    [Plugin Library] LibFredo6 - v16.3a - 20 Oct 26
    2.3k Posts 587 Posters 12.0m Views 589 Watching
      No need to uninstall the earlier version[s].
      The new installation will overwrite any equivalent files/version etc as needed.
      But you should restart SketchUp after finishing the installation[s] to ensure everything gets synced...
      • guanjinG
        guanjin
        cannot be set in sketchup2015, all Chinese is empty.
        • fredo6F
          Can you be more explicit for the problem.
          I do have the Chinese in SU2015
          • guanjinG
            guanjin
            [attachment=1:18r21dr6]<!-- ia1 -->LibFredo6 - plugins load chinese.png<!-- ia1 -->[/attachment:18r21dr6]
            [attachment=0:18r21dr6]<!-- ia0 -->LibFredo6 - About Chinese.png<!-- ia0 -->[/attachment:18r21dr6]
            Found that your version is 8.7h, I installed 8.7f
            • fredo6F
              v8.7f is the latest release. v8.7h is an internal release on my own laptop.
              • fredo6F
                • fredo6F
                  NEW RELEASE: LibFredo6 v8.7k - 14 Feb 19
                  LibFredo6 8.7k fixes various bugs and the accuracy of the hand cursor over button palettes
                  • P
                    Puco
                    Hi Fredo one question, I installed SU 2019 and the first thing that I freshly install is LibFredo6-v8.7K but when I go to Windows/LibFredo6Settings/Check for updates it gives info that 8.7j is actually installed and needs an update to 8.7k... I tried everything to fix this, fresh install and everything and after several attempts to install 8.7k, it gives a result as if I have installed 8.7j and needs an update. Any help?
                      You must restart SketchUp to ensure the latest installed version is loaded.
                      But if the issue continues after that, then come back...
                      • P
                        Puco
                        Did restart SketchUp, and my pc to be entirely sure that everything is set correctly, but no luck, 8.7j is installed instead of 8.7k. Checked the download folder if I accidentally have the wrong version downloaded, but no, everything is ok, 8.7 K is what I have downloaded and installed, and yet, SketchUp even upon restart of the program and pc says that I need to actually update to 8.7 k 😞
                        • fredo6F
                          This is my own error in the parameterization of the release. You definitely have the good version. So don't worry.
                          • P
                            Puco
                            Thank you for the quick response to this concern. As long as you are saying that it is just some minor issue regardless the version number only, I won't be supper paranoic to cry for the same issue πŸ˜„ all over again, except this time it gives like I have version 8.7 L installed and need to update to 8.7 M ... I will avoid that notification that I don't have the latest version, as long as you said already that is just a parametrization, not the actual extension/plugin problem! Thank you once again!
                            • fredo6F
                              NEW RELEASE: LibFredo6 v8.7m - 15 Feb 19
                              LibFredo6 8.7m fixes various bugs and aligns the release reference (misaligned with previous v8.7k)
                              • fredo6F
                                NEW RELEASE: LibFredo6 v8.8a - 24 Feb 19
                                LibFredo6 8.8a fixes various bugs and is required for Curvizard v2.4a (Circle, Arc, Polygon)
                                • G
                                  Gordy_Z
                                  Sketchucation Folk,
                                  Sorry to be dense. I'd like to update LibFredo6 but after reading the documentation, watching a video on installation, and doing a search in Sketchucation, I keep coming up with intall instructions. https://sketchucation.com/plugin/903-libfredo6definitely definitely says "It must be installed ONCE and updated as needed..." I think this makes sense as I believe I read somewhere that having old LibFredo folders/files around can cause problems.
                                  Of course I know to check FOR updates - that's how I know I need one. But the only clickable link in the resulting window is "Info" and it takes me to the installation page noted above that says to ONLY install once, then use an update process from then on. Please inform me of this update process. Again, apologies if I'm missing something obvious.
                                  Thanks,
                                  Gordy_Z
                                    Go to...
                                    https://sketchucation.com/pluginstore
                                    Search for Lib_Fredo6...
                                    Download its RBZ and install it in SketchUp like any other archive...
                                    • G
                                      Gordy_Z
                                      Thanks, got thrown by the "must be installed ONCE."
                                      The Sketchucation Extension Store I've installed in SU is simply the automated way to download an RBZ archive and install it, correct?
                                        Yes that's OK.
                                        The ExtensionStore from SketchUcation Tools is just a simplified method, so the PluginStore entry can be auto-installed without the need for you to download any RBZ files.
                                        Some people like to have the actual RBZ file for their archives, but the way the ExtensionStore is set up is intended to make life as simple as it can be...
                                        • fredo6F
                                          Actually the process of installing for the first time and updating is technical similar, as you
                                          • download the RBZ file
                                          • install this RBZ file as an extension Sketchup (via the Sketchup Extension manager)
                                          Simply, as TIG says, if you manage your extensions with the Sketchucation ExtensionStore, the update is a simple click in the Extension manager of the Sketchucation tool.
                                          I modified the page to state that "installed once" is related to "all my extensions", as LibFredo6 is shared by all my extensions precisely.
                                            mrkidd
                                            No matter which way I try to install the latest version of LibFredo6 into SU 2019, I get on error message that it's installed incorrectly, that the sub-folder is missing.
                                            Any suggestions?
                                            • 69
                                            • 70
                                            • 71
                                            • 72
                                            • 73
                                            • 113
                                            • 114
                                            • 71 / 114
