    [Plugin] Import ALL from Folder
    77 Posts 20 Posters 78.7k Views 20 Watching
      If you want to import the file types in alphanumeric order, then sort the list as follows.
      Edit the file [../Plugins/import_from_folder.rb] using a plain-text editor like Notepad++ [or TextWrangler on MAC].
      At line #124
      list.each_with_index{|f, ix|...
      change it to read
      list.****sort.****each_with_index{|f, ix|...
      then save and close.
      Now restart SketchUp...
      • H Offline
        harnstein
        Thanks a lot for your super quick support!
        I'll try it when I get back to the office.
        Another TIG tool that comes right on time.. πŸ˜‰
        still sketchin'
          Sugareth
          Hi all, I have posted a companion plugin for Blender, which enables you to bulk export Collada files from Blender (which is very good at importing STL). Hope it helps someone.
          https://github.com/johnnyshield/blender
            superanus
            amazing tool - thanks
            I have 50+ geolocated skp files
            is it possible to place them according its own coordinates instead all in 0,0,0
            would donate this feature- thank you in advance!
              Unfortunately SKP imports default to 0,0,0 - unless it's done manually - when you can choose a location.
              However, if a SKP is geo-located, then importing it [e.g. manually] can force it to its geo-located point ??
              I can't see how we need to automate that...
              • H Offline
                harumscarum
                just recently it was possible to make this with the KMZ files
                as soon as geo-located model or Geo-Location itself is in SketchUp scene - on the import KMZ files placing each in just exact location
                  Sorry, but your post is unclear.
                  Is it a question or a statement of fact ??
                  Please explain...
                  • H Offline
                    harumscarum
                    just checked again - it also works with the SKP files (with geo-located ones)
                    1. fist we need to add as many location tiles as we need - File - Geo-Location - Add Location
                    2. after that all geo-located SKP files automatically importing on its location - no need to move it
                    here is a quick test - 3 random buildings in the Austin, TX downtown
                      mojikenso
                      thankjk
                      • Y Offline
                        youngjv
                        i have a problem on saving the files separately. when i choose to save as a local location the file name will be change as the extension file, just like the image below.
                        i usually use this plug in for furniture 3D DWG to SKP format.
                        i think the problem is when i import 3d model to skp it is already component.
                          mtraherne
                          Hopefully this helps someone.
                          I have been using this module for years, and have recently been getting really frustrated with the module crashing after apparently importing all the files.
                          Today was the last straw, after manually importing over 120 components, Sketchup crashed. Then the same again when I tried a second time.
                          This is it. This module NEEDS to be fixed - so I debugged it.
                          The line that is causing my system to crash is this:
                          [183] model.active_view.refresh
                          Comment this line out (#) and then the module works fine.
                          Hopefully this helps some one out there, or if a mod could update the ruby script (no update since 2015).
                            I've updated this olde script to v1.7 [still not 'signed']
                            https://sketchucation.com/pluginstore?pln=import_from_folder
                            Hopefully this avoids the issues you just reported...
                              bluewater2222
                              Mac OSX.... .jpeg extension does not work. changed to .jpg and all imported fine.
                                What version of SketchUp are you using? Your profile says 2020 Free/Make but there is no 2020 Free/Make version. SketchUp 2020 does include support for the .jpeg extension.
                                  However, please note that this plugin has never supported .JPEG files - but it does support .JPG...
                                  All of the file extensions it does support use the 'standard' .123 naming convention.
                                  This comes about because earlier versions of Windows required an extension of 3 or fewer characters - although now things are more relaxed - so PC users normally expect/use .JPG - which is the shortened Windows form of .JPEG... They are the same type of file with different suffixes.
                                  You can do a simple edit on the code in plugin's .RB file [which it puts in your Plugins folder], to include any additional extension type [provided that it is acceptable to SketchUp when importing].
                                  The .RB file's code has not been signed so you won't break anything when you edit it, provided that you use a plain text-editor on the file [like TextWrangler]...
                                  • 4 / 4
