    1.5k Posts 478 Posters 4.3m Views 478 Watching
    • fredo6F
      Dave,
      It should be possible in FredoCorner (but more complex in RoundCorner).
      Again, the result is visually different
      • I
        ITman496
        Thank you so much Fredo! My years of suffering are over!
        I can't wait for the update to fredocorner!
        And Dave, I will try 2D tools. Thank you!
        • fredo6F
          I'll publish it later today.
          here is the video
            Wow! Very good.Thank you!
            • fredo6F
              NEW RELEASE: RoundCorner v3.3a - 18 Dec 18
              Requirement: LibFredo6 v8.7a or above
              RoundCorner 3.3a is a maintenance release.
              Home Page of RoundCorner for information and Download.
              Main post of this thread.
              • O
                oyercab
                Hello,
                About two weeks ago I received an error message about RoundCorner when starting Sketchup 2018 Pro. I didn't save the message, and don't know exactly what it said, but RoundCorner was no longer available. I'm on macOS High Sierra (can't upgrade any higher). I updated Fredo6 to the latest version, restarted Sketchup, and then updated RoundCorner and restarted. The toolbar appears, but is completely unresponsive. I also tried installing FredoCorner. Its toolbar has never appeared, but I can put the icons in my main toolbar. It is also unresponsive.
                In the "Fredo6 Collection" under Tools both RoundCorner and FredoCorner are showing, along with their menus, but I can't do anything with them. I've been using RoundCorner for years, and can barely function without it (many thanks, Fredo). Please, somebody help!
                (I did install through Extension Manager in Sketchup).
                Thank you, and hope everybody had a Merry Christmas.
                • fredo6F
                  @oyercab
                  You seem to use Sketchup 8. Can you confirm?
                  Can you open the Ruby Console, and check for error message when you launch RoundCorner.
                  • O
                    oyercab
                    @fredo6 said:
                    @oyercab
                    Hello Fredo, I use SU2018 Pro. I did open Ruby Console, and the LibFredo6 plugin seems to be the problem. I installed the latest version through Extension Manager and followed instructions carefully, closing and re-starting Sketchup before installing RoundCorner. I then closed and re-started before installing FredoCorner. As I said, the toolbars and icons are there, but they don't do anything.
                    This problem started suddenly, after I had been away from the computer for a week. When I launched SketchUp, the error message about RoundCorner was on the screen, and its toolbar had disappeared. I'm going to try deleting and re-installing LibFredo6 again, but have already done that several times. Can I post the Ruby Console info here if I have no luck?
                    • fredo6F
                      @oyercab said:
                      Could you copy - paste the errors you see in the Ruby console.
                      • O
                        oyercab
                        Error: #<Errno::ENOENT: No such file or directory @ rb_sysopen - /Users/21imac/Library/Application Support/.LIBFREDO6_DATA_Dir/LibFredo6_all_defaults.dat>
                        /users/21imac/library/application support/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:144:in initialize' /users/21imac/library/application support/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:144:in open'
                        /users/21imac/library/application support/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:144:in write_to_file' /users/21imac/library/application support/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:127:in store'
                        /users/21imac/library/application support/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1278:in usage_use' /users/21imac/library/application support/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1266:in command_invoke'
                        /users/21imac/library/application support/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1249:in block (2 levels) in build_config_commands' /users/21imac/library/application support/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1348:in call'
                        /users/21imac/library/application support/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1348:in block in add_command' SketchUp:1:in call'
                        • fredo6F
                          It seems you may have some restriction (security-based) to create subdirectories in /Users/21imac/Library/Application Support/.LIBFREDO6_DATA_Dir.
                          Possibly, this has to do with the mode of your finder, which may require "View Hidden files".
                          Can you check.
                          Worse case, create the directory manually: /Users/21imac/Library/Application Support/.LIBFREDO6_DATA_Dir.
                          Please note that there is a 'dot' before LIBFREDO6_DATA_Dir. On Mac, I think this to make the directory hidden.
                          • O
                            oyercab
                            The directory is there, but it is hidden. I was able to see it by opening Terminal. Now what should I do? (The dot does make it hidden.)
                            • fredo6F
                              Could you enable the option "view hidden file" in your Finder.
