    [Plugin][$] FredoCorner - v2.7a - 31 Mar 24
    442 Posts 153 Posters 674.7k Views 151 Watching
    • fredo6F Offline
      @einstein said:
      Also there are mesh errors in some cases, when bevelling triangulated meshes.
      • screenshot with bug report in some other case of triangulated mesh.
      Do you have the models with the multiple bricks (the one attached only contains 1 brick and is related to the problem of 2 segment beveling). Thanks.
      • E Offline
        Einstein
        Now it works fine. It looks like your last fix fixed also the last issue 😄
        The only issue which is still there is the one with broken mesh.
          dell oglio
          Hi, thank for Your Work on sketchup, it is amazing.
          The fredo corner give me an error when i try to use the chop corner on every corner...How I can Resolve? thanks
          • fredo6F Offline
            First, can you update your profile, at least concerning the SketchUp version you do use (SketchUp 2014 is shown currently, but FredoCorner only runs on SketchUp 2016 and above).
            Second, you do not seem to use the latest version of FredoCorner. Can you download it and check if you still have the problem.
            • yanrothwellY Offline
              yanrothwell
              I've used the old Round Corner for years and now am using this plugin... Thanks so much for it and all your plugins Fredo
              MY corners are inverted and I can't make them as 'normal' round corners. It's not the reversed faces, and clicking invert doesn't do anything... Any idea?
              Merci in advance
              Ian
              http://www.ianrothwell.co.uk
              • fredo6F Offline
                Could you show or post the model please.
                  amsalari
                  WOW, Thanks For nice and very well work
                  • fredo6F Offline
                    NEW RELEASE: FredoCorner v1.6b - 18 Apr 19
                    Requirement: LibFredo6 8.8a
                    FredoCorner 1.6b fixes bugs and extend validity.
                    Please note that, in the current version of FredoCorner:
                    • there are issues with some shortcut modifiers (Ctrl, Alt) on Mac)
                    • there are known issues and bugs here and there. This concerns in particular Collisions, i.e. when the offset is too large.
                    • Terminal corners (that is ending on a single edge) may present issues and bugs
                    • No documentation yet, so watch the videos that I will publish.
                    Please report issues, questions and any feedback in the present thread
                    Home Page of FredoCorner for information and Download.
                    Main post of this FredoCorner thread.
                    • N Offline
                      noldo
                      Hi Fredo, the plug-in fail with this geometry type.
                      Roundcorner work correctly.
                      Untitled.skp
                      • fredo6F Offline
                        It looks like there is a problem in the model.
                        One of the face is actually spreading over 3 blocks
                        This creates an issue with FredoCorner, as you can imagine.
                        Noldo - Corner - Untitled.skp
                        I'll try to detect this type of configuration in a next version.
                        • N Offline
                          noldo
                          [attachment=1:3klx88xg]<!-- ia1 -->Multi faces Corner.png<!-- ia1 -->[/attachment:3klx88xg]
                          [attachment=0:3klx88xg]<!-- ia0 -->Noldo - Corner - Untitled.skp<!-- ia0 -->[/attachment:3klx88xg]
                          Thank's for your work Fredo!
                            cskovago
                            I have just updated to the latest version, because the plugin refused to work as the 1.6 version. Now, it is NON-WORKING order, I can not even copy the bug report (because the cursor turns semi-transparent on the bug-report tab), I can select the faces, edges, I can set the parameters, the plugin calculates the edges, but when I let it done the task, nothing happens, just the bug-report tab is red...
                            Any idea or help, please?
                            Win7, SketchUp 2017 latest
                            • fredo6F Offline
                              @cskovago said:
                              In this kind of situation, it would be helpful to attach the model. Otherwise, this is difficult to find out.
                              If you have the red notification, then there is an error. So, open the Ruby console before launching FredoCorner and check if there are errors displayed. That would also help.
                                ronagoldberg
                                Thank you so much for this plugin and the previous version.
                                I was using it today and got this odd geometry, it only happened on this side, the other side of this box laid out correctly. I realize it would run into the hole in the geometry but I was surprised at what it was doing and that it wasn't doing the same thing on both sides.
                                Ron
                                • fredo6F Offline
                                  Strange! Could you post the model so that I have a close look.
                                  • fredo6F Offline
                                    NEW RELEASE: FredoCorner v1.6c - 20 Jun 19
                                    FredoCorner 1.6c extends validity.
                                      MWH
                                      Hi, Fredo corner stopped working. It says "no good edges at face"or "NO match of edge properties) even with a new drawing and a simple box.
                                      I have reinstalled Fredo Corner v 1.6c and LibFredo6 ver 9.0A and have rebooted my computer. Still same problem.
                                      I´m using Sketchup 8 Pro on Mac OSX Mojave (10.14.5).
                                      Any tips?
                                      Mattias
                                        Your profile indicates you are using SketchUp 2018. Which one is correct?
                                        • fredo6F Offline
                                          This may simply be normal. You have a filter to select edges
                                          Depending on the filter and what you select, FredoCorner may find that there is no effective edges.
                                          So make sure that the edges you select and the filter do match.
                                            MWH
                                            Thanks Fredo:)
                                            It was that simple. Unbelievable that I missed that.
                                            Dave R, you're right. I'm using 2018.
                                            Thanks again!
                                            M
                                            • 22
                                            • 23
                                            • 7 / 23
