    FlexTools Updates
    Scheduled Pinned Locked Moved FlexTools
    renderpluginsextensions
    168 Posts 17 Posters 289.8k Views 17 Watching
      pibuz
      This is real wonder 😍 😍 😍 😍
      WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
      • halroachH Offline
        halroach
        Meet the new FlexDoor Glass component!
        Now you can easily create different dynamic glass doors with additional panels and multiple muntin distributions. The detailed documentation is in the works.
        See more at https://flextools.cc/blog/new-flexdoor-glass/
        FlexTools - Super Quick Windows, Doors, Slats...
          pibuz
          So cool! Thanks!
          ...did you guys had a look to the bug that I reported some time ago, about componentfinder including objects in folders different from the selected?
          https://sketchucation.com/forums/viewtopic.php?f=403&t=71638
          • utilerU Offline
            utiler
            This is so so good!!! Congratulations to you guys to continually listening to your user base and implementing new features! 👍 👍 👍
            Just Curious...
            • halroachH Offline
              halroach
              @pibuz said:
              So cool! Thanks!
              Yes, we'll try to have this fixed in the next ComponentFinder update.
                pibuz
                Wonderful! Thanks!!!!
                • halroachH Offline
                  halroach
                  Check out the updated FlexDoor & FlexDoor Glass - Learn Page.
                  Find out what you can do with these flex components, including how to change the glass distributions, assign materials, make a glass pivot door, and more.
                  https://flextools.cc/wp-content/uploads/2020/03/FlexDoor-Glass_main-anim_02-gif_03.gif
                  • utilerU Offline
                    utiler
                    Super cool additions guys...!! nice to see you expanding this great suite of tools!!
                    Just Curious...
                    • halroachH Offline
                      halroach
                      Many thanks to Justin from 'The SketchUp Essentials' for a great FlexDoor Glass review!
                      • halroachH Offline
                        halroach
                        • mogrenM Offline
                          mogren
                          UN bonus serait d'avoir dans le arch window une possibilité paramétrable d'entourage de l'arc (voir capture)
                          Je ne sais pas si c'est une tannée de programmation.
                            On doit pouvoir tricher avec une texture! 😉
                            Maybe cheat with a texture ?
                              Even by default, it's not so bad! 😄
                              Separate for have more size acceptable (no made here! 😄
                              • mogrenM Offline
                                mogren
                                Oui.. un peu long comme mise en oeuvre tout ça.
                                De mon cotĂ© j'avais recréé une arche avec l'outil dĂ©calage, fermĂ©e avec mĂȘme diamĂštre et mĂȘme nombre de segments (nombre impair pour la clĂ© de voute) juste au-dessus de mon composant puis utilisĂ© le plugin Split tool pour l'appareillage qui s'adapte aux segments
                                En derniÚre étape si je veux que l'appareillage soit saillant du nu du mur: un Fredo's Joint push pull pour l'extrusion de toutes les pierres ou au choix une par une.
                                D'ailleurs au moment de ce dernier l'application a sauté, je me demande si ce n'est pas un conflit entre Joint push pull et Split view?
                                C'est une méthode aussi trop longue, le but de ma question s'adressait au dévellopeur de Flex s'il imaginait pouvoir rajouter la fonction à l'Archwindow (qui est déjà trÚs pratique)
                                  Il semble qu'il a pris bonne note et donnĂ© une cool astuce! ☀ (voir 2 posts plus haut! 😉
                                  • mogrenM Offline
                                    mogren
                                    What I would like ☀
                                    • mogrenM Offline
                                      mogren
                                      Exemple
                                        Hospices imaginaires ou ayant existés ?
                                        • mogrenM Offline
                                          mogren
                                          Décor film
                                          • halroachH Offline
                                            halroach
                                            @mogren said:
                                            What I would like ☀
                                            You should be able to get that with the following settings.
                                            'Inset' to move the window in/out in relation to the wall.
                                            'Frame - Depth' to get it as deep as you need.
                                            Play with the 'Frame - Width' setting to change what you wrote as Height in your picture.
                                            • 5 / 9
