's possible. ๐Ÿ˜‰
                db11
                Thanks for the great work on this extension Samuel. It's so useful, and I appreciate the rapid iteration / evolution to address user feedback.
                Fantastic job!
                • samuel_tS
                  samuel_t
                  1.1.5 version adds TGA and TIFF support for textures.
                  Download latest Universal Importer plugin from SketchUcation PluginStore.
                  • PixeroP
                    Pixero
                    Thanks you.
                    I agree with the previous poster that PDF import would be awesome.
                    • O
                      olaydigitaldesign
                      **This is a huge game changer for game developers like me. It is almost up to par with the Skimp plugin's importer which comes with a pretty heavy price tag. The reason why this plugin is so valuable is that I can import models into Sketchup while preserving the UV map, and then export them back into the game engine (Unity in my case).
                      The only thing it's missing is the ability to preserve the scale and position of imported models, which is the only thing Skimp has on you at this point.
                      Thanks a ton!** ๐Ÿ‘
                      • E
                        Einstein
                        @samuel_t said:
                        @einstein said:
                        1. When I import a model with multiple textures, I can only select one texture file and that texture is applied.
                          Sometimes I can but another time I cannot have all textures included. Some models may be badly textured but I'm almost sure that I tried importing the same chair as TutorialsUp did with success, while I didn't get both textures (only one).
                        Einstein, your issue has been fixed with 1.1.3 version of plugin. ๐Ÿ˜‰
                        [attachment=1:2pw66q0f]<!-- ia1 -->Rudolf Chair.jpg<!-- ia1 -->[/attachment:2pw66q0f]
                        Hi!
                        Can you tell me how you imported this chair with both textures? I downloaded the latest version of your plugin and tried to import OBJ model. It asked me a few times for textures, I indicated one map (green leather), then the other (wood) but still it'll only be mapped with one of them.
                        What's more, I cannot remesh any model. Every time it splashes this error:
                        • samuel_tS
                          samuel_t
                          [attachment=1:1a6tfze3]<!-- ia1 -->Rudolf Chair.jpg<!-- ia1 -->[/attachment:1a6tfze3]
                          Hi!
                          Hi!
                          I specify a leather texture, nothing for plastic (because it's a color) and a wood texture then it's OK.
                          https://sketchucation.com/forums/download/file.php?id=158502&t=1
                          Try to follow these steps:
                          1. Download opengl32.dll (Win64) from this direct link.
                          2. Move downloaded opengl32.dll to this folder: C:\Users\DELL\AppData\Roaming\SketchUp\SketchUp 2018\SketchUp\Plugins\universal_importer\MeshLab\Win
                          3. Reduce polygons with Universal Importer plugin.
                          • E
                            Einstein
                            @samuel_t said:
                            [attachment=1:213cpcm1]<!-- ia1 -->Rudolf Chair.jpg<!-- ia1 -->[/attachment:213cpcm1]
                            Hi!
                            Hi!
                            I pasted the library as you advised, relaunched SketchUp (maybe I should restart my PC) but still the same error pops up as I press the violet swan ๐Ÿ˜ž
                            How do you specify textures? If I pick them one by one during import, only one texture is put onto whole chair. Surely, I can manually repaint a part of it but it looks like no UV map is assigned. If I pick the other texture from "In Model" material palette, say leather, and paint the chair top, the texture has wrong scale and orientation.
                            • samuel_tS
                              samuel_t
                              Do you use SketchUp through a remote desktop? ๐Ÿ˜ฎ
                              I specify textures during import process (dialog box).
                              • OxerO
                                Oxer
                                macos 10.13.6 & SU2017
                                The v1.1.5 gives an error when I try to import an obj format model, with previous version v1.1.4 the model was imported right.
                                • samuel_tS
                                  samuel_t
                                  https://sketchucation.com/forums/download/file.php?id=158504
                                  ๐Ÿ˜ฎ Could you please upload your model here or to a file hoster?
                                  • samuel_tS
                                    samuel_t
                                    About remesher, you can try to reinstall your graphics card driver. Let me know if problem persists.
                                    Also, be sure to import FBX version of "Rudolf Chair" model since OBJ version is badly textured. ๐Ÿ˜‰
                                    • OxerO
                                      Oxer
                                      Excuse me, the problem was that the obj.mtl file was missing, I deleted it accidentally, the Plugin works fine. ๐Ÿ˜ณ
                                      • E
                                        Einstein
                                        OK, I managed to import FBX model properly textured ๐Ÿ˜„ Thank you for your help!
                                        You mean I should totally reinstall NVIDIA drivers? (I'm actually afraid to do it because NVIDIA does problems with driver installation. Plus I'm an amateur and don't want to mess up with my computer.) Or should I just reinstall one of MS Visual C++ Redistributables or some other package?
                                        • samuel_tS
                                          samuel_t
                                          ๐Ÿ˜‰ ๐Ÿ‘
                                          Yes, you should totally reinstall NVIDIA drivers.
                                          • panixiaP
                                            panixia
                                            Hi there, thank you for this wonderful plugins.
                                            I tryed it a bit and looks pretty robust and useful.
                                            Do you think could be possible to have a feature to preserve quads in obj and fbx import as per thomthom convention of pseudo-quads in sketchup (mark the diagonal with "soft" "smooth" "don't cast shadows")?
                                            That would be perfect!
                                            • 22
                                            • 23
                                            • 8 / 23
