    1.5k Posts 478 Posters 4.3m Views 478 Watching
    • fredo6F
      It seems you may have some restriction (security-based) to create subdirectories in /Users/21imac/Library/Application Support/.LIBFREDO6_DATA_Dir.
      Possibly, this has to do with the mode of your finder, which may require "View Hidden files".
      Can you check.
      Worse case, create the directory manually: /Users/21imac/Library/Application Support/.LIBFREDO6_DATA_Dir.
      Please note that there is a 'dot' before LIBFREDO6_DATA_Dir. On Mac, I think this to make the directory hidden.
      • O
        oyercab
        The directory is there, but it is hidden. I was able to see it by opening Terminal. Now what should I do? (The dot does make it hidden.)
        • fredo6F
          Could you enable the option "view hidden file" in your Finder.
          In the Terminal, type
          defaults write com.apple.finder AppleShowAllFiles YES; killall FINDER
          If it does not work, then it would mean that your Support folder is protected against file creation by program, and then you'll have to find how to allow it via changing some security settings.
          • O
            oyercab
            When I did that, I got this response "No matching processes belonging to you were found."
            But I can see the folder by typing the following two lines, one at a time:
            defaults write com.apple.finder AppleShowAllFiles TRUE
            killall Finder
            What should be inside that hidden folder? It only contains a folder named DefaultParameters,
            which has two files: FredoCorner.def and ROundCorNer.def (spelled just like that)
            Gail
            • fredo6F
              LibFredo6 tries to create a file named "LibFredo6_all_defaults.dat", but apparently it cannot, based on the error that you get in the Ruby console.
              So, this may be related to some security settings.
              In the Ruby console, could you copy and paste the following command and press Enter
              File.open(File.join(LibFredo6.appdata_dir, "LibFredo6_all_defaults.dat"), 'w') { |f| f.puts "###" }
              Do you get an error?
              If so, could you type (same command, but with a .txt extension)
              File.open(File.join(LibFredo6.appdata_dir, "LibFredo6_all_defaults.txt"), 'w') { |f| f.puts "###" }
              • O
                oyercab
                I deleted the hidden folder .LIBFREDO6_DATA_Dir.
                and then uninstalled LibFredo6, FredoCorner and RoundCorner.
                After doing that, when I re-installed LibFredo6, another file showed up below the folder DefaultParameters inside the hidden folder. It wasn't there before.
                Then I re-installed FredoCorner and RoundCorner, and now they are both working!!
                Thank you so much for your help and time, Fredo.
                • fredo6F
                  OK. Strange, but glad it worked. This may be useful to know for other Mac users.
                  • N
                    notapoireau
                    découverte de ce plugin malin, bien que son interface ne rende pas son utilisation des plus pratiques; heureusement la généreuse et très détaillée documentation est là.
                    Par contre, impossible de savoir ce que le plugin considère comme étant une arête invalide. Et si je pose la question, c'est justement parce que sur un modèle simple (un anneau type bague semi ouverte) aucune arête et aucune surface ne peuvent être sélectionnés. Bon c'est vrai que je ne suis pas super à l'aide avec Sketchup, mais j'ai réussi à faire fonctionner ce plugin sur d'autres modèles.
                    Quelque chose m'échappe encore avec Sketchup; une fois de plus!
                    Ring.skp
                    • fredo6F
                      RoundCorner permet de filtrer les arêtes selon leur propriétés (plain, soft, smooth, hidden). En general, on ne considère que les arêtes plain (donc non-soft, non-smooth, non-hidden).
                      Dans la palette de boutons, tu as un filtre qui peut être modifié.
                      Dans ton modèle, utilise l'option pour montrer la géométrie cachée.
                      PS: J'ai publié recemment le plugin FredoCorner qui est un peu plus puissant que RoundCorner.
                      • N
                        notapoireau
                        Merci Fredo pour cette précision.
                        Je n'avais pas perçu cette partie filter des arêtes; bon pas plus succès quelle que soit le Edge Prop. Filter sélectionné, non seulement aucune sélection d'arête n'est possible, mais en plus Sketchup plante (du moins suis-je obligé de "forcer à quitter")
                        Je vais suivre ta suggestion en installant FredCorner, peut être aurais-je plus de succès...
                        ah ben non, décidément quand ça veut pas!
                        Dès que je fais appel au plugin, j'ai un message d'erreur, et il me faut cliquer sur OK une bonne vingtaine de fois pour en sortir. Une fois sortie de ce message d'erreur, même si le contour de la pièce apparait en rouge (donc sélectionné je suppose), je ne parviens pas à arrondir le bord. Je laisse tomber, je le ferai au papier de verre, une fois la pièce imprimée en 3D (je mettrai sans doute moins de temps).
