    Bezier camera interpolation
    renderpluginsextensions
    5 Posts 2 Posters 7.7k Views 2 Watching
      chrishe
      Hey Fredo,
      can you explain to me how the bezier camera interpolation works? For me it turns out to be a linear movement.
      Best,
      • fredo6F Offline
        @chrishe said:
        Can you explain to me how the bezier camera interpolation works? For me it turns out to be a linear movement.
        It should not be, although it may depend on the factor you choose.
        Do you have an example ?
          chrishe
          Thank you for your fast reply. I tried the function in another file and it worked... but even after a lot of tries I can't get it to work in the following file:
          https://www.dropbox.com/s/hm6pb8ev8sx52oc/NEUE%20DATEI%202_2017.skb?dl=0
          https://www.dropbox.com/s/6wlhutuk1qzybml/NEUE%20DATEI%202_2017.skp?dl=0
            chrishe
            Also, what factor did you mean? I didn't use any fade-out functions for now.
              chrishe
              The File I posted first is bigger than necessary.
              Here is another example file. If the camera path were curved (between Camera 2 and 3) you would get to see on the box. But as you can see the interpolation is linear.
              Dropbox
              (www.dropbox.com)
