ℹ️ GoFundMe | Our friend Gus Robatto needs some help in a challenging time Learn More
Softening a cut
8 Posts 5 Posters 1.7k Views
    miikka1978
    Do you have any idea how to make "soft cut"? I would need to cut a hole to the geometry and I would need to make the edges of the cut geometry soft/round because the object will be 3d printed.
    https://i.postimg.cc/MMSRDH7M/AA.jpg
    This is something I would like to achieve:
    https://i.postimg.cc/HckWdCHv/BB.jpg
    Example Sketchup model
      For whatever reason, your images haven't uploaded. Best bet, though is to upload the SKP file so we can see what you are trying to accomplish. Please also complete your profile with SketchUp version and operating system. That information helps us help you.
        miikka1978
        New try with the pictures. I don't know what happened with the links.
        Now the original post also includes example of the model. Unfortunately I am not able to upload the actual model because it is not my own model.
        The attached example of of the model is quite low poly but I in the final model I would need to make the model high poly in order to have nice and smooth 3D printed object.
        I also updated my profile a little. I am still using 2017 Sketchup Make.
          I think the best approach would bt to draw the shape of the hole including the rounded edge and use the whole thing as a drill to cut the hole.
            rv1974
            Start it flat, then conform it via flowify
            • H Offline
              HornOxx
              Hi, might not be a SubD approach also be suitable for this? Finally you could remain in a simple base geometry, similar to this (unfinished!) proxy-sketch below...
              proxy-scribble.skp
              never trust a skinny cook
                mrossk
                Some time ago, Jeff Hammond did a great example using Curviloft to do just such a thing. the video is here: http://www.youtube.com/v/gy5VGSxST2Q
                In the same thread, others posted some other options. Worth a look: https://sketchucation.com/forums/viewtopic.php?f=15&t=46136&p=412551&hilit=curviloft#p412551
                https://www.mkaplanfinefurniture.com/
                  miikka1978
                  Thanks for everybody for suggestions/tips. I will need to do some testing.
                  I was also thinking that maybe I will try to take the created geometry to Blender and test if I can use Blender for making the whole with soft edges.
