    Softening a cut
    8 Posts 5 Posters 1.9k Views 5 Watching
      miikka1978
      Do you have any idea how to make "soft cut"? I would need to cut a hole to the geometry and I would need to make the edges of the cut geometry soft/round because the object will be 3d printed.
      https://i.postimg.cc/MMSRDH7M/AA.jpg
      This is something I would like to achieve:
      https://i.postimg.cc/HckWdCHv/BB.jpg
      Example Sketchup model
        For whatever reason, your images haven't uploaded. Best bet, though is to upload the SKP file so we can see what you are trying to accomplish. Please also complete your profile with SketchUp version and operating system. That information helps us help you.
          miikka1978
          New try with the pictures. I don't know what happened with the links.
          Now the original post also includes example of the model. Unfortunately I am not able to upload the actual model because it is not my own model.
          The attached example of of the model is quite low poly but I in the final model I would need to make the model high poly in order to have nice and smooth 3D printed object.
          I also updated my profile a little. I am still using 2017 Sketchup Make.
            I think the best approach would bt to draw the shape of the hole including the rounded edge and use the whole thing as a drill to cut the hole.
              rv1974
              Start it flat, then conform it via flowify
              • HornOxxH Offline
                HornOxx
                Hi, might not be a SubD approach also be suitable for this? Finally you could remain in a simple base geometry, similar to this (unfinished!) proxy-sketch below...
                proxy-scribble.skp
                never trust a skinny cook
                  mrossk
                  Some time ago, Jeff Hammond did a great example using Curviloft to do just such a thing. the video is here: http://www.youtube.com/v/gy5VGSxST2Q
                  In the same thread, others posted some other options. Worth a look: https://sketchucation.com/forums/viewtopic.php?f=15&t=46136&p=412551&hilit=curviloft#p412551
                  https://www.mkaplanfinefurniture.com/
                    miikka1978
                    Thanks for everybody for suggestions/tips. I will need to do some testing.
                    I was also thinking that maybe I will try to take the created geometry to Blender and test if I can use Blender for making the whole with soft edges.
