    [Plugin][$] FredoCorner - v2.7a - 31 Mar 24
    442 Posts 153 Posters 697.9k Views 151 Watching
    • E
      Einstein
      Hi!
      I have a model where I want do bevel about 500 edges at once. I get an error "CATENA Compute all", whatever it means. It won't let me bevel these edges. Problem doesn't occur with Round Corner. Is it that Fredo Corner just doesn't manage too many edges? Even if so, 500 is not soo many. Even if I select some of them, problem still occurs. About 150 edges is maximum that can be performed.
      Maybe it's because currently my SketchUp runs on integrated Intel graphics card with very limited performance.
      I attach the problematic model.
      /SketchUp 2017 on Win7
      CATENA Compute all.skp
      • E
        Einstein
        Also there are mesh errors in some cases, when bevelling triangulated meshes.
        • screenshot with bug report in some other case of triangulated mesh.
        bevelling mesh errors.skp
        • fredo6F
          Oops! Thanks for signaling. I unfortunately left some limitations for debugging purpose.
          So fixed in next version.
          • fredo6F
            NEW RELEASE: FredoCorner v1.6a - 20 Feb 19
            Requirement: LibFredo6 8.7k
            FredoCorner 1.6a fixes an issue when pre-selecting a lot of edges. There were artificial limitations in the script which are now removed.
            Please note that, in the current version of FredoCorner:
            • there are issues with some shortcut modifiers (Ctrl, Alt) on Mac)
            • there are known issues and bugs here and there. This concerns in particular Collisions, i.e. when the offset is too large.
            • Terminal corners (that is ending on a single edge) may present issues and bugs
            • No documentation yet, so watch the videos that I will publish.
            Please report issues, questions and any feedback in the present thread
            Home Page of FredoCorner for information and Download.
            Main post of this FredoCorner thread.
            • fredo6F
              Do you have the models with the multiple bricks (the one attached only contains 1 brick and is related to the problem of 2 segment beveling). Thanks.
              • E
                Einstein
                Now it works fine. It looks like your last fix fixed also the last issue ๐Ÿ˜„
                The only issue which is still there is the one with broken mesh.
                  dell oglio
                  Hi, thank for Your Work on sketchup, it is amazing.
                  The fredo corner give me an error when i try to use the chop corner on every corner...How I can Resolve? thanks
                  • fredo6F
                    First, can you update your profile, at least concerning the SketchUp version you do use (SketchUp 2014 is shown currently, but FredoCorner only runs on SketchUp 2016 and above).
                    Second, you do not seem to use the latest version of FredoCorner. Can you download it and check if you still have the problem.
                    • yanrothwellY
                      yanrothwell
                      I've used the old Round Corner for years and now am using this plugin... Thanks so much for it and all your plugins Fredo
                      MY corners are inverted and I can't make them as 'normal' round corners. It's not the reversed faces, and clicking invert doesn't do anything... Any idea?
                      Merci in advance
                      Ian
                      http://www.ianrothwell.co.uk
                      • fredo6F
                        Could you show or post the model please.
                          amsalari
                          WOW, Thanks For nice and very well work
                          • fredo6F
                            NEW RELEASE: FredoCorner v1.6b - 18 Apr 19
                            Requirement: LibFredo6 8.8a
                            FredoCorner 1.6b fixes bugs and extend validity.
                            • N
                              noldo
                              Hi Fredo, the plug-in fail with this geometry type.
                              Roundcorner work correctly.
                              Untitled.skp
                              • fredo6F
                                It looks like there is a problem in the model.
                                One of the face is actually spreading over 3 blocks
                                This creates an issue with FredoCorner, as you can imagine.
                                Noldo - Corner - Untitled.skp
                                I'll try to detect this type of configuration in a next version.
                                • N
                                  noldo
                                  [attachment=1:3klx88xg]<!-- ia1 -->Multi faces Corner.png<!-- ia1 -->[/attachment:3klx88xg]
                                  [attachment=0:3klx88xg]<!-- ia0 -->Noldo - Corner - Untitled.skp<!-- ia0 -->[/attachment:3klx88xg]
                                  Thank's for your work Fredo!
                                  • C
                                    cskovago
                                    I have just updated to the latest version, because the plugin refused to work as the 1.6 version. Now, it is NON-WORKING order, I can not even copy the bug report (because the cursor turns semi-transparent on the bug-report tab), I can select the faces, edges, I can set the parameters, the plugin calculates the edges, but when I let it done the task, nothing happens, just the bug-report tab is red...
                                    Any idea or help, please?
                                    Win7, SketchUp 2017 latest
                                    • fredo6F
                                      @cskovago said:
                                      In this kind of situation, it would be helpful to attach the model. Otherwise, this is difficult to find out.
                                      If you have the red notification, then there is an error. So, open the Ruby console before launching FredoCorner and check if there are errors displayed. That would also help.
                                        ronagoldberg
                                        Thank you so much for this plugin and the previous version.
                                        I was using it today and got this odd geometry, it only happened on this side, the other side of this box laid out correctly. I realize it would run into the hole in the geometry but I was surprised at what it was doing and that it wasn't doing the same thing on both sides.
                                        Ron
                                        • fredo6F
                                          Strange! Could you post the model so that I have a close look.
                                          • fredo6F
                                            NEW RELEASE: FredoCorner v1.6c - 20 Jun 19
                                            FredoCorner 1.6c extends validity.
                                            • 22
                                            • 23
                                            • 7 / 23
