    [Plugin] Import ALL from Folder
    77 Posts 20 Posters 79.9k Views 20 Watching
      Sugareth
      Hi all, I have posted a companion plugin for Blender, which enables you to bulk export Collada files from Blender (which is very good at importing STL). Hope it helps someone.
      https://github.com/johnnyshield/blender
        superanus
        amazing tool - thanks
        I have 50+ geolocated skp files
        is it possible to place them according its own coordinates instead all in 0,0,0
        would donate this feature- thank you in advance!
          Unfortunately SKP imports default to 0,0,0 - unless it's done manually - when you can choose a location.
          However, if a SKP is geo-located, then importing it [e.g. manually] can force it to its geo-located point ??
          I can't see how we need to automate that...
          • H
            harumscarum
            just recently it was possible to make this with the KMZ files
            as soon as geo-located model or Geo-Location itself is in SketchUp scene - on the import KMZ files placing each in just exact location
              Sorry, but your post is unclear.
              Is it a question or a statement of fact ??
              Please explain...
              • H
                harumscarum
                just checked again - it also works with the SKP files (with geo-located ones)
                1. fist we need to add as many location tiles as we need - File - Geo-Location - Add Location
                2. after that all geo-located SKP files automatically importing on its location - no need to move it
                here is a quick test - 3 random buildings in the Austin, TX downtown
                  mojikenso
                  thankjk
                  • Y
                    youngjv
                    i have a problem on saving the files separately. when i choose to save as a local location the file name will be change as the extension file, just like the image below.
                    i usually use this plug in for furniture 3D DWG to SKP format.
                    i think the problem is when i import 3d model to skp it is already component.
                      mtraherne
                      Hopefully this helps someone.
                      I have been using this module for years, and have recently been getting really frustrated with the module crashing after apparently importing all the files.
                      Today was the last straw, after manually importing over 120 components, Sketchup crashed. Then the same again when I tried a second time.
                      This is it. This module NEEDS to be fixed - so I debugged it.
                      The line that is causing my system to crash is this:
                      [183] model.active_view.refresh
                      Comment this line out (#) and then the module works fine.
                      Hopefully this helps some one out there, or if a mod could update the ruby script (no update since 2015).
                        I've updated this olde script to v1.7 [still not 'signed']
                        https://sketchucation.com/pluginstore?pln=import_from_folder
                        Hopefully this avoids the issues you just reported...
                        • B
                          bluewater2222
                          Mac OSX.... .jpeg extension does not work. changed to .jpg and all imported fine.
                            What version of SketchUp are you using? Your profile says 2020 Free/Make but there is no 2020 Free/Make version. SketchUp 2020 does include support for the .jpeg extension.
                              However, please note that this plugin has never supported .JPEG files - but it does support .JPG...
                              All of the file extensions it does support use the 'standard' .123 naming convention.
                              This comes about because earlier versions of Windows required an extension of 3 or fewer characters - although now things are more relaxed - so PC users normally expect/use .JPG - which is the shortened Windows form of .JPEG... They are the same type of file with different suffixes.
                              You can do a simple edit on the code in plugin's .RB file [which it puts in your Plugins folder], to include any additional extension type [provided that it is acceptable to SketchUp when importing].
                              The .RB file's code has not been signed so you won't break anything when you edit it, provided that you use a plain text-editor on the file [like TextWrangler]...
                              • 4 / 4
