    Smit Panther ASD Tug
    58 Posts 18 Posters 36.9k Views 18 Watching
    • tuna1957T Offline
      tuna1957
      The level of detail is just mind altering ! πŸ‘ πŸ‘
      • axeonaliasA Offline
        axeonalias
        Thanks guys, really enjoying this project!
        Bridge frames, Starboard bridge entrance, maindeck windows, bell and bow hatches ad Stern deck port fittings arranged as they should be ( not mirrored ).
        Railings, top deck fittings and mast coming soon!
        https://www.dropbox.com/s/833fn8uqfj5v5s5/55.jpg?raw=1
        https://www.dropbox.com/s/ah9bmgopxz1wxjg/56.jpg?raw=1
        https://www.dropbox.com/s/gelkuqd2c5k0z27/57.jpg?raw=1
        https://www.dropbox.com/s/hq06okjvt8577rv/58.jpg?raw=1
        https://www.dropbox.com/s/kmfmy6ca3pqbcwt/59.jpg?raw=1
        Currently 89 Hours 04 Minutes in
        https://sketchfab.com/Axeonalias
        • tuna1957T Offline
          tuna1957
          speechless..... πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘
            axeonalias
            Alot has been changed over the years ive noticed, many things were added everywhere it seems, keeps this project challenging! Bridge Deck Railings took much longer than I thought, sprinklers and lights are there as well, you will see pretty big differences between the 2 sides of the bridge and that aft platform also was added later. Nearing the 100 Hour Mark!
            Exterior will be done soon then I can get cracking on the interior!
            https://www.dropbox.com/s/x69bw84lbtcmp3b/60.jpg?raw=1
            https://www.dropbox.com/s/vml2onzvz7axphh/61.jpg?raw=1
            https://www.dropbox.com/s/ld9y4qug7spzaki/62.jpg?raw=1
            Currently 98 Hours 32 Minutes in
              db11
              Insanely impressive!
                axeonalias
                I thought this roof would take a hour or two and I could move on, well well Surprise! How much equipment can you cram into that tiny space! look no further!
                The Top Deck is pretty much done, moving on to the mast next.
                https://www.dropbox.com/s/fb04xohdvyxi11o/63.jpg?raw=1
                https://www.dropbox.com/s/toa902j3hro74wm/64.jpg?raw=1
                https://www.dropbox.com/s/lzqak7xlhjy8vdg/65.jpg?raw=1
                Currently 106 Hours 32 Minutes in
                • Bryan KB Offline
                  Superb work.
                  Where do you get your references?
                  Also, how did you create the hull?
                    axeonalias
                    Thanks Bryan, its an interesting process that ive tried to explain as best I could here:
                    https://sketchfab.com/blogs/community/art-spotlight-trawler-sea-lady/
                    I can give you a specific rundown on this hull if needed?
                      "I can give you a specific rundown on this hull if needed"?
                      That would be really cool and helpful.
                        axeonalias
                        Step 1: Gathering info
                        https://www.dropbox.com/s/7u6tb1wfy7a8p4w/Hull1.jpg?raw=1
                        So step 1 is to be sure you have decent drawings (Side View and Front view is a must, top view is a bonus), rib plans are always the best but in the case I had a fairly simple hull with enough information on the drawings to create it, of course go searching for the images of the real ship out the water if you can find any!
                        Step 2: Subdiv Mesh
                        https://www.dropbox.com/s/ha2i1ulccsshtu7/Hull2.jpg?raw=1
                        Creating the subdiv mesh is always fun, in this case I hard a few hard chine lines to deal with so I was sure to mark them out, I should have added the keel in at this stage, it would have made for a better looking mesh but with higher poly count for no reason apart from a better looking mesh.
                        https://www.dropbox.com/s/g7ae1sd52xfaafr/Hull3.jpg?raw=1
                        Step 3. Seperating mesh for smoothing
                        https://www.dropbox.com/s/zyiotevz5jpw2tl/Hull4.jpg?raw=1
                        This step is really quite dependent on the type of hull you are creating, a wooden ship for instance will not need this, to preserve the hard chine when smoothing is applied, I separate the meshs in their smoothing groups so that when it goes to blender for mapping and smoothing, it wont smoothen out the areas near the bow and stern that have less than a 35Β° angle. the tradeoff with this method is you will have separated areas on the UV for something that is essentially joined.
                        Hope this helps!
