    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.2k Posts 583 Posters 9.3m Views 585 Watching
    • fredo6F
      @hugomego said:
      Question : is there anyway you can render to chaos groups new cloud render service from animator ?
      The ' render to cloud button' in vray next for SU is situated in the asset panel. We usually use their service for larger longer renders.
      Rendering animations created by Animator from the Rendering Software is really something that is left to the developers of the rendering software. I have published an API for these rendering software to interact with Animator and render the frames in batch. So far, only Thea Render has implemented it.
      I am not sure however there is enough traction for them to engage into these (small) developments.
      • H
        hugomego
        Thank you, I will raise it with Chaos Group to see their thoughts. It would be an additional route to their new cloud render service. Animator seems to level the playing field in the 3DS Max versus Sketch up choice especially in the property development market, so the need for them to accomodate will hopefully increase.
        • L
          llaves
          Something seems to be wrong with the link on the SketchUCation extension store. When I tried to download LibFredo6 I get a file ending in .php, not rbz. This problem doesn't occur for any other extension I've tried to download. The problem exists in both Firefox and Chrome browsers.
            Hmmm... I just download it from the PluginStore and it downloaded with the .rbz extension.
            What do you get when you use the Sketchucation Extension Store to download and install it?
            • L
              llaves
              Apparently it's some strange interaction with the Free Download Manager plug-in in Firefox (and Chrome). But what has me baffled is that it only affected LibFredo, but not any other extension I downloaded. But at least it's solved (for now).
              Really got burned by g28 once - have avoided it ever since.
                I'm using Chrome with no problems.
                What is g28 and what does it have to do with this?
                • fredo6F
                  NEW RELEASE: LibFredo6 v9.1a - 20 Jul 19
                  LibFredo6 9.1a fixes various bugs and is required for FredoPortrait 1.2a
                  • fredo6F
                    NEW RELEASE: LibFredo6 v9.1b - 28 Jul 19
                    LibFredo6 9.1b is a minor release for
                    • Souvenir 1.8d, with the possibilité to specify the directory where SU tasks are saved
                    • Animator video generation, with a timeout extended to 60 minutes for VRay.
                      radimjurca
                      Hi, thank you for plugin. I have a problem with icon on the deskop. i cant opredo. Jpg is en fin annexe. Thank you for answer
                      help
                        The empty toolbar should have a tooltip when you hover over it.
                        What does it say ?
                        If you drag it onto the main work area can you see anything more ?
                        A little more detail would help us help you...
                          donglihuoguo
                          Glad to hear its working 👍
                          • OxerO
                            Oxer
                            Spanish Language file updated:
                            LibFredo6_ES.zip
                            • fredo6F
                              [attachment=0:a941s360]<!-- ia0 -->LibFredo6_ES.zip<!-- ia0 -->[/attachment:a941s360]
                              Thank you very much. This will go in the next version.
                                spun47x
                                Hey is anyone else having issues with Fredotools on 2019? I get this error -
                                http://jjg.io/x/Capture.JPG
                                http://jjg.io/x/Capture2.JPG
                                I've tried installing libfredo6 before, or after, uninstalling reinstalling, doing it via download vs sketchucation store. alll out of ideas
                                • fredo6F
                                  Can you clean and reinstall FredoTools instead.
                                    I know that these kinds of errors have been seen before... and easily fixed by Fredo.
                                    I think it involves temporarily deleting some preference file/folder, or removing an old/unneeded 'traductor' file...
                                    But I'm sure Fredo will be along to advise you later, with the definitive answer...
                                    • L
                                      llammc
                                      Instalei o LIBfredo6 que funcionava bem. mas por último quando inicio o SketchUP aparece este erro descrito abaixo.
                                      ERRO SKETCHUP 2016
                                      Erro ao carregar o arquivo Fredo6_Curviloft.rb
                                      Error: #<ArgumentError: wrong number of arguments (2 for 1)>
                                      C:/Users/Lourival/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:308:in top_load' C:/Users/Lourival/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_Curviloft.rb:50:in module:Fredo6'
                                      C:/Users/Lourival/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_Curviloft.rb:26:in <top (required)>' Erro ao carregar o arquivo Fredo6_FredoTools.rb Error: #<ArgumentError: wrong number of arguments (2 for 1)> C:/Users/Lourival/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:308:in top_load'
                                      C:/Users/Lourival/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_FredoTools.rb:50:in <module:Fredo6>' C:/Users/Lourival/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_FredoTools.rb:26:in <top (required)>'
                                      meu sistema é Win7 de 64 bits
                                      isto tambem passou a aparecer após instalar outro plug-in que tambem teria como base o LIBFREDO6
                                        adorian
                                        Help!
                                        I tried several times and this window still comes out. (>.<)'
                                        Does anyone know what can I do?
                                          How did you install it?
                                          What version of SketchUp are you using? Please complete your profile.
                                            @Dave R beat me to it [again!]
                                            Anyway...
                                            A few things to check...
                                            Please complete your details with OS, SUp version etc...
                                            When you installed SketchUp did you select the installer file's exe icon and choose the right-click context-menu "Run as administrator" ?
                                            You can try a repair [rather than a full uninstall/reinstall]...
                                            Whilst logged into Windows as your normal user-account... close SketchUp and use "Run as administrator" - when prompted choose "Repair" [for a fresh installation the option is "Install"]
                                            Installing in other ways - e.g. by double-clicking the exe file to "Run" it - can result in weird permission problems, missing files/folders etc...
                                            Have you also installed the latest version of LibFredo ?
                                            AND restarted SketchUp afterwards to sync everything...
                                            After all of these tries, also try to reinstall FredoTools from its RBZ...
                                            • 71
                                            • 72
                                            • 73
                                            • 74
                                            • 75
                                            • 112
                                            • 113
                                            • 73 / 113
