    [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26
    2.2k Posts 573 Posters 4.2m Views 575 Watching
      Hmmm... I just download it from the PluginStore and it downloaded with the .rbz extension.
      What do you get when you use the Sketchucation Extension Store to download and install it?
        llaves
        Apparently it's some strange interaction with the Free Download Manager plug-in in Firefox (and Chrome). But what has me baffled is that it only affected LibFredo, but not any other extension I downloaded. But at least it's solved (for now).
        Really got burned by g28 once - have avoided it ever since.
          I'm using Chrome with no problems.
          What is g28 and what does it have to do with this?
          • fredo6F Offline
            NEW RELEASE: LibFredo6 v9.1a - 20 Jul 19
            LibFredo6 9.1a fixes various bugs and is required for FredoPortrait 1.2a
            • fredo6F Offline
              NEW RELEASE: LibFredo6 v9.1b - 28 Jul 19
              LibFredo6 9.1b is a minor release for
              • Souvenir 1.8d, with the possibilité to specify the directory where SU tasks are saved
              • Animator video generation, with a timeout extended to 60 minutes for VRay.
                radimjurca
                Hi, thank you for plugin. I have a problem with icon on the deskop. i cant opredo. Jpg is en fin annexe. Thank you for answer
                help
                  The empty toolbar should have a tooltip when you hover over it.
                  What does it say ?
                  If you drag it onto the main work area can you see anything more ?
                  A little more detail would help us help you...
                    donglihuoguo
                    Glad to hear its working 👍
                    • OxerO Offline
                      Oxer
                      Spanish Language file updated:
                      LibFredo6_ES.zip
                      • fredo6F Offline
                        [attachment=0:a941s360]<!-- ia0 -->LibFredo6_ES.zip<!-- ia0 -->[/attachment:a941s360]
                        Thank you very much. This will go in the next version.
                          spun47x
                          Hey is anyone else having issues with Fredotools on 2019? I get this error -
                          http://jjg.io/x/Capture.JPG
                          http://jjg.io/x/Capture2.JPG
                          I've tried installing libfredo6 before, or after, uninstalling reinstalling, doing it via download vs sketchucation store. alll out of ideas
                          • fredo6F Offline
                            Can you clean and reinstall FredoTools instead.
                              I know that these kinds of errors have been seen before... and easily fixed by Fredo.
                              I think it involves temporarily deleting some preference file/folder, or removing an old/unneeded 'traductor' file...
                              But I'm sure Fredo will be along to advise you later, with the definitive answer...
                                llammc
                                Instalei o LIBfredo6 que funcionava bem. mas por último quando inicio o SketchUP aparece este erro descrito abaixo.
                                ERRO SKETCHUP 2016
                                Erro ao carregar o arquivo Fredo6_Curviloft.rb
                                Error: #<ArgumentError: wrong number of arguments (2 for 1)>
                                C:/Users/Lourival/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:308:in top_load' C:/Users/Lourival/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_Curviloft.rb:50:in module:Fredo6'
                                C:/Users/Lourival/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_Curviloft.rb:26:in <top (required)>' Erro ao carregar o arquivo Fredo6_FredoTools.rb Error: #<ArgumentError: wrong number of arguments (2 for 1)> C:/Users/Lourival/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:308:in top_load'
                                C:/Users/Lourival/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_FredoTools.rb:50:in <module:Fredo6>' C:/Users/Lourival/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_FredoTools.rb:26:in <top (required)>'
                                meu sistema é Win7 de 64 bits
                                isto tambem passou a aparecer após instalar outro plug-in que tambem teria como base o LIBFREDO6
                                  adorian
                                  Help!
                                  I tried several times and this window still comes out. (>.<)'
                                  Does anyone know what can I do?
                                    How did you install it?
                                    What version of SketchUp are you using? Please complete your profile.
                                      @Dave R beat me to it [again!]
                                      Anyway...
                                      A few things to check...
                                      Please complete your details with OS, SUp version etc...
                                      When you installed SketchUp did you select the installer file's exe icon and choose the right-click context-menu "Run as administrator" ?
                                      You can try a repair [rather than a full uninstall/reinstall]...
                                      Whilst logged into Windows as your normal user-account... close SketchUp and use "Run as administrator" - when prompted choose "Repair" [for a fresh installation the option is "Install"]
                                      Installing in other ways - e.g. by double-clicking the exe file to "Run" it - can result in weird permission problems, missing files/folders etc...
                                      Have you also installed the latest version of LibFredo ?
                                      AND restarted SketchUp afterwards to sync everything...
                                      After all of these tries, also try to reinstall FredoTools from its RBZ...
                                        LoulouCaskou
                                        Hello !
                                        I installed LibFredo6 as explained in the video, seems to work, but as i try to install RoundCorner from the ExtensionManager, it seems to work as it's written "Signed", but nothing appears in the sketchup page, cannot find the use of the plugin even if it seems to be there somewhere.
                                        Do you know what i should do?
                                          First, try closing and restarting SketchUp.
                                          Next, look in View>Tool Palettes. Or look in Tools>Fredo6 Collection.
                                            PeterHead
                                            need help..
                                            I already install round corner but the icon didn't show up
                                            • 76
                                            • 77
                                            • 78
                                            • 79
                                            • 80
                                            • 109
                                            • 110
                                            • 78 / 110
