    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 655.8k Views 155 Watching
    • designerbursaD Offline
      designerbursa
      I am sorry for my English πŸ˜„
        reza1813
        Dear Fredo,
        Hello, I kindly reach you to mention a problem in the Joint Push Pull plugin.
        When I model organic shape or complex surface(Almost curve form or tensile structure) Pushing of the surface is not moving well and also I have tried to copy of surface and then use Curviloft to close it but it also doesn't work properly. What should I do exactly in this Situation? Thanks in advance.
        Joint Push Pull
        Sincerely
        Hamidreza
        • fredo6F Offline
          Could you post the model with the Tensile surface, so that I can try to investigate the problem with JPP.
          Also, can you use the Extrude tool in JPP (X marked) instead.
            reza1813
            Dear Fredo,
            Thanks a lot. It works when I use the Extrude tool in JPP (X marked). Thanks in advance.
            • CadFatherC Offline
              CadFather
              Hi Fredo, i noticed that JPP will treat group copies as instances - i think it would be great to bypass this and have it treat groups as separate. perhaps something for the next update cycle...
              • fredo6F Offline
                Definitely. This happens for freshly copied groups, that behave as components until you edit them. I need to correct this as I did in FredoCorner. Just some work!
                  CadFather
                  fantastic! : )
                    Leon aa
                    Hi, first of all I really like this plugin and I have been using it for some time now. Somehow the face selection via surface stopped working for me. The plugin only selects by face if I set it to surface.
                    • fredo6F Offline
                      Weird... May be you could
                      • open the Ruby console before launching JPP to check if there are errors
                      • post your model, or show a short video of the problem
                        Leon aa
                        I opened the Ruby console and then started the plugin, but there was no text in the console, so I think there's no problem there.
                        I don't think that there's a problem with my model. I tried it on different models and it wasn't working either.
                        Maybe there is a problem with LibFredo? I updated it last week and I haven't noticed any problem before. I tried reinstalling LibFredo and JPP, but it didn't fix anything.
                        Here is how it looks in SketchUp, no error message, just not working as intended:
                        https://lh3.googleusercontent.com/NYDBJXLT7sezAN-zo_IWJP4Acbj1OvDfYPJvVighSo7VZrWpVmUxxoeWVA990Dxz8BI-6V330jSpyn6ypOa98Ujt99LBn8Y9rk_L97MnKP60EQEeJEheowtRaqAukt8UFB6SAZ4xxJS8NBj_zAQZCcyT3Xo7gL9wa5FCGfd7Xc84DC6Bf6U0Si2rEBsl2QuwGAo_64YTmEvYjTE_q5QEMuRUrPFCPfJQH0u6vpgR9VuXjKDGKhZ7p2RELTMbT5pDB6EWPkdTs9TjZojeYQLyOLNlzNQiQv_T8a5Ije2KSUVas20TLmR0ONbOddARvr0GTu4ahaEkzqQW0vJzds3Jj6TwHpEwtmK77mWOJ1LtSEgi6-PVkWKGE7vDJ_vb2b3F7ig6o3WSAYYK994rumkb_sYyUnmQuP27MJ7osJiqfe2F-bM86idQ_EyYoPdMkYAORvNl1MIuART3NueFMFl8Th8HPh8Ks7vFv-mDh1XCF2PkEe5Um1DEXA8EtPCEN92ptFvv74acnZydPcK3shIGSN-KXZ1YEnn-TvzS7ubzbvPzx0D7hTaOwY3hzvtBa4-tnqUK3w2JQtxkWuEqRVnPGGTs80kpCDuImAy1gxJ_cgvl7V5HFq0v7PMVOTiDTWap9cKHspvmr4W7VsYxJ_4QOmaJZ_12LCjx68g8dAodSWiApzAsCQhOnn58Va5Guy2jNZZHSttnLAKJlAvXn2QYkjC_=w1563-h839-no
                        • fredo6F Offline
                          In Sketchup, surface is defined by a set of faces whose common edges are soft (so not smooth).
                          Can you check in your model.
                          Also, what happens when you turn off "Hidden Geometry" ?
                          • E Offline
                            Einstein
                            Round Push Pull with minimum number of rounding segments = 1, that would be nice πŸ˜„ (Now it's 2)
                              rv1974
                              Fredo, would it be possible to add 'afterward selection department' to JPP?
                              Say 3 check boxes that rule which category will stay selected: initial faces, offset faces, or connecting faces.
                              • fredo6F Offline
                                I am not sure I understand. The selection scope option is kept across JPP sessions and even Sketchup sessions.
                                  rv1974
                                  Say you have state 0, then run JPP and immediately after execution (on exit) you'd have (wishful thinking) 3 states.
                                  The goal is ability to group selection and assign diffrent material or make some geniuos manipulations (independently).
                                  • fredo6F Offline
                                    OK. I get what you want to get.
                                    Doable indeed, but this is another option in a GUI which some consider already 'bloated'!!
                                    Currently, JPP keeps the selection on the faces which have been selected.
                                      rv1974
                                      @fredo6 said:
                                      ...Currently, JPP keeps the selection on the faces which have been selected.
                                      OK. Could you please change this setting it to the offsetones? It would solve all my request without UI bloating. You see, I can Cnrl+C initial faces before JPP execution, and then just paste original faces after JPP is done. This simple hack restores original selection.
                                      • fredo6F Offline
                                        The native SketchUp Push Pull does the following
                                        • if and only if a face is pre-selected before launching the PP tool...
                                        • ...its offset fasce is hard-selected when you finished the push pull.
                                          This means that if you wish to push-pull another face right after within the same Push-Pull session, you have to press Escape to deselect.
                                        Is this behavior you want to reproduce with JPP?
                                          rv1974
                                          This is the way I imagine:
                                          1. Preselect
                                          2. Run JPP
                                          3. Hit Enter to exit
                                          4. Offset faces stay selected
                                          It's very similar to the principle described in Pilou gifs here:
                                          http://sketchucation.com/forums/viewtopic.php?f=323&t=1523&start=30
                                          but in our case we deal with faces, not lines
                                          P.S. By 'offset faces' I mean case #1 (see my picture above ^^^)
                                          • fredo6F Offline
                                            @rv1974
                                            Can you have a look at JPP v4.4c.
                                            It selects the offset faces of preselected faces (if any) at exit. This assumes indeed that you perform only one Push Pull operation and then exit.
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 26 / 31
