    [Plugin] Import ALL from Folder
    77 Posts 20 Posters 79.9k Views 20 Watching
      You on Win8.1?
        driven
        @tig said:
        So this begs the question, "why does it work OK for me ?"
        :roll:
        have you run it on your mac?
          Win7 64bit, v2015 64bit... also works in v8 32bit etc...
            I won't get near laptop until 9pm.
            But I will test then.
              No rush... I'm asleep right now πŸ˜‰
                • Y
                  YoungOSG
                  @tig said:
                  @Young
                  You code is overly complicated.
                  It also has some odd working practices... πŸ˜•
                  I am sure I have answered this same query elsewhere...
                  See the @yuyuwhy posts...
                  Is it you, but with a different user-name ??
                  http://sketchucation.com/forums/viewtopic.php?p=554042#p554042
                  This thread explains how to setup an empty model SKP - the order of purging IS important - yours is wrong !
                  Do that BEFORE importing anything.
                  It also suggests a sensible approach to the subsequent import, purge and export of each DAE in turn.
                  If you enclose those actions within a ' model.start_operation(...)' block, BUT afterward each you ' model.abort_operation' it [NOT the usual ' model.commit_operation' it] then the imported data is simply forgotten, but the export is safe because the DAE file is now outside of the SKP's control... So there is no need to purge between each import/export at all.
                  Recast your code thus...
                  Make the host SKP empty.
                  Process the list of DAE files in turn.
                  Use a model.start_operation(...) block around each iterate step.
                  Remember to use the model.abort_operation to undo the import etc, but leave the export intact.
                  You should end up with an empty SKP and all of the DAE files processed.
                  Incidentally, your code only works in v2015 as the UI folder selector is new in that version's API.
                  Thanks!! I tried and it works!
                  And I want to import *.dae file with 2000 jpg.However Sketchup stop at 10%. It do not warn me anything.
                  could you help me ?
                    Here's v1.6 http://sketchucation.com/pluginstore?pln=import_from_folder It is overhauled to ensure that SKP file imports do not BugSplat - which was an unpredictable issue with multiple SKP files, especially those including un-purged dross.
                    Rather than use 'import' for SKP files, it now uses 'load' on them, which adds their definitions to the model and depending on the user's choice, it either leaves them as unused Component-Browser definitions, or it also places an instance of each of them at [0,0,0]...
                      McSquizzy
                      This tool is exactly what I am looking for but having problems with it. I am having some issues with collada (.dae) files. The tool seems to operate properly until it completes. Once it has stepped through all of the collada files, it says it has completed but does not render any of the data. I am left with an empty SketchUp model. I am using it with v2014. I have tried this plugin with .skp files and worked perfectly.
                        appgeo
                        I installed successfully to Sketchup Make Version 16, 32 bit on Windows PC running Windows 7.
                        Imported 4 small .DAE files and report says successful. However, nothing shows up on screen.
                        These files load fine when using the "File, Import" dialog in Sketchup, one at a time.
                        In "File, Import" dialog you have to place imported DAE file manually. Plug in does not ask. I always insert at origin of the model, so that would be fine. What am I doing wrong?
                        Thanks! Fred
                        • H
                          harnstein
                          Hi @TIG,
                          I'm working on modeling a bunch of objects from photo reference. Therefore I used your plugin to mass import image files.
                          They come in nicely arranged next to each other - unfortunately they're all in random order..??
                          Their original filename is DSC_XXX, I tried batch renaming it to incremental numbers but that didnt solve it.
                          Any idea how to solve this?
                          Many thanks as usual πŸ˜„ Niko
                          still sketchin'
                            If you want to import the file types in alphanumeric order, then sort the list as follows.
                            Edit the file [../Plugins/import_from_folder.rb] using a plain-text editor like Notepad++ [or TextWrangler on MAC].
                            At line #124
                            list.each_with_index{|f, ix|...
                            change it to read
                            list.****sort.****each_with_index{|f, ix|...
                            then save and close.
                            Now restart SketchUp...
                            • H
                              harnstein
                              Thanks a lot for your super quick support!
                              I'll try it when I get back to the office.
                              Another TIG tool that comes right on time.. πŸ˜‰
                              still sketchin'
                                Sugareth
                                Hi all, I have posted a companion plugin for Blender, which enables you to bulk export Collada files from Blender (which is very good at importing STL). Hope it helps someone.
                                https://github.com/johnnyshield/blender
                                  superanus
                                  amazing tool - thanks
                                  I have 50+ geolocated skp files
                                  is it possible to place them according its own coordinates instead all in 0,0,0
                                  would donate this feature- thank you in advance!
                                    Unfortunately SKP imports default to 0,0,0 - unless it's done manually - when you can choose a location.
                                    However, if a SKP is geo-located, then importing it [e.g. manually] can force it to its geo-located point ??
                                    I can't see how we need to automate that...
                                    • H
                                      harumscarum
                                      just recently it was possible to make this with the KMZ files
                                      as soon as geo-located model or Geo-Location itself is in SketchUp scene - on the import KMZ files placing each in just exact location
                                        Sorry, but your post is unclear.
                                        Is it a question or a statement of fact ??
                                        Please explain...
                                        • H
                                          harumscarum
                                          just checked again - it also works with the SKP files (with geo-located ones)
                                          1. fist we need to add as many location tiles as we need - File - Geo-Location - Add Location
                                          2. after that all geo-located SKP files automatically importing on its location - no need to move it
                                          here is a quick test - 3 random buildings in the Austin, TX downtown
                                            mojikenso
                                            thankjk
                                            • 4 / 4
