    SketchUp 2019 release
    430 Posts 94 Posters 381.2k Views 94 Watching
    • PixeroP
      Pixero
      @solo said:
      SU is as good as it's going to get without totally redoing it from the ground up, plugin authors are the only reason I'm still using SU it's is no longer my only modeling app, C4D has been added to my toolbox and it is powerful and evolving at a greater rate than SU with tons more bells and whistles. If this is the new normal I see myself using SU less and less as it's becoming a bit of a dinosaur, and I dislike renting software
      When reading about Adobe acquiring Allegorithmic some think C4D is next on Adobes buy list so you better prepare for subscription there as well. πŸ˜‰
      • sfto1S
        sfto1
        @chippwalters said:
        So, I placed the above message in the SketchUp forum thread (not Sketchucation) this all started. In less than 45 seconds a moderator killed my post. So, just a heads up, it's now clear they will want to control the messaging around the dire straits of SketchUp.
        Your comment is hidden but not removed. I was able to click on it and read it. 😎
        • N
          numerobis
          C4D is Nemetschek (Allplan, ArchiCAD, Vectorworks, etc.)
            rv1974
            Cinema 4D and Cineware
            Learn to create CINEMA 4D files from within After Effects and work with complex 3D elements and animations.
            (helpx.adobe.com)
              david.
              This release just confirms that the SketchUp team gives little regard to a significant portion of their customer base. I have another high-end software app (not drawing/CAD). When they release a major upgrade, it is truly a "major upgrade". I'm confident that I'm getting value added. They also have other separate cloud based products, but they are not trying to force their customer base into a subscription. With SU, I'm consistently disappointed. I won't make that mistake again.
              • G
                Glenn at home
                @khai said:
                but none of them have the ease of Sketchup.
                About their only saving grace at the moment imho. It's just so damn easy in SU to get my ideas out. I have access to Form-Z but I am just so SU ingrained. IF and when Blender ever gets a way to mimic SU it might be over. πŸ˜‰
                • N
                  numerobis
                  (helpx.adobe.com)
                  https://www.nemetschek.com/en/brands/our-brands/ πŸ˜‰
                  • F
                    function
                    I'm curious what features they roll out 'periodically' with the subscription 😲 I mean if it takes them a year for dashed lines...
                    • ntxdaveN
                      ntxdave
                      I might be wrong, please correct me if I am, but I do not think anyone from the SketchUp team looks at the comments in this forum. 😞
                      Press F1...thank me later
                      • F
                        faust07
                        After reading all this, I think rather ambiguously about the many opposing and the few for-opinions.
                        Besides, I'm too dr... again ...
                        At some point I got stuck for my day work on SUp8 Pro, because it was pretty good. Then a few years later on SUp16 Pro ascended, because it was probably also stable (it actually runs ...). For my private animation fun I use SUp17 Make now because it is required for MSPhysics and also runs very well.
                        Since almost all plugins have reached a high level and I can sometimes even reprogram something myself, I am quite satisfied.
                        I think, for the visualization of my architectural designs, I will come up with the "old" program versions for a while (even with the few remaining errors).
                        I've been flirting with Blender, Unreal and Unity for years, never really found the time to go into it. Also, because I find SketchUp so original (rudimentary), spontaneous and somehow artistic. Here I can still hammer around on a natural stone plate with the hand ax ... and other SUp fans think that's great ...
                        I think that I still stick to SUp24 like this. (At work, we had a hard-to-follow flow from AutoCAD to BricksCAD to Revit within a few years, leaving SketchUp a stable component)
                        Peace, friendship, pancakes!
                        • Bryan KB
                          I am shocked and disappointed that Trimble has made Sketchup either subscription for the business version or web based and very bare bones for the free version. Neither option is acceptable to me. Software subscription is something I will never buy and web based is too slow and crippled.
                          It took me years to finally land a job where I was actually considering buying the Pro version at the previous price of $600, but now at over $1000, that is also unacceptable.
                          So 2017 is the end for me. I will probably finally learn Blender and spend another 8 years trying to master it.
                          At least I will finally be able to do high quality animations!
                          • L
                            I must admit I was perplexed by those eagerly awaiting SU 2019. On the recent history of Trimble SU some were expecting something good?
                            • Gus RG
                              Gus R
                              It appears that Sketchup 2019 is still available for download as a 30 day trial version as with previous releases which will then lose the Pro features and revert to the typical free version after 30 days as in the past, no?
                              www.instagram.com/gusrobatto/
                              www.facebook.com/gusrobatto
                              • BoxB
                                @gus r said:
                                no?
                                No, it will stop working unless you add a license or subscription. Same as 2018. You have to go back to 2017 to get the trial that reverts to Make.
                                  And you missed the Classic license version. But a lot of people seem to be ignoring that option.
                                    Yes. You're wrong. SketchUp team members do look at this forum.
                                    And to david, it's unfortunate that you haven't gotten to know the SketchUp team members. If you did, you'd know that your conclusion is as far from the truth as it is possible to get.
                                    • Gus RG
                                      Gus R
                                      @box said:
                                      @gus r said:
                                      no?
                                      Very well then. So ends Sketchup's fun run. Can't say I didn't see the writing on the wall when it was purchased by Trimble. I used Sketchup 8 for years and recently upgraded to Sketchup 17 which is working fine. I imagine Trimble will finally sell Sketchup to Lockheed Martin. πŸ˜‰
                                      • Randy HutniakR
                                        Randy Hutniak
                                        SU 2019 is out; check the Trimble website.
                                        Subscription based...now at twice the annual Service and Maintenance cost. I guess it was bound to happen.
                                        Now I have to purchase it before my 2018 ends so I can 'Train' the students I have. No discount for Accredited Trainers as far as I can tell. I did apply for the Teacher's edition $0.00 and where it asks for the School Name I put Accredited Trainer as per SU website! haha lets see what they say πŸ˜‰
                                          You also seem to have chosen to ignore the Classic license option which continues with the $120/year option as before. They haven't removed it.
                                          As for a "teachers edition" you should contact Customer Support directly.
                                            @pbacot said:
                                            But oddly if you just go to their site or you use the links they've just mailed to the faithful...you only find this (no Classic):
                                            https://www.sketchup.com/plans-and-pricing#for-professional
                                            Until you take the time to read ALL of the information.
                                            That page is directed at new users. You should already have a classic license if you've been a SketchUp Pro 2018 user.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 21
                                            • 22
                                            • 13 / 22