                          axeonalias
                          The Exterior for the most part is complete, the text will probably be removed later and replaced with textures, the Poly count currently is at 438k
                          https://www.dropbox.com/s/zbe35uwp7jn32l0/66.jpg?raw=1
                          https://www.dropbox.com/s/8ttim7nr54w4eia/67.jpg?raw=1
                          https://www.dropbox.com/s/ngx0q1sb66bqgae/68.jpg?raw=1
                          https://www.dropbox.com/s/939e9cgox1p2ukp/69.jpg?raw=1
                          https://www.dropbox.com/s/ryltgrcxns5rsaj/70.jpg?raw=1
                          Currently 110 Hours 46 Minutes in
                            Thanks very much for the TUT, looking fantastic.
                            • DanielD Offline
                              Daniel
                              I'm blown away by your modeling. And inspired. Hardly touched SU in two years, but I'm starting to get the itch again.
                              My avatar is an anachronism.
                              • Bryan KB Offline
                                Thanks axeonalias.
                                That was a good explanation of your hull modeling.
                                When you subdivide and smooth, what are you using?
                                  axeonalias
                                  Alright I dragged my feet abit with this one, but shes finally done, the lack of accurate info for the interior left me demotivated, but after the birth of my first son I decided, I better get this one out while he is asleep!, it still took another 3 weeks to complete the exterior but im happy with the result, im going to fiddle with getting it into VSF but I have my doubts, she has 53 separate 4k textures ( made up of Diffuse, AO, Rough, Metallic, Spec and normals ) so I have my doubts that VSF will be able to render her correctly
                                  If you want to have a look at her in 3d, heres the link : https://skfb.ly/6WAyG
                                  Sorry for the oversize images, just zoom out with your browser to 75% and you will see the whole image.
                                  https://live.staticflickr.com/65535/50625353491_a87120cb75_k.jpg
                                  71R by mariusmoolman, on Flickr
                                  https://live.staticflickr.com/65535/50624605458_deed8595c0_h.jpg
                                  72R by mariusmoolman, on Flickr
                                  https://live.staticflickr.com/65535/50625352646_e101d933fd_h.jpg
                                  73R by mariusmoolman, on Flickr
                                  https://live.staticflickr.com/65535/50624604533_a1b5fef404_h.jpg
                                  74R by mariusmoolman, on Flickr
                                  https://live.staticflickr.com/65535/50625351851_952bfa1447_h.jpg
                                  75R by mariusmoolman, on Flickr
                                  https://live.staticflickr.com/65535/50625351271_b3acd50715_k.jpg
                                  76R by mariusmoolman, on Flickr
                                  https://live.staticflickr.com/65535/50624602993_c92185557d_h.jpg
                                  77 by mariusmoolman, on Flickr
                                  [url=https://flic.kr/p/2k8A9Xj:1m0fwj62]
                                  https://live.staticflickr.com/65535/50625350536_4956bb8a7a_h.jpg
                                  [/url:1m0fwj62][url=https://flic.kr/p/2k8A9Xj:1m0fwj62]78[/url:1m0fwj62] by mariusmoolman, on Flickr
                                  [url=https://flic.kr/p/2k8A9Rx:1m0fwj62]
                                  https://live.staticflickr.com/65535/50625350201_434f15b5fb_k.jpg
                                  [/url:1m0fwj62][url=https://flic.kr/p/2k8A9Rx:1m0fwj62]79[/url:1m0fwj62] by mariusmoolman, on Flickr
                                  [url=https://flic.kr/p/2k8wjrz:1m0fwj62]
                                  https://live.staticflickr.com/65535/50624602003_13f354badb_k.jpg
                                  [/url:1m0fwj62][url=https://flic.kr/p/2k8wjrz:1m0fwj62]80[/url:1m0fwj62] by mariusmoolman, on Flickr
                                  [url=https://flic.kr/p/2k8AEfZ:1m0fwj62]
                                  https://live.staticflickr.com/65535/50625449117_fbcf1414f1_h.jpg
                                  [/url:1m0fwj62][url=https://flic.kr/p/2k8AEfZ:1m0fwj62]81[/url:1m0fwj62] by mariusmoolman, on Flickr
                                  • tuna1957T Offline
                                    tuna1957
                                    Brilliant ! Bravo πŸ‘
                                      Completely marvelous and a great inspiration. πŸ‘Š
                                      • Bryan KB Offline
                                        As professional as it gets. πŸ‘
                                        No game, movie or engineering company could do better.
                                        • HornOxxH Offline
                                          HornOxx
                                          ... do we have a "SketchUp Hall of Fame" somewhere here ? πŸ˜„
                                          never trust a skinny cook
                                          • duanekempD Offline
                                            duanekemp
                                            What a great project and well executed. Love the details. Bravo.
                                            Duane Kemp
                                            Kemp Productions
                                            Puidoux, Switzerland
                                            Gallery:
                                            https://duanekemp.artstation.com/
                                            • 2 / 3
