    Rendered Walkthrough
    renderpluginsextensions
    39 Posts 8 Posters 15.1k Views 8 Watching
    • V
      valerostudio
      @dprince said:
      I would still like to know how to do the walk through using vray. no matter how long it takes to render
      VRay will render animation based on SketchUp scene tabs. For example I would make a scene tab for point A of my walkthrough, then one for point B, point C, etc.
      Setup your animation settings in model info with Scene delay off and a reasonable amount of time for the transitions, so the speed is the way you like it.
      Render using VRay with animation enabled and saving to a folder. VRay will save each frame out. Then use an application to combine the frames into a video file. I bet there are a bunch of free ones. Photoshop will also do this now.
      There are plugins that can make the walkthrough smoother and with animation (doors open for example) but that becomes more complex, and you have to make sure its VRay compatible, but the procedure above is the fastest way to get up and running (pun intended).
      Smustard had some nice path animation plugins a long time ago. I am not sure if they still work. Worth a shot.
        Dprince
        What settings should i have for Vray animation or better yet are should the settings be? im using vray 3.4
        • andybotA
          andybot
          The settings I would recommend are having a powerful CPU or using a render-farm.
          • PixeroP
            Pixero
            Several years ago I rendered a animation with Vray 1.5 on one PC.
            I believe rendering took 4-5 weeks 24/7.
            I would NOT do it like that again. πŸ˜†
            With Enscape I rendered a 4 minutes animation in less than an hour.
              Dprince
              my machine cant run enscape . each time i try it crashes
              • andybotA
                andybot
                If you're serious about rendering an animation with V-Ray, I would highly recommend looking at render farms, there are quite a few options out there.
                • soloS
                  You said in a PM you had $1600 to spend on a new laptop, this will get it done:
                  Amazon.com
                  (www.amazon.com)
                    Dprince
                    Can you send me some examples please? Thanks
                      Dprince
                      Amazon.com
                      (www.amazon.com)
                      I was looking at this also ASUS ROG STRIX Hero Edition Gaming Laptop, https://www.amazon.com/dp/B076D95JW7/ref=cm_sw_r_cp_api_i_2m6KCb2GCA8BM
                      • soloS
                        Amazon.com
                        (www.amazon.com)
                        Considering you are usimg Vray 3.4 I assume you are not using GPU rendering, so the alienware will have more cores than the ASUS, both will work great for Enscape however
                        • andybotA
                          andybot
                          Here's a list from Chaos Group: https://www.chaosgroup.com/render-farms (not all of these have SU+V-Ray support, but if you narrow the list to just SU, it misses farms like Rebus)
                          And they have their own cloud: https://www.chaosgroup.com/cloud (I haven't used it so I couldn't speak to how it compares.)
                            Dprince
                            Thanks.
                            what do u guys think about these specs thinking about building a desktop computer
                            CPU: AMD – Ryzen 5 1600 3.2GHz 6-Core Processor
                            CPU-Cooler: Already included with CPU
                            Motherboard: MSI – B350 PC MATE ATX AM4 Motherboard
                            Memory: Corsair – Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory
                            Storage: Samsung – 860 Evo 500GB 2.5β€³ Solid State Drive
                            GPU: MSI – GeForce GTX 1060 2GB Video Card
                            Case: Deepcool – DUKASE WHV2 ATX Mid Tower Case
                            Power Supply: Corsair – CX 500W 80+ Bronze Certified Semi-Modular ATX
                            • andybotA
                              andybot
                              Looks good. Now you can render a V-Ray animation in one week instead of four.
                                Dprince
                                lol. I plan on using enscape for walkthroughs/animation
                                • soloS
                                  In that case I'd suggest a GPU with much more ram, 2gb is very little
                                  • andybotA
                                    andybot
                                    Smart plan! I have a pair of GTX 1070's and they're working great with Enscape.
                                    Also, at 8GB memory. Like Solo says, gotta have enough memory.
                                      Dprince
                                      Thanks for the suggestion champ
                                        Dprince
                                        I was thinking about getting the Nvidia GTX 1060 8gb
                                        • V
                                          valerostudio
                                          VRay cloud is very nicely integrated and easy to use but I thought that I read that you can find cheaper farms out there. The price tag of Enscape will pay for itself with one animation job. Not pushing Enscape down your throat but we have all been there with V-Ray and Enscape is just damn fast and easy.
                                            rspierenburg
                                            I know it might be a little more involved but Unity might be a good option as well.
                                            • 2 / 2
