    [Plugin] ComponentScenes v0.3 UPDATE
    17 Posts 6 Posters 14.4k Views 6 Watching
    • T
      tim
      @rich o brien said:
      It's somewhat similar to this....
      404 Not Found
      (forums.sketchucation.com)
      Yes, it has some important similarities to both the viewports and Comp2Layer plugins including the fact that they jointly inspired me to try something oblong the same lines but more suited to my own needs. ComponentScenes works with nested components though, which viewports seems not to handle. Comp2Layer actually moves the chosen components to new layers, which I found annoying.
      Most importantly to me the process of writing the plugin is a learning experience; the possibility that it may result in something useful to other people is a nice bonus ๐Ÿ˜„
      • T
        tim
        Hunh? Damn you auto cockerel. That should be oolong
        • T
          tim
          New version uploaded 15 Jun 2012; try to make the zoom setting for each component scene actually work. Yet again, the API does't do what it says in the docs.
          • Dan RathbunD
            Dan Rathbun
            @tim said:
            Pages seem to be happy to share names whereas Layers seem to prefer unique names and there shouldn't be any clashes.
            I think your asking for trouble.
            What will happen when code tries to get a reference to a page with: pages["name"] ??
            I'm not here much anymore.
              It is daft that Definitions, Layers, Materials etc must have unique names - set automatically, BUT every Scene-tab could be called 'foo' !
              You can 'uniquify' your page names... before falling foul of the potential for duplicated names...
              ### assuming that 'pages' is reference to the Model's Pages object
              names = []; pages.each{|page| names << page.name }
              used = []; names.each{|name|
                unless used.include?(name)
                  used << name
                else ### already used !
                  name = name+"#1"
                  name.next! while used.include?(name)
                  used << name
              used.each_with_index{|name, i| pages[i].name = name }
              NOW the Scene-tabs will have unique names !
              foo, foo#1, foo#2, foo#3 etc...
              • K
                kostiaarh
                Can anyone help me? please add icons for this plugin. I tried to do it, but could not get the plugin to work. Thanks
                ComponentScenes.rar
                  When you join strings into a file-path it's best NOT to use a separator.
                  So NOT
                  cmd.large_icon = File.join(imgdir, "/cs_l.png")
                  but
                  cmd.large_icon = File.join(imgdir, "cs_l.png")
                  Although Ruby should usually fix it for you.
                  However, I don't think that is the issue - I suspect it is with your PNG files themselves.
                  PNGs for buttons need not be that big, also your PNGs are in 'Indexed Colors' - try converting them to 'RGB' with something like Gimp.
                  Your larger PNG is 1.5kb, my toolbar equivalents are usually considerably smaller...
                  Yours is 128px sq, when mine is 24px sq - just like the su_... equivalents...
                  Again you can use Gimp to resize then down to 24px sq [16px sq for small icons]...
                  As recommended here:
                  http://ruby.sketchup.com/UI/Command.html#large_icon=-instance_method
                  • BoxB
                    7 years between posts, impressive.
                    • K
                      kostiaarh
                      Thanks Tig. I made all the corrections but the plugin does not work. I donโ€™t know what to do with it.
                      Error: #<NameError: undefined local variable or method deleting_group' for main:Object> C:/Users/KOSTIA/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ComponentScenes.rb:189:in block in <top (required)>'
                      2ComponentScenes.rar
                        The error message is most helpful.
                        Your code calls deleting_group from outside the module !
                        The get it to work move all of your toolbar code inside it, and rename the methods with self.xxx
                        However, you never define deleting_group and ComponentScenes is used oddly within the menu code.
                        It all needs reworking...
                        Look at some other authors code that define a cmd and make a toolbar...
                        You have muddled up everything !
                        • K
                          kostiaarh
                          I would also like to know if it is possible to organize the created scenes in the panel? For example, scene1, scene2, scene3 ... sceneN? When I use this plugin, the scenes are placed in a chaotic order.
                            You are jumping around somewhat in your 'problems'...
                            Look at the Pages and Page section of the API guide.
                            You need to get an array of the scene-tabs names and sort them, then reorder the scenes accordingly...
                            http://ruby.sketchup.com/Sketchup/Pages.html
                            It's not that easy to do !
                            But here's a crib to get you started...
                            model = Sketchup.active_model
                            pages = model.pages
                            num   = pages.length
                            if num > 0
                              selected = pages.selected_page.name
                              page_names = pages.map{|pg| pg.name }
                              page_names.sort!
                              num = page_names.length
                              page_names.each{|page|
                                tran_time = pages[page].transition_time
                                pages[page].transition_time = 0
                                delay_time = pages[page].delay_time
                                pages[page].delay_time = 0
                                pages.selected_page = pages[page]
                                new_page = pages.add(page)
                                new_page.transition_time = tran_time
                                new_page.delay_time = delay_time
                              num.times{ pages.erase(model.pages[0]) }
                              pages.selected_page = pages[selected]
                            Pages [Scenes] are now in order...
                            • K
                              kostiaarh
                              Thank you Tig. I put this code in the toolbar editor. Works great.
