    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 1.1m Views 79 Watching
    • HornOxxH Offline
      HornOxx
      Hi All - Back in 2017 I modelled Homer Simpson's head and loudly announced that I intend to make the whole guy - someday 😉 (https://sketchucation.com/forums/viewtopic.php?f=397&t=63826&start=810)
      Now, more than two years later, I finally managed to realize this announcement - still without clothes though, but that's again another task - sometime 😄
      Homer's body was modeled as individual segments first, such as body, arms, legs... and then finally merged into one solid. Only details like eyes, ears and his 3 hairs are added as independent solids. The renderings are made with Enscape and Shaderlight
      Enjoy 😄
      Enscape Render
      Shaderlight Render
      Enscape Render
      never trust a skinny cook
      • BoxB Offline
        From Hornoxx's brilliant complexity to perhaps the simplest SUbD of all, a Guitar Pic.
        • bazB Offline
          baz
          Simple rocks. I am a bit SubD challenged meself, but I watched that gif 3 times, then went and did it in about the same time, (a bit longer). Perfick.
          Ta.
          • BoxB Offline
            That's the trick Baz, start small and play with little shapes and see what you get. Gradually you'll see how to put shapes together to make complex structures.
            • bazB Offline
              baz
              Yes. Ciao.
              • HornOxxH Offline
                HornOxx
                SubD´s range of possibilities couldn't be better illustrated than with Alsomar´s corinthian column masterpiece and Box´s ingenious Guitar Pic quicky-exercise (both above here) - both are great examples! Thanks for sharing 😄
                • alsomarA Offline
                  alsomar Extension Creator
                  D'oh! What a great Homer!
                  Alejandro Soriano Visuals · All my links
                  • alsomarA Offline
                    Hello there!
                    Here's a vintage fan I modelled yesterday. Besides SUbD I used some other extensions like VertexTools and QuadFace Tools.
                    Rendered pic in V-Ray
                    Rendered pic in V-Ray (quads overlayed)
                    Views in SketchUp (0 subdivisions)
                    Views in SketchUp (2 subdivisions)
                    Views in SketchUp (just profiles)
                    • HornOxxH Offline
                      HornOxx
                      ... Prima !! 👍
                      • BoxB Offline
                        Excellent.
                        • alsomarA Offline
                          An old fashioned caravan.
                          • HornOxxH Offline
                            HornOxx
                            😄 👍 ... again a so nice model idea - especially with the box-shaped carriage, I wouldn't have guessed SubD first 😄
                            • HornOxxH Offline
                              HornOxx
                              Hi All - To bring my Homer Simpson endless project to an end, I finally decided to put him on his white shirt, his blue pants and his shoes. Finally the winter is approaching here and Homer should not freeze 😄
                              If anyone wants to SubD-play with this thick cuddly yellow guy himself, I´ll add the entire proxy model here...
                              The rendered model, without SubD-function then, is also available in the 3D Warehouse:
                              https://3dwarehouse.sketchup.com/model/60074a83-9b9d-4f29-85aa-73cf6e29be75/Homer-Simpson-by-HornOxx
                              edit: pic2 - did some minor modeling improvements at Homer's mouth
                              PROXY model
                              • BoxB Offline
                                A little early morning SUbD insanity, took quite a while to subdivide. I wouldn't have done the whole thing if I had thought about it properly, just one segment and array. But this is all one piece with thickness and is a solid. Added the cutaway to see the inner structure.
                                  • BoxB Offline
                                    Just a bit of fun. For the absolute simplicity of it.
                                    • HornOxxH Offline
                                      HornOxx
                                      ... wunderbar - how does this inner glass shape look like (raw)? Somewhere I read of "extra thumbs up" - you know where it right now comes from...
                                      • BoxB Offline
                                        Is this what you mean?
                                        I didn't save the model so I reproduced it.
                                        Note the outer layer I have thickened with JPP, not shown in the original image.
                                        • BoxB Offline
                                          This one shows how if you SUbD before JPP you get the sharp edges in the original render rather than the soft ones in the second model.
                                          • HornOxxH Offline
                                            HornOxx
                                            Thanks, now I got it 😄 - I first assumed to see 2 shapes above. To see your competent handling with geometry is impressive allways 👍 - for exampe that you started with a section plane to generate this first shape ...
                                            • 65
                                            • 66
                                            • 67
                                            • 68
                                            • 69
                                            • 82
                                            • 83
                                            • 67 / 83
