    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.3k Posts 587 Posters 10.9m Views 589 Watching
    • fredo6F
      NEW RELEASE: LibFredo6 v8.7m - 15 Feb 19
      LibFredo6 8.7m fixes various bugs and aligns the release reference (misaligned with previous v8.7k)
      • fredo6F
        NEW RELEASE: LibFredo6 v8.8a - 24 Feb 19
        LibFredo6 8.8a fixes various bugs and is required for Curvizard v2.4a (Circle, Arc, Polygon)
        • G
          Gordy_Z
          Sketchucation Folk,
          Sorry to be dense. I'd like to update LibFredo6 but after reading the documentation, watching a video on installation, and doing a search in Sketchucation, I keep coming up with intall instructions. https://sketchucation.com/plugin/903-libfredo6definitely definitely says "It must be installed ONCE and updated as needed..." I think this makes sense as I believe I read somewhere that having old LibFredo folders/files around can cause problems.
          Of course I know to check FOR updates - that's how I know I need one. But the only clickable link in the resulting window is "Info" and it takes me to the installation page noted above that says to ONLY install once, then use an update process from then on. Please inform me of this update process. Again, apologies if I'm missing something obvious.
          Thanks,
          Gordy_Z
            Go to...
            https://sketchucation.com/pluginstore
            Search for Lib_Fredo6...
            Download its RBZ and install it in SketchUp like any other archive...
            • G
              Gordy_Z
              Thanks, got thrown by the "must be installed ONCE."
              The Sketchucation Extension Store I've installed in SU is simply the automated way to download an RBZ archive and install it, correct?
                Yes that's OK.
                The ExtensionStore from SketchUcation Tools is just a simplified method, so the PluginStore entry can be auto-installed without the need for you to download any RBZ files.
                Some people like to have the actual RBZ file for their archives, but the way the ExtensionStore is set up is intended to make life as simple as it can be...
                • fredo6F
                  Actually the process of installing for the first time and updating is technical similar, as you
                  • download the RBZ file
                  • install this RBZ file as an extension Sketchup (via the Sketchup Extension manager)
                  Simply, as TIG says, if you manage your extensions with the Sketchucation ExtensionStore, the update is a simple click in the Extension manager of the Sketchucation tool.
                  I modified the page to state that "installed once" is related to "all my extensions", as LibFredo6 is shared by all my extensions precisely.
                    mrkidd
                    No matter which way I try to install the latest version of LibFredo6 into SU 2019, I get on error message that it's installed incorrectly, that the sub-folder is missing.
                    Any suggestions?
                      Please post the actual message's text.
                      That way Fredo can see which folder is causing issues...
                      • L
                        lyn_z_la_vie
                        I just installed Lib Fredo6 v8.8a and then installed Roundcorner. Lib Fredo6 v8.a seems to be installed and Roundcorner is working fine. However, I then installed FredoScale and I cannot get it to work. When I start Sketchup it gives me a pop up message which says 'You must install LibFredo6 version 6.9 or higher to run Fredo_6 FredoScale'. But it seems I have the most up to date version of LibFredo 6. Is there something I am missing? Thanks.
                        • fredo6F
                          You must have an old version of FredoScale (or some old files left in your plugin directory).
                          I suggest you do a cleanup and reinstall FredoScale.
                          • C
                            chenamy1997
                            when using curviloft i got an information saying contours cannot be interpreted correctly. i have some images but i don't know how to upload here,would you mind if can communicate via email?
                            amy
                              You managed to attach one image.
                              Attaching more images or a SKP is much the same process, using the 'Upload attachment' tab...
                                sophieo44
                                Hello,
                                On the 2019 version, I was able to install the Curviloft plugins, frontface and toposhaper out for 1 month, when opening Sketchup now I have this message:
                                Error loading Fredo6_FredoScale file / __ loader__FredoScale
                                Could not find included file 'Fredo6_FredoScale / __ loader__FredoScale'
                                Error loading Fredo6_RoundCorner / __ loader__RoundCorner file
                                Could not find included file 'Fredo6_RoundCorner / __ loader__RoundCorner'
                                Error loading Fredo6_TopoShaper / __ loader__TopoShaper file
                                Could not find included file 'Fredo6_TopoShaper / __ loader__TopoShaper'
                                Since I uninstalled them and I can not install them, an error message also appears: "Error: Invalid component file"
                                I would like to reuse them do you have a solution to bring me?
                                Regards,
                                • fredo6F
                                  @sophieo44
                                  I think there is something wrong in your Plugin directory.
                                  I would suggest you check the footprint of extensions (normally, one .rb file and one folder).
                                    dtrachtman
                                    I installed LibFredo6 v8.8a and then Fredo6 FredoScale but in the Extension manager it says "Signature Outdated" and I don't see FredoScale anywhere in Sketchup. What am I missing?
                                      Did you restart SketchUp after the installations ?
                                      For me the Lib and ALL of Fredo's Extensions report as being 'signed'...
                                      And of course their various menu entries and toolbars appear where they should be...
                                      • fredo6F
                                        NEW RELEASE: LibFredo6 v8.9b - 06 Jun 19
                                        LibFredo6 8.9b fixes various bugs and is required for my new plugin FredoGhost 1.2a
                                        • BrillanteB
                                          Brillante
                                          Bonjour Fredo
                                          serait il possible de faire qq modifications dans la liste des calques,
                                          je m'explique
                                          il faudrait rajouter une colonne solo, pour mettre le calque seul visible à l'ecra en masquant tous les autres.
                                          Et un petit voyant devant chaques calques pour signaler si il est vide ou pas.
                                          Peut etre que cette option existe déjà? si oui fais moi signe, si non à voir.
                                          L'idéal serait un plug in pour chaque version
                                          RnR
                                          Vincent
                                          • fredo6F
                                            @brillante said:
                                            Bonjour Fredo
                                            There already exists several plugins that provide additional fonctionality with layers.
                                            • Layer Organizer, by LawArchitects
                                            • Layer Planel by Lindale
                                            • SU4U Layers [$], by Suforyou
                                            • Layer Manager, by Didier Bur
                                            There are also some on EWH (by Eneroth3 for instance)
                                            • 69
                                            • 70
                                            • 71
                                            • 72
                                            • 73
                                            • 113
                                            • 114
                                            • 71 / 114
