    Toolbar menu issues SU 2018
    12 Posts 4 Posters 8.4k Views 4 Watching
    • F Offline
      fast2hulls
      Hi- Thanks TIG.
      I just tried what you suggested.. Unfortunately, to improvement.
      SO...wondering if its a driver issue? I can see it there are new drivers for this NVIDA card. Again...brand new workstation.
      Also installed Rhino...but have not (yet) gone through all if it's menus.
      • F Offline
        fast2hulls
        Hi- Thanks TIG.
        • F Offline
          fast2hulls
          Thanks TIG. I tried what you suggested...but to no affect.
          Wonder if this a driver issue?
            Next step is to ensure the Graphics Card's drivers are up to date...
            Restart SketchUp to use the changes...
              What is display scaling set to?
              • F Offline
                fast2hulls
                Well...I contacted Dell and we did a complete system reset.
                So...newly installed Windows 10 x64 Pro
                Dell then looked for and updated any avail drivers for the NVIDIA Card.
                Here are the system specs:
                Model: Dell Precision 7730 mobile work station
                Processor: Intel Core I-9-8950HKP
                Graphics: NVIDIA P3200 w/6GB
                Memory: 16GB
                Built in display: 17.3" UHD (3840x2160)
                Hard Drive (1): 512GB PCIe SSD
                so...a pretty robust system.
                Scaling set to 250%.
                Then...try it at 100%. No improvement.
                I heard back from SU support..
                They had me uninstll and reinstall. Also make sure that SU is assigned the NVIDIA high perfommance graphics card in the NVIDA control panel.
                Still....no improvement.
                • F Offline
                  fast2hulls
                  another update:
                  Just contacted by SU support.
                  Per their instructions..I've now installed SU2019.
                  Well...having the same issue.
                  So...where does this leave me? Hardware configuration? Display resolution?
                    Try setting display scaling to no more than 150%. Then restart SketchUp.
                    • F Offline
                      fast2hulls
                      Hi All,
                      Sorry for not getting back with an update to this.
                      So..it turns out that the screen scaling (on a 4k monitor) was the issue.
                      Sketchup needs to launch on a screen that is scaled to no more than 175%...150% is best.
                      Once it launches...the screen can be scaled back to a high percent.
                      Im my case...with a 17" 4K built-in display on my Dell Precision, the proper scaling is 250% for Windows 10.
                      1. set screen scaling to 150%
                      2. open sketchup
                      3. change screen scaling back to 250%....all the menues now function.
                      Sketchup Support will likely issue a patch for this...or at least now they know how to advice others.
                      • jujuJ Offline
                        juju
                        strange, my 4k monitor is set to 200% scaling and I don't recall having any problems (apart from some icon images not scaling)
