    ClothWorks License broke - deadline tomorrow!
    extensions
    39 Posts 14 Posters 27.1k Views 14 Watching
    • jujuJ Offline
      juju
      Which version are you using?
      • Windows
      • SketchUp
      • Clothworks
        corneydj
        I'm using the following:
        Mac OS 10.13.5
        SketchUp Pro 2018 18.0.16976
        Clothworks 1.1.1
        • jujuJ Offline
          juju
          @corneydj said:
          Mac OS 10.13.5
          Clothworks 1.1.1
          You need to update your profile here.
          Any accent / special characters in your username (on your machine)?
          Else it may be with the licencing system, IIRC Clothworks utilizes the SketchUcation licencing system. do you have the latest of these installed?
          Which other extensions / plugins do you have installed? Do you experience any problems there?
            corneydj
            @juju said:
            @corneydj said:
            Mac OS 10.13.5
            Clothworks 1.1.1
            Profile updated
            There is a '.' in my username. Would that cause an issue? Not sure if I can change it as this is a work computer.
            My SketchUcation is v3.1.5
            I have many other extensions/plugins installed (my tool pallet is huge!) - no problems with any of them.
              Anton_S
              Hello corneydj,
              That is an interesting case. This may be an issue with SketchUcation licensing on particular configurations of Mac OS X. I sent you a private message regarding this.
              Best regards,
              Anton
                corneydj
                @anton_s said:
                Hello corneydj,
                Best regards,
                Anton
                Hey Anton,
                I tried replying to your PM but the website says you don't accept them. Response below:
                Yeah sure - if you think that will help. The funny thing is is that I have 2 seats currently activated - one on my personal computer and one on my work computer - both machines are Mac laptops running the same version of Mac OS, SketchUp, SketchUcation & Clothworks, but only one is having licensing issues. When I look up the licensing details on my personal computer it reports all as ok with the proper seats being activated (2 of 3), but my work computer says it is unlicensed & when I direct it to my license file it gives me that error message (but then randomly the other day it decided that it was licensed after all? It's broken again since)
                If you think what you suggested will help go ahead & I'll let you know what happens; otherwise we can try the second option.
                Can you explain what the "msg_validation_error Request to Sketchucation = ERROR_A0C" means? Is it saying my computer is unable to contact the SketchUcation servers for validation?
                  Anton_S
                  Corneydj,
                  I updated my private messaging option. My apologies.
                  According to Gábor, the ERROR_A0C error message is thrown when the hostname of the computer does not match the hostname stored in the SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt file. Erasing the file from the folder where the licensing info is stored might help with addressing issue.
                  I have reset your licence at the server side. Now, you will have to erase the signature file and reactivate your licence. Please refer to ClothWorks Licensing Manual page 4, Known Issue issue section, for resetting your licence: https://drive.google.com/open?id=1QLzrBm5Qy7ZQh56HNqRl_LjqxNhgd9dO
                  If that doesn't work, I will send you a private message regarding the second option.
                  Best regards,
                  Anton
                    corneydj
                    @anton_s said:
                    Corneydj,
                    Best regards,
                    Anton
                    Cool! That seems to have fixed it for now - thanks 😄 I'll keep an eye on it though & if it breaks again I'll message you.
                    Thanks for the help!
                      tsalinas
                      Dear friends,
                      I have just experienced the same error:
                      I am using the following:
                      Mac OS 10.14.3
                      SketchUp Pro 2019
                      Clothworks 1.5.2a
                      Please help, I need this plugin working ASAP.
                      Thank you,
                        Gábor
                        Probably the fastest solution for the problem is the same: Find on your computer the SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt file and erase it. It should help to solve the problem.
                          Have you also downloaded and installed the latest version of the SketchUcation-Toolset ?
                          It's needed for SCF-license compatibility with v2019.
                          Get v3.1.8 here:
                          https://sketchucation.com/pluginstore?pln=SketchUcationTools
                          Not having done so might be a factor ?
                          Note that you do need an internet connection, but just for the initial setup of the license details...
                            tsalinas
                            @tsalinas said:
                            @gábor said:
                            Thank you. It actually worked for me as well.
                            My only concern now is that, according to Clothworks licence validation system, I have reached 3 installations. It is not true. I have 2 active installations (2 different computers). This is not an issue right now, but I'm afraid having the same licencing trouble in the future may prevent me to validate the plugin (once again).
                            Thank you anyways.
                              Gábor
                              I've released 2 seats of your license at server-side. I hope it allays your concern.
                                Thanju
                                Same error
                                But i cannot locate the file on Macbook Pro, Mac OS Mojave, Sketchup Pro 2019
                                  Gábor
                                  @thanju said:
                                  Same error
                                  In case of windows it is at C:\Users\username\AppData\Local\SCF Licenses\SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt so in case of MAC it should be somewhere under ~/Library/Application Support I suppose but I do not have a MAC so it would be nice if a MAC user could conform it.
                                    Thanju
                                    @gábor said:
                                    @thanju said:
                                    Same error
                                    I eventually found it on a Mac as follows;
                                    On sketchup go to Extensions/Clothworks/License/History/License file location
                                      thabault
                                      @tsalinas said:
                                      @tsalinas said:
                                      @gábor said:
                                      Thank you anyways.
                                      hello
                                      I had the same trouble with my licence. I fixed it when i erase the file SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt but now the number of seats is wrong. I use one and the licence say I use 2....
                                      Can you help me please?
                                      Thanks a lot
                                      Vanina
                                        Anton_S
                                        Hello Vanina,
                                        I reset your license seats at the server side. If you click on the Seats... button, within the licensing dialog, the correct value should be reflected. If not, delete the SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt and activate the license again.
                                        Thank you,
                                        Anton
                                          Thanju
                                          @anton_s said:
                                          Hello Vanina,
                                          Thank you,
                                          Anton
                                          I am not able to delete DO NOT MODIFY OR DELETE.txt simply because the 'Open File Location' tab no longer works. I click on it and it no longer shows the File Location.
                                          How do I locate the text files on a Mac?
                                            Anton_S
                                            Thank you for the report. The License File Location... does not work on my Mac OS X 10.13 either.
                                            In the meantime, you can find the DO NOT MODIFY OR DELETE.txt files at
                                            /Users/YOUR_NAME/Library/Application Support/SCF Licenses
                                            To access this path, open Finder and from the menu, access (Menu) Go > Go to Folder.... Paste the path above, replacing YOUR_NAME with your account user name, and you will be navigated to the folder.