                              In the Terminal, type
                              defaults write com.apple.finder AppleShowAllFiles YES; killall FINDER
                              If it does not work, then it would mean that your Support folder is protected against file creation by program, and then you'll have to find how to allow it via changing some security settings.
                              • O
                                oyercab
                                When I did that, I got this response "No matching processes belonging to you were found."
                                But I can see the folder by typing the following two lines, one at a time:
                                defaults write com.apple.finder AppleShowAllFiles TRUE
                                killall Finder
                                What should be inside that hidden folder? It only contains a folder named DefaultParameters,
                                which has two files: FredoCorner.def and ROundCorNer.def (spelled just like that)
                                Gail
                                • fredo6F
                                  LibFredo6 tries to create a file named "LibFredo6_all_defaults.dat", but apparently it cannot, based on the error that you get in the Ruby console.
                                  So, this may be related to some security settings.
                                  In the Ruby console, could you copy and paste the following command and press Enter
                                  File.open(File.join(LibFredo6.appdata_dir, "LibFredo6_all_defaults.dat"), 'w') { |f| f.puts "###" }
                                  Do you get an error?
                                  If so, could you type (same command, but with a .txt extension)
                                  File.open(File.join(LibFredo6.appdata_dir, "LibFredo6_all_defaults.txt"), 'w') { |f| f.puts "###" }
                                  • O
                                    oyercab
                                    I deleted the hidden folder .LIBFREDO6_DATA_Dir.
                                    and then uninstalled LibFredo6, FredoCorner and RoundCorner.
                                    After doing that, when I re-installed LibFredo6, another file showed up below the folder DefaultParameters inside the hidden folder. It wasn't there before.
                                    Then I re-installed FredoCorner and RoundCorner, and now they are both working!!
                                    Thank you so much for your help and time, Fredo.
                                    • fredo6F
                                      OK. Strange, but glad it worked. This may be useful to know for other Mac users.
                                      • N
                                        notapoireau
                                        découverte de ce plugin malin, bien que son interface ne rende pas son utilisation des plus pratiques; heureusement la généreuse et très détaillée documentation est là.
                                        Par contre, impossible de savoir ce que le plugin considère comme étant une arête invalide. Et si je pose la question, c'est justement parce que sur un modèle simple (un anneau type bague semi ouverte) aucune arête et aucune surface ne peuvent être sélectionnés. Bon c'est vrai que je ne suis pas super à l'aide avec Sketchup, mais j'ai réussi à faire fonctionner ce plugin sur d'autres modèles.
                                        Quelque chose m'échappe encore avec Sketchup; une fois de plus!
                                        Ring.skp
                                        • fredo6F
                                          RoundCorner permet de filtrer les arêtes selon leur propriétés (plain, soft, smooth, hidden). En general, on ne considère que les arêtes plain (donc non-soft, non-smooth, non-hidden).
                                          Dans la palette de boutons, tu as un filtre qui peut être modifié.
                                          Dans ton modèle, utilise l'option pour montrer la géométrie cachée.
                                          PS: J'ai publié recemment le plugin FredoCorner qui est un peu plus puissant que RoundCorner.
                                          • N
                                            notapoireau
                                            Merci Fredo pour cette précision.
                                            Je n'avais pas perçu cette partie filter des arêtes; bon pas plus succès quelle que soit le Edge Prop. Filter sélectionné, non seulement aucune sélection d'arête n'est possible, mais en plus Sketchup plante (du moins suis-je obligé de "forcer à quitter")
                                            Je vais suivre ta suggestion en installant FredCorner, peut être aurais-je plus de succès...
                                            ah ben non, décidément quand ça veut pas!
                                            Dès que je fais appel au plugin, j'ai un message d'erreur, et il me faut cliquer sur OK une bonne vingtaine de fois pour en sortir. Une fois sortie de ce message d'erreur, même si le contour de la pièce apparait en rouge (donc sélectionné je suppose), je ne parviens pas à arrondir le bord. Je laisse tomber, je le ferai au papier de verre, une fois la pièce imprimée en 3D (je mettrai sans doute moins de temps).
                                            Capture d’écran 2019-02-18 à 16.53.43.pdf
                                            • 63
                                            • 64
                                            • 65
                                            • 66
                                            • 67
                                            • 74
                                            • 75
                                            • 65 / 75
