    [Plugin] ComponentScenes v0.3 UPDATE
    17 Posts 6 Posters 14.4k Views 6 Watching
    • T
      tim
      @tim said:
      something oblong the same lines
      Hunh? Damn you auto cockerel. That should be oolong
      • T
        tim
        New version uploaded 15 Jun 2012; try to make the zoom setting for each component scene actually work. Yet again, the API does't do what it says in the docs.
        • Dan RathbunD
          Dan Rathbun
          @tim said:
          Pages seem to be happy to share names whereas Layers seem to prefer unique names and there shouldn't be any clashes.
          I think your asking for trouble.
          What will happen when code tries to get a reference to a page with: pages["name"] ??
          I'm not here much anymore.
            It is daft that Definitions, Layers, Materials etc must have unique names - set automatically, BUT every Scene-tab could be called 'foo' !
            You can 'uniquify' your page names... before falling foul of the potential for duplicated names...
            ### assuming that 'pages' is reference to the Model's Pages object
            names = []; pages.each{|page| names << page.name }
            used = []; names.each{|name|
              unless used.include?(name)
                used << name
              else ### already used !
                name = name+"#1"
                name.next! while used.include?(name)
                used << name
            used.each_with_index{|name, i| pages[i].name = name }
            NOW the Scene-tabs will have unique names !
            foo, foo#1, foo#2, foo#3 etc...
            • K
              kostiaarh
              Can anyone help me? please add icons for this plugin. I tried to do it, but could not get the plugin to work. Thanks
              ComponentScenes.rar
                When you join strings into a file-path it's best NOT to use a separator.
                So NOT
                cmd.large_icon = File.join(imgdir, "/cs_l.png")
                but
                cmd.large_icon = File.join(imgdir, "cs_l.png")
                Although Ruby should usually fix it for you.
                However, I don't think that is the issue - I suspect it is with your PNG files themselves.
                PNGs for buttons need not be that big, also your PNGs are in 'Indexed Colors' - try converting them to 'RGB' with something like Gimp.
                Your larger PNG is 1.5kb, my toolbar equivalents are usually considerably smaller...
                Yours is 128px sq, when mine is 24px sq - just like the su_... equivalents...
                Again you can use Gimp to resize then down to 24px sq [16px sq for small icons]...
                As recommended here:
                http://ruby.sketchup.com/UI/Command.html#large_icon=-instance_method
                • BoxB
                  7 years between posts, impressive.
                  • K
                    kostiaarh
                    Thanks Tig. I made all the corrections but the plugin does not work. I don’t know what to do with it.
                    Error: #<NameError: undefined local variable or method deleting_group' for main:Object> C:/Users/KOSTIA/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ComponentScenes.rb:189:in block in <top (required)>'
                    2ComponentScenes.rar
                      The error message is most helpful.
                      Your code calls deleting_group from outside the module !
                      The get it to work move all of your toolbar code inside it, and rename the methods with self.xxx
                      However, you never define deleting_group and ComponentScenes is used oddly within the menu code.
                      It all needs reworking...
                      Look at some other authors code that define a cmd and make a toolbar...
                      You have muddled up everything !
                      • K
                        kostiaarh
                        I would also like to know if it is possible to organize the created scenes in the panel? For example, scene1, scene2, scene3 ... sceneN? When I use this plugin, the scenes are placed in a chaotic order.
                          You are jumping around somewhat in your 'problems'...
                          Look at the Pages and Page section of the API guide.
                          You need to get an array of the scene-tabs names and sort them, then reorder the scenes accordingly...
                          http://ruby.sketchup.com/Sketchup/Pages.html
                          It's not that easy to do !
                          But here's a crib to get you started...
                          model = Sketchup.active_model
                          pages = model.pages
                          num   = pages.length
                          if num > 0
                            selected = pages.selected_page.name
                            page_names = pages.map{|pg| pg.name }
                            page_names.sort!
                            num = page_names.length
                            page_names.each{|page|
                              tran_time = pages[page].transition_time
                              pages[page].transition_time = 0
                              delay_time = pages[page].delay_time
                              pages[page].delay_time = 0
                              pages.selected_page = pages[page]
                              new_page = pages.add(page)
                              new_page.transition_time = tran_time
                              new_page.delay_time = delay_time
                            num.times{ pages.erase(model.pages[0]) }
                            pages.selected_page = pages[selected]
                          Pages [Scenes] are now in order...
                          • K
                            kostiaarh
                            Thank you Tig. I put this code in the toolbar editor. Works great.
