    1.5k Posts 477 Posters 4.2m Views 477 Watching
      josegara
      Sketchup owes you
      • I
        ITman496
        Hello, I've been a loyal user of this tool for a very long time, great work!
        I've been trying for a long time to get it to sort of.. maintain a radius when rounding a corner. For example, I'm trying to set up a part and calculate pocket cuts of a CNC machine's endmill, when it can't accurately do an interior corner because of the size of the endmill. When I round with say a 1/8" radius, it seems to do a non-circular rounding when doing anything other then 90 degrees. Is there a solution for this? Doing it manually sucks πŸ˜ƒ
        Here is a picture for an example. I want the right's inner bends, but the plugin instead gives me what's on the left.
          I've never noticed that but you're right.
          At least for now you could use TIG's 2D Fillet from his 2D Tools set.
          • fredo6F
            ITman496 made a very relevant observation.
            Indeed this concerns borders where the edge angle is different from 90 degrees.
            In RoundCorner and FredoCorner, the offset is measured perpendicularly to the borders, along their faces.
            As a result, the rounding is not a circle, but it is scaled to be tangent at faces. All pictures below generated with an ofset of 1.5 m and a Circle profile.
            However, there is another possibility, which is to make the rounding so that it matches a circle with a radius equal to the offset value
            This is a matter of choice indeed, so it has to be an option, which I am implementing in FredoCorner.
            Below are the same solid rounded with the two options
            As far as I remember, I discarded the radius mode because it gives border rounding which are visually non uniform. But, the option is valid geometrically, especially if it is to generate the shape for 3D Printing.
              Thank you for that explanation, Fredo. I'm happy to know it'll be a feature in FredoCorner.
              • fredo6F
                Dave,
                It should be possible in FredoCorner (but more complex in RoundCorner).
                Again, the result is visually different
                • I
                  ITman496
                  Thank you so much Fredo! My years of suffering are over!
                  I can't wait for the update to fredocorner!
                  And Dave, I will try 2D tools. Thank you!
                  • fredo6F
                    I'll publish it later today.
                    here is the video
                      Wow! Very good.Thank you!
                      • fredo6F
                        NEW RELEASE: RoundCorner v3.3a - 18 Dec 18
                        Requirement: LibFredo6 v8.7a or above
                        RoundCorner 3.3a is a maintenance release.
                        Home Page of RoundCorner for information and Download.
                        Main post of this thread.
                        • O
                          oyercab
                          Hello,
                          About two weeks ago I received an error message about RoundCorner when starting Sketchup 2018 Pro. I didn't save the message, and don't know exactly what it said, but RoundCorner was no longer available. I'm on macOS High Sierra (can't upgrade any higher). I updated Fredo6 to the latest version, restarted Sketchup, and then updated RoundCorner and restarted. The toolbar appears, but is completely unresponsive. I also tried installing FredoCorner. Its toolbar has never appeared, but I can put the icons in my main toolbar. It is also unresponsive.
                          In the "Fredo6 Collection" under Tools both RoundCorner and FredoCorner are showing, along with their menus, but I can't do anything with them. I've been using RoundCorner for years, and can barely function without it (many thanks, Fredo). Please, somebody help!
                          (I did install through Extension Manager in Sketchup).
                          Thank you, and hope everybody had a Merry Christmas.
                          • fredo6F
                            @oyercab
                            You seem to use Sketchup 8. Can you confirm?
                            Can you open the Ruby Console, and check for error message when you launch RoundCorner.
                            • O
                              oyercab
                              @fredo6 said:
                              @oyercab
                              Hello Fredo, I use SU2018 Pro. I did open Ruby Console, and the LibFredo6 plugin seems to be the problem. I installed the latest version through Extension Manager and followed instructions carefully, closing and re-starting Sketchup before installing RoundCorner. I then closed and re-started before installing FredoCorner. As I said, the toolbars and icons are there, but they don't do anything.
                              This problem started suddenly, after I had been away from the computer for a week. When I launched SketchUp, the error message about RoundCorner was on the screen, and its toolbar had disappeared. I'm going to try deleting and re-installing LibFredo6 again, but have already done that several times. Can I post the Ruby Console info here if I have no luck?
                              • fredo6F
                                @oyercab said:
                                Could you copy - paste the errors you see in the Ruby console.
                                • O
                                  oyercab
                                  Error: #<Errno::ENOENT: No such file or directory @ rb_sysopen - /Users/21imac/Library/Application Support/.LIBFREDO6_DATA_Dir/LibFredo6_all_defaults.dat>
                                  /users/21imac/library/application support/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:144:in initialize' /users/21imac/library/application support/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:144:in open'
                                  /users/21imac/library/application support/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:144:in write_to_file' /users/21imac/library/application support/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:127:in store'
                                  /users/21imac/library/application support/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1278:in usage_use' /users/21imac/library/application support/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1266:in command_invoke'
                                  /users/21imac/library/application support/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1249:in block (2 levels) in build_config_commands' /users/21imac/library/application support/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1348:in call'
                                  /users/21imac/library/application support/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1348:in block in add_command' SketchUp:1:in call'
                                  • fredo6F
                                    It seems you may have some restriction (security-based) to create subdirectories in /Users/21imac/Library/Application Support/.LIBFREDO6_DATA_Dir.
                                    Possibly, this has to do with the mode of your finder, which may require "View Hidden files".
                                    Can you check.
                                    Worse case, create the directory manually: /Users/21imac/Library/Application Support/.LIBFREDO6_DATA_Dir.
                                    Please note that there is a 'dot' before LIBFREDO6_DATA_Dir. On Mac, I think this to make the directory hidden.
                                    • O
                                      oyercab
                                      The directory is there, but it is hidden. I was able to see it by opening Terminal. Now what should I do? (The dot does make it hidden.)
                                      • fredo6F
                                        Could you enable the option "view hidden file" in your Finder.
                                        In the Terminal, type
                                        defaults write com.apple.finder AppleShowAllFiles YES; killall FINDER
                                        If it does not work, then it would mean that your Support folder is protected against file creation by program, and then you'll have to find how to allow it via changing some security settings.
                                        • O
                                          oyercab
                                          When I did that, I got this response "No matching processes belonging to you were found."
                                          But I can see the folder by typing the following two lines, one at a time:
                                          defaults write com.apple.finder AppleShowAllFiles TRUE
                                          killall Finder
                                          What should be inside that hidden folder? It only contains a folder named DefaultParameters,
                                          which has two files: FredoCorner.def and ROundCorNer.def (spelled just like that)
                                          Gail
                                          • fredo6F
                                            LibFredo6 tries to create a file named "LibFredo6_all_defaults.dat", but apparently it cannot, based on the error that you get in the Ruby console.
                                            So, this may be related to some security settings.
                                            In the Ruby console, could you copy and paste the following command and press Enter
                                            File.open(File.join(LibFredo6.appdata_dir, "LibFredo6_all_defaults.dat"), 'w') { |f| f.puts "###" }
                                            Do you get an error?
                                            If so, could you type (same command, but with a .txt extension)
                                            File.open(File.join(LibFredo6.appdata_dir, "LibFredo6_all_defaults.txt"), 'w') { |f| f.puts "###" }
                                            • 63
                                            • 64
                                            • 65
                                            • 66
                                            • 67
                                            • 74
                                            • 75
                                            • 65 / 75
