    Housebuilder
    160 Posts 57 Posters 243.2k Views 57 Watching
    • F Offline
      FiKumiczek
      first of all thank you for a great job with keeping alive that old plugin ๐Ÿ˜„
      I want to do translation of this one for a friend and also change some small things.
      However housebuilder.rb and housebuildertool.rb (in folder) are encrypted. Is there any way to do anything to get acces into the code itself? I've already translated toolbar and changed all the lumber sizes, but all the popups are problematic for my friends ๐Ÿ˜ž
        The encrypted RB files can only be unencrypted by the author so you would have to contact him. Based on history, he hasn't been interested in doing that, though.
        • X Offline
          XxXTAZXxX
          I have tried many time to get house builder to install on SU many times. just keeps coming up with error. i am not cpu smart anyhelp would be great
          • X Offline
            XxXTAZXxX
            i have trying to down loading the housebuilder for my SU 17 but i just dont know what to do. i have done, i think the right stuff from other streams. i am at a lose.
              To get/use any RBZ you just download it.
              You do not 'process' it.
              If WinRar thinks it ought to extract it, then stop it doing that.
              An RBZ archive is actually a ZIP archive with its file-type suffix changed...
              Once you have an intact RBZ file - perhaps it's in your Downloads folder - then you just use the 'Install Extension' red button in SketchUp's Window > Extension Manager menu item, and select the RBZ...
              When it is installed, then its menu items, toolbars etc should become available to you...
              • N Offline
                nickb22
                It is the 2017 Version. Yeah every time I try double clicking the RBZ file, I asks how I would like to open it and I canโ€™t find a program to open that file. I have a Microsoft surface pro I believe with windows 10 and itโ€™s been difficult
                @tig said:
                Which version ?
                Contact its author - it is probably easily fixable...
                I am a complete noob at doing all of this. I have downloaded the metric link and since i have WinRAR on my computer, it goes directly there. I have no idea what to do next or how to get into my 2017 Sketchup Pro.
                • N Offline
                  nickb22
                  @oneear said:
                  Nevermind, i found it in a different thread and it installed perfectly in SU 2017. Here is the link i used:
                  404 Not Found
                  (sketchucation.com)
                  How do you open this? Everytime i click it my computer asks me what app would i like to use and it never gives me sketchup as an option.
                    As with any other extension you've downloaded to your computer, in SketchUp, go to Window>Extensions Manager. Click on Install Extension at the bottom of the window. Navigate to where you saved the extension, select it, click Open and then Yes.
                      silenthentefant
                      I just want to say that this is an great plugin and a great forum for some of the issues i had with other problem. Fixed them all by reading in this forum. But now i have question that i didn`t find any answer to. How to change the dimensions on the material? I try to change the numbers in the housebuilder_section.txt, but nothing changed. Do i change this also in rubyeditor? or is there another way?
                      Did do some modification in the plugin, like change the stud and joist spacing so it fits my porpuse.
                      Jan
                      • H Offline
                        Helle
                        Tried to install from this thread, but keep getting:
                        Error Loading File HouseBuilder_extension.rb
                        Error: #<NameError: undefined local variable or method exec_on_autoload' for main:Object> C:/Users/Helle/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/HouseBuilder_extension.rb:197:in <top (required)>'
                        I need the metric version in SU 2016 pro, but I simply cannot figure out what to do (sorry if this has been asked before)
                          Did you get the latest metric RBZ from the link suggested in an earlier post here - http://sketchucation.com/forums/viewtopic.php?p=564448#p564448
                          It works for me...
                          It is old and flaky, and there are newer/better tools around now... but it will work if you load the most recent version...
                            abrahamsfam18
                            I have tried following all the steps listed above but can't get homebuilder installed and working on my PC in Sketchup 2019 Pro. The extension just says "unsigned" in the extension manager.
                              Unsigned does not mean it isn't installed. In fact that is an indication that it is indeed installed. As long as you leave loading permission for extensions set to allow unsigned extensions to load, there's no need to worry about it being unsigned.
                              This is an old extension though and may not run correctly in SU2019 due to changes in the scripting language version since the extension's last update. There are newer extensions out there that do work.
                                Jacester
                                I have the file d/l ed on the computer it says it's in the extension warehouse but, to no avail does it work.. I'm ready to throw my computer through the wall.. wtf why is it so hard to do this simple af task????
                                  Do you mean it shows as installed in Extension Manager? This extension is not hosted in the Extension Warehouse.
                                  All you need to do is look in the correct menu. This extension shows in the Draw menu or you can display the toolbar.
                                    dannygerhard17
                                    I down loaded house builder and install the file into sketch up,but in the warehouse manager it is saying unsigned so is not function correctly, what am I doing wrong???
                                      Leaping to the incorrect conclusion that "Unsigned" means the extension doesn't work. Unsigned would only prevent the extension from loading if you've set the loading permission to limit loading. The Housebuilder extensions hosted here do work just fine in current versions of SketchUp.
                                      Speaking of current versions of SketchUp, which one are you using. Your profile indicates SketchUp 2019 Free/Make but that couldn't be since there is no SketchUp 2019 Make.
                                        dannygerhard17
                                        My mistake I typed the wrong version I am using Sketch up 2017
                                          How about updating your profile so it is correct? Update it on the SketchUp forum, too.
                                            LetsSee
                                            @ckizer said:
                                            Unfortunately the only version hosted here that worked is metric version.
                                            Time to adapt. to. metric. system. ๐Ÿ’š
                                            Note that I didn't say to learn: There's nothing to learn about metric system: it's intuitive. Hence why our two-year old could already use it. Try that with the imperial system. ๐Ÿ˜ฎ
                                            It's really JUST your habit. that. stops. you.
                                            @ckizer said:
                                            I'm trying to design a house in the US, so this won't work.
                                            How much proof do you need that even. US. houses. can. be. designed. and. built. per. metric system. ๐Ÿ’š
                                            No offense, just funny.
                                            • 7 / 8