                        Capture d’écran 2019-02-18 à 16.53.43.pdf
                        • N
                          notapoireau
                          Merci Fredo pour cet éclaircissement.
                          Reste que sur le fichier que j'avais joint, quel que soit le type d'arête sélectionné, le plugin ne fonctionne pas; il ne se passe rien, aucun arrondi n'est effectué.
                          Quant à FredoCorner, ce n'est pas mieux, voire pire, puisque dès que le plugin est appelé j'ai un message d'erreur.
                          Bon, je laisse tomber. Pour moi c'est trop compliqué de parvenir à faire fonctionner Sketchup de manière logique et fiable. Je ferai mes arrondis au papier verre, au moins là je suis certain d'y arriver.
                          message d'erreur avec FredoCorner
                          • fredo6F
                            Verifie la valeur de l'offset qui est probablement trop grand.
                            Ouvre RoundCorner ou FredoCorner sans aucune pre-selection
                            Tu peux taper une nouvelle valeur dans la VCB ou en cliquant sur le bouton.
                            • N
                              notapoireau
                              Première tentative: dès le lancement du plugin (roundcorner) Sketchup plante.
                              je relance.
                              Le plugin est activé (roundcorner): je vois en bas à droite Offset: 30mm , 6s
                              https://i77.servimg.com/u/f77/19/58/42/50/offset10.png
                              je change la valeur de 30 par 1: ne change rien, aucune arête sélectionnable.
                              Puis je vois en haut à gauche cette cas qui semble est désignée par VCB;
                              https://i77.servimg.com/u/f77/19/58/42/50/vcb10.png
                              je souhaite donc changer la valeur. impossible; que je mette 10 ou 1, la boite de dialogue demandant de valider le nouveau choix ne cesse de revenir demandant la validation de cette valeur.
                              Bref cela ne marche toujours pas, ou bien ce qui est plus probable c'est moi qui ne sait pas utiliser cela....alors que je suis bien plus à l'aise avec de la toile émeri.
                              • V
                                valid8r
                                Please excuse my inexperience with both Sketchucation and this forum. I am I think replying to a thread when in fact I want to post a new thread for RoundCorner. I can't find a 'new thread' type button so again, my apologies.
                                My Post Title would be: "Help with RoundCorner toolbar size in Sketchup 2016"
                                Problem: I have had Round Corner installed for some time and always struggled with the fact that in my installation, the toolbar (the pop-up window for settings that appears after I select either S
                                harpCorner or say RoundCorner - Bevel) is so small that I can not enter parameters for my roundcorner use. I am able to use the extension, but my problem is with the 'settings window' that appears when I select one of the three main options.
                                Any help or direction on how to properly ask this question (and your patience is appreciated) would be much appreciated.
                                Thank you in advance
                                • fredo6F
                                  @valid8R
                                  You must have a high-resolution screen.
                                  For Sketchup 2016, you have to indicate the scale factor manually.
                                  Go to Window > LibFredo6 Settings > Default Parameters... to display the Default Parameters of LibFredo6.
                                  At the top of the dialog box, you should adjust the value of the field "High Resolution Screen Factor". Probably a factor 2.
                                  Note that this adjustment is automatic for SU2017, SU2018 and SU2019.
                                  • C
                                    caritz
                                    HI i'm working on a youtube channel introducing sketchup extensions in korean language.
                                    Hoping if i and my team can make short films (dur : 1 min) from your works.
                                    Of course we're not selling, will leave all links to your page on the description
                                    we ask any opinion of this
                                    thanks.
                                    ps. The channel is not open yet and we're not gonna proceed without your permission
                                    • fredo6F
                                      thanks.
                                      You have my permission. And thanks for this initiative (and thanks for asking).
                                      Obviously, It will be difficult to review it in your native language 😄
                                      PS: by the way, you may want to have a look at FredoCorner, which is a separate plugin that does the same and a lot more than RoundCorner. The only restriction is that FredoCorner is for SU2016+.
                                      • N
                                        notapoireau
                                        C'est vrai que je ne suis pas un champion de Sketchup, mais j'essaie d'y mettre du mien. Hélas, je vais de déboire en déception.
                                        Dernière tentative en date d’utilisation du plugin roundcorner; tout cela est décidément trop mystérieux pour moi.
                                          Looks to me as if you need to greatly reduce the offset amount to something appropriate to the size of the model.
                                          • HornOxxH
                                            HornOxx
                                            @notapoireau said:
                                            ...tout cela est décidément trop mystérieux pour moi.
                                            😄 😄 Dave is probably right I think, but before all this becomes too mysterious for you 😆 how about to share your shown model here and briefly describe your intention? so we could look what really happens ...
                                            never trust a skinny cook
                                            • 63
                                            • 64
                                            • 65
                                            • 66
                                            • 67
                                            • 74
                                            • 75
                                            • 65 / 75
