    Convert to .dwg
    8 Posts 5 Posters 2.4k Views 5 Watching
    • E Offline
      erzane
      I sent my skp file to a manufacture but they asked me to convert it in .dwg. Unfortunatley in my free version of skp there is no option to do this, only .dea file extension is available for a 3D export.
        There used to be Skp to Dwg converters for free in the Sketchucation plugin store and people used to share Ruby scripts to do that. As far ad I know they have all disappeared since Trimble took over sketchup, as far as I know anyway. if you know somebody with pro kind enough to convert for you? I guess I should warn you that technically you should not use Make for comercial work anyway, sadly 😞
          You haven't given much helpful detail in your Profile.
          If you don't have it, then please download and install the latest SketchUp Make version [v2017]...
          Giving you the benefit of the doubt - assuming this 'manufacture' is for your own personal use - then there are some free SKPtoDXF tools in the SCF PluginStore.
          https://sketchucation.com/pluginstore?pln=GKWare_Simple_DXF
          https://sketchucation.com/pluginstore?pln=dxf_export
          A DXF is often usable in lieu of a DWG format file, but then AutoDesk also have a free DWG-Trueview app which lets you convert a DXF into a DWG too, without having AutoCAD.
          https://knowledge.autodesk.com/support/dwg-trueview/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-download-DWG-TrueView.html
          I assume this file is perhaps for laser-cutting or CNC work etc ?
          For some 3d-printing you can make STL files in Make using an extension from the EWH which appears under the File menu [it's a shipped exporter with newer SUps].
          https://extensions.sketchup.com/en/content/sketchup-stl
          Also look here, for another DXF/STL toolset...
          http://sketchupplugins.com/plugins/convert-sketchup-skp-files-to-dxf-or-stl/
          In the long run getting the Pro version might be your best bet ?
          • E Offline
            erzane
            Thanks for your replies.
            Maybe one of you could convert this file for me of you're using a pro version?
              Maybe you can use the free PConPlanner! 😉
              • E Offline
                erzane
                I now have a SketchUp Pro 2019 v19.0.685 64bit
                Should I uninstall my actual SketchUp Make 2017 or can I just install the new one and replace automaticaly?
                • HornOxxH Offline
                  HornOxx
                  Hi - you can run different SkUps side by side - so there is no need to uninstall previous versions (unless your hard drive doesn't have enough capacity 😉 )
                  never trust a skinny cook
                  • E Offline
                    erzane
                    Ok, thanks!!
