    [Plugin][$] FredoCorner - v2.7a - 31 Mar 24
    442 Posts 153 Posters 697.9k Views 151 Watching
    • uwesketchU
      uwesketch
      Fredo wrote:
      I am not sure I full understand the case, but apparently you would like that the SubDiv tool create several subdivision lines instead of one.
      Yes, exactly: more lines .
      The point is that the SubD Plugin will subdivide all faces in a Group/Component. So if I use a FredoCorner Circle to create a smooth corner (with many Segments) and then use as well SubD to smooth the rest of the component, SubD will subdivide as well the already smooth FredoCorner faces. This generates far too many faces and SubD will fail.
      Therefore the idea is that FredoCorner should create a rough SubDivision mesh, so that SubD will generate a nice approximated circle for the corner and also smoothes the rest of the component.
      I also tried it with an Edge where the two faces are not orthogonal. SubD will generate an approximated arc when using the proposed n-gon as a basis.
      The existing option "Subdivision" in FredoCorner is good, but too rough of a mesh, if you want SubD to produce a "circle like" smoothing of the Corner.
      Example of object using FredoCorner and SubD (only the Bell):
      Example combining FredoCorner and SubD
      • fredo6F
        I got it. This is just a little bit complicated, but probably doable.
        • E
          Einstein
          Hi!
          I have a model where I want do bevel about 500 edges at once. I get an error "CATENA Compute all", whatever it means. It won't let me bevel these edges. Problem doesn't occur with Round Corner. Is it that Fredo Corner just doesn't manage too many edges? Even if so, 500 is not soo many. Even if I select some of them, problem still occurs. About 150 edges is maximum that can be performed.
          Maybe it's because currently my SketchUp runs on integrated Intel graphics card with very limited performance.
          I attach the problematic model.
          /SketchUp 2017 on Win7
          CATENA Compute all.skp
          • E
            Einstein
            Also there are mesh errors in some cases, when bevelling triangulated meshes.
            • screenshot with bug report in some other case of triangulated mesh.
            bevelling mesh errors.skp
            • fredo6F
              Oops! Thanks for signaling. I unfortunately left some limitations for debugging purpose.
              So fixed in next version.
              • fredo6F
                NEW RELEASE: FredoCorner v1.6a - 20 Feb 19
                Requirement: LibFredo6 8.7k
                FredoCorner 1.6a fixes an issue when pre-selecting a lot of edges. There were artificial limitations in the script which are now removed.
                Please note that, in the current version of FredoCorner:
                • there are issues with some shortcut modifiers (Ctrl, Alt) on Mac)
                • there are known issues and bugs here and there. This concerns in particular Collisions, i.e. when the offset is too large.
                • Terminal corners (that is ending on a single edge) may present issues and bugs
                • No documentation yet, so watch the videos that I will publish.
                Please report issues, questions and any feedback in the present thread
                Home Page of FredoCorner for information and Download.
                Main post of this FredoCorner thread.
                • fredo6F
                  Do you have the models with the multiple bricks (the one attached only contains 1 brick and is related to the problem of 2 segment beveling). Thanks.
                  • E
                    Einstein
                    Now it works fine. It looks like your last fix fixed also the last issue ๐Ÿ˜„
                    The only issue which is still there is the one with broken mesh.
                      dell oglio
                      Hi, thank for Your Work on sketchup, it is amazing.
                      The fredo corner give me an error when i try to use the chop corner on every corner...How I can Resolve? thanks
                      • fredo6F
                        First, can you update your profile, at least concerning the SketchUp version you do use (SketchUp 2014 is shown currently, but FredoCorner only runs on SketchUp 2016 and above).
                        Second, you do not seem to use the latest version of FredoCorner. Can you download it and check if you still have the problem.
                        • yanrothwellY
                          yanrothwell
                          I've used the old Round Corner for years and now am using this plugin... Thanks so much for it and all your plugins Fredo
                          MY corners are inverted and I can't make them as 'normal' round corners. It's not the reversed faces, and clicking invert doesn't do anything... Any idea?
                          Merci in advance
                          Ian
                          http://www.ianrothwell.co.uk
                          • fredo6F
                            Could you show or post the model please.
                              amsalari
                              WOW, Thanks For nice and very well work
                              • fredo6F
                                NEW RELEASE: FredoCorner v1.6b - 18 Apr 19
                                Requirement: LibFredo6 8.8a
                                FredoCorner 1.6b fixes bugs and extend validity.
                                • N
                                  noldo
                                  Hi Fredo, the plug-in fail with this geometry type.
                                  Roundcorner work correctly.
                                  Untitled.skp
                                  • fredo6F
                                    It looks like there is a problem in the model.
                                    One of the face is actually spreading over 3 blocks
                                    This creates an issue with FredoCorner, as you can imagine.
                                    Noldo - Corner - Untitled.skp
                                    I'll try to detect this type of configuration in a next version.
                                    • N
                                      noldo
                                      [attachment=1:3klx88xg]<!-- ia1 -->Multi faces Corner.png<!-- ia1 -->[/attachment:3klx88xg]
                                      [attachment=0:3klx88xg]<!-- ia0 -->Noldo - Corner - Untitled.skp<!-- ia0 -->[/attachment:3klx88xg]
                                      Thank's for your work Fredo!
                                      • C
                                        cskovago
                                        I have just updated to the latest version, because the plugin refused to work as the 1.6 version. Now, it is NON-WORKING order, I can not even copy the bug report (because the cursor turns semi-transparent on the bug-report tab), I can select the faces, edges, I can set the parameters, the plugin calculates the edges, but when I let it done the task, nothing happens, just the bug-report tab is red...
                                        Any idea or help, please?
                                        Win7, SketchUp 2017 latest
                                        • fredo6F
                                          @cskovago said:
                                          In this kind of situation, it would be helpful to attach the model. Otherwise, this is difficult to find out.
                                          If you have the red notification, then there is an error. So, open the Ruby console before launching FredoCorner and check if there are errors displayed. That would also help.
                                            ronagoldberg
                                            Thank you so much for this plugin and the previous version.
                                            I was using it today and got this odd geometry, it only happened on this side, the other side of this box laid out correctly. I realize it would run into the hole in the geometry but I was surprised at what it was doing and that it wasn't doing the same thing on both sides.
                                            Ron
                                            • 22
                                            • 23
                                            • 7 / 23
