    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 769.0k Views 175 Watching
      rilian
      I ran into an issue w/ the lathe tool. Seems sometimes it doesn't put the starting and ending faces on the lathed object. Pics attached. The face created consists of 2 edges and 1 arc. I've tried making them all curves and even welding them all into one big arc to no avail. The fix is simple. I'm ok w/ it but thought I'd bring it up.
      Thanks Tig for all the great tools you've made and maintained over the years! Your work is heartily appreciated!! πŸ‘
      [edit] Using SU Make 2017 for Windows
      shows mesh before create. Vertical line is chosen axis of rotation
      Shows mesh post-create
      Shows fixed mesh and lines that had to be added to fix it.
      • E Offline
        Einstein
        Hi!
        Your tool always asks a lot of questions and honestly, it takes time to answer them. What about some dialog box to set default parameters for each sub-tool, like Fredo does, and do not prompting questions every time after making an extrusion?
        • Didier BurD Offline
          Didier Bur
          If it takes you time to answer several question, ask yourself how many hours TIG spent writing this plugin, or draw your extrusion by hand, you surely will go faster πŸ˜‰
          DB
            Maybe TIG could release a commercial version that offers some user set parameters instead of the way the free version works.
            • E Offline
              Einstein
              Sometimes I have to create a lot of extrusions in the row and speed matters then.
              He surely devoted a lot of time to that but isn't it the aim of programming to make things as fast as possible?
              And yes, I'd gladly pay for a version that works smooth with SU 17 and has ability to set default params πŸ˜„ If only TIG would like to go commercial.
              • F Offline
                Fillister
                Very sorry to say SketchUp 2019 appears to have caused a conflict. These messages did not appear with 2018.
                Error Loading File C:/.../SketchUp/SketchUp 2019/SketchUp/Plugins/ExtrudeTools/ExtrudeToolsLoader.rb
                Error: #<SyntaxError: C:/.../SketchUp/SketchUp 2019/SketchUp/Plugins/ExtrudeTools/ExtrudeToolsLoader.rb:33: Invalid return in class/module body
                return nil if noPlugin ### we've go...
                C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in load'
                C:/.../SketchUp/SketchUp 2019/SketchUp/Plugins/ExtrudeTools.rb:67:in register_extension' C:/.../SketchUp/SketchUp 2019/SketchUp/Plugins/ExtrudeTools.rb:67:in module:ExtrudeTools'
                C:/.../SketchUp/SketchUp 2019/SketchUp/Plugins/ExtrudeTools.rb:24:in `<top (required)>'
                Other TIG plugins seem to be fine: Lattice Maker, Mirror, Split tools, TIG Weld
                Your time and abilities are so valuable. I hope you can find some way to look into this.
                • TIGT Online
                  I have a fix for this.
                  I'll publish an update soonest...
                  • TIGT Online
                    https://sketchucation.com/pluginstore?pln=ExtrudeTools
                    Version 5.0 fixes the v2019 incompatibility.
                    However, please note that the ExtrudeEdgesbyFace tool no longer loads, this is because it crashes in v2019, and was already known to be flaky in the more recent SketchUp versions anyway ! Safest to skip it completely...
                    I have been looking for a workaround [I must admit with little success], but if I can get that tool de-flaked then I'll re-update things back to the full set of 11...
                    • BoxB Offline
                      Thanks Tig, that has been stopping me from moving to 2019 full time.
                      • N Offline
                        notapoireau
                        Just installed today, and pleased to see that is translated in french.
                        Unfortunately, the plugin palette doesn't appear, and I don't know to get it visible.
                        Then, the first test is not good; certainely do I need to see one more time the video tutorial
                        • TIGT Online
                          I assume you mean the toolset's 'Toolbar'.
                          On a MAC 'Toolbars' are activated from the .... View > Tool Palettes menu item...
                          • X Offline
                            xandra22
                            Hi TIG,
                            Your Extrudetools-Full set is excellent, but I find that there only 10 tools, single Section Lofting is not included,could you please add that into the Extrudetools-Full set.Then the plugin would be more pefect.
                            Thanks.
                            Best Regards.
                            Xandra
                            • TIGT Online
                              As I explained in the recent post https://sketchucation.com/forums/viewtopic.php?p=645437#p645437 it was removed because of issues with v2019...
                              Have you looked for alternatives - I think there might be some around...
                                tengel07
                                Buggy as usual: Does not work on my System...
                                I try extrude edges by face like on the "demo video" and noting happens...
                                  Give more information about what you are trying to accomplish. Share the SKP file. Are you still using SketchUp 8 as your profile indicates?
                                  • nattapakN Offline
                                    nattapak
                                    Help after install plugin it not show some botton in menu
                                    https://drive.google.com/open?id=113EzBbH7gcpXdKlOl4sHkWx7ad7umls7
                                    And this my
                                    https://drive.google.com/open?id=11SG2HjjJhEJtNNilD0VoFmGOsh3NCDzj
                                    plz help me how i can install full menu ?
                                      Your images are not showing up. Please upload them using Upload Attachment below the reply window.
                                      What version of SketchUp are you using? Is it still SketchUp 8 as indicated in your profile?
                                      • TIGT Online
                                        Here are the missing images...
                                        I expect this relates to this https://sketchucation.com/forums/viewtopic.php?p=645437#p645437
                                        I removed one of the tools because it became incompatible with newer SketchUp versions [and would have needed a complete re-coding], but there are alternatives...
                                          GigaG
                                          Is there an equivalent to something like "Extrude edges by loft to lattice", to make a lattice out of more than 2 cross-sections?
                                            tondaa
                                            Great plugin, great work. Migrated from another, that was with 2020 buggy and like it a lot!
                                            Is there a way how to disable popup prompts (reverse faces and group)?
                                            • 31
                                            • 32
                                            • 4 / 32
