    [Plugin] Smooth Zoom 2.1.0 - 24 October 2021
    76 Posts 31 Posters 96.5k Views 30 Watching
      Anton_S
      Hi Chris,
      I updated SmoothZoom for SU2019 compatibility.
      Anton
        awadrummer
        @anton_s said:
        Hi Chris,
        Anton
        Awesome! Thanks Anton!
        • zooenZ Offline
          zooen
          Merci Anton!
            SKEMTHESAGE
            are you planing on making a mac version? I think the accelerometer could be very useful and smooth with this plug in 😄
              Anton_S
              Mac OS X has a completely different API. I do not know if there is a way to hack into a Mac OS X SketchUp window to take control of the the mouse wheel input. That is sure possible with Windows API but probably not with Mac OS X API, Carbon or Cocoa.
              I know that zooming with laptop mouse pads already eliminates the bumpiness from zoom. Perhaps a better mouse wheel hardware is a solution.
                awadrummer
                Hi, I just upgraded from Sketchup 2019 to 2021 and noticed this plugin doesn't appear to work for the new version. Is there a chance that it will be updated to work with the new version of Sketchup? Is there an alternative? Thank you!
                  pibuz
                  Same here.
                  It was working on 2020 but it isn't anymore on 2021..
                  So sad!
                  WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                    Anton_S
                    Announcing version 2. This one should not interfere with any tools. The way this works is it suppresses existing mouse wheel messages with deltas of 120 and in turn sends multiple subsequent mouse wheel messages with smaller deltas, yielding smoother transition effects. Let me know if this works, so that I can decide how to proceed with this. Options to adjust zoom intensity will be added soon. Thanks!
                    By the way, this is still Windows only, for now (SU6-SU2021). I only tested this with SU2020 and SU2021 though. Also, AMS Library is not longer needed for this, so this is an independent plugin.
                      pibuz
                      Wonderful!!! Thanks Anton!
                        AISmebel
                        Hello. Thank you very much for the useful plugin. It is very convenient.
                        After the update, the option menu disappeared. Please return it to adjust the speed. Thank you very much! 👍
                          awadrummer
                          Hey Anton, thank you so much for the update! For me personally I utilize this plugin in order prevent having to scroll a lot to get in and out of my models. I'm not necessarily particular about how smooth the zooming is. I just do a lot of large scale models, mainly floor plans for schools and office buildings and to get in and change a wall I have to scroll in a lot. I got around it temporarily by changing my Logitech mouse to treat one scroll wheel movement as 3 which was ok except when I had to use the save or open dialog box to scroll through files lol.
                          Again thank you so much for continuing to offer this capability. I can't wait until you add back the dialog to set the scroll distance as this helps so much.
                            gisello
                            how to regulate the smoothnes sof the zoom in SketchUp 2020 - 21 ?
                            option command are not available
                              Anton_S
                              Announcing 2.1. This version allows adjusting single-notch duration and frequency.
                              • X Offline
                                xyhcwu
                                Thank you very much for sharing 👍
                                  AISmebel
                                  Dear Anton_S, I have been using your plugin for a very long time, it greatly facilitates daily work in SU.
                                  I personally express my point of view, but your plugin, up to version <2.0, was more convenient for me. Scrolling was smoother and easier to work with. Going back to the old version of Smooth Zoom again....
                                    Anton_S
                                    I am curious if version 2 even works for you. Do you notice a difference with this plugin installed?
                                      AISmebel
                                      Hi.
                                      Now I have version 1.3.0a installed with settings:
                                      Intenstity 0.8
                                      Transition Time 1.25
                                      Update FPS 60
                                      And it is very convenient for me to use. Smooth camera movement, which I can stop at any time, and this is very convenient)
                                      With these settings it sometimes slows down, but only when my SU model is filled with models with a lot of polygons.
                                      I installed version 2.0, the movement of the camera did not suit me, and I could not change the characteristics of the camera in the menu. I had to return the old version 1.3.0a.
                                      2.1 also did not suit me.
                                      Once again, this is just my opinion))) For some, version 2.1 is more suitable)))
                                      • TutorialsUpT Offline
                                        TutorialsUp
                                        Hi, Anton
                                        Thanks for updating this plugin.
                                        can we adjust zoom in/out speed like the layout?
                                        I'm using mouse 4th and 5th buttons as a scroll to zoom in and out in SketchUp but using with buttons zoom in/out speed is very fast and windows scroll speed settings are not applied in SketchUp viewport.
                                        it would be great if I can decrease speed with your Plugins. I want very slow
                                          Anton_S
                                          @tutorialsup said:
                                          Hi, Anton
                                          Hey. How do you zoom in/out with 4th and 5th buttons? What are these buttons you are referring to? For me, I can only zoom with the mouse wheel.
                                            TutorialsUp
                                            @anton_s said:
                                            @tutorialsup said:
                                            Hi, Anton
                                            Anton thank you so much for your response, Actually, with the help of X-Mouse Button Control software or Logitech software, I can use these buttons as a wheel up and down. Right now it's helping but speed is a bit fast. and there is no any way to control the speed.
                                            Thanks again
                                            https://imgur.com/iipShDx
                                            • 3 / 4
