    [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26
    2.2k Posts 573 Posters 4.2m Views 575 Watching
    • fredo6F Offline
      NEW RELEASE: LibFredo6 v8.7e - 01 Jan 19
      LibFredo6 8.7e fixes a major bug preventing some dialog boxes to display
      • fredo6F Offline
        NEW RELEASE: LibFredo6 v8.7f - 10 Jan 19
        LibFredo6 8.7f fixes a major bug preventing Animator to generate videos with recent versions of FFmpeg
          tonyliu
          θΌ‰ε…₯ζͺ”ζ‘ˆ Fredo6_!LibFredo6.rb ζ™‚η™Όη”ŸιŒ―θͺ€
          Error: #<ArgumentError: invalid byte sequence in UTF-8>
          c:/users/εŠ‰η₯ζˆ/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:50:in gsub' c:/users/εŠ‰η₯ζˆ/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:50:in get_dir_from_ENV'
          c:/users/εŠ‰η₯ζˆ/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:413:in dir_appdata' c:/users/εŠ‰η₯ζˆ/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:211:in startup'
          C:/Users/εŠ‰η₯ζˆ/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:in process' C:/Users/εŠ‰η₯ζˆ/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in module:LibFredo6_Loader'
          C:/Users/εŠ‰η₯ζˆ/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in `<top (required)>'
          window10
            @tonyliu
            Your Windows user-name in Chinese [εŠ‰ η₯ 成] "LiΓΊ yΓ²u chΓ©ng" seems to be causing the issue.
            Ruby is having difficulty encoding it into UTF-8 format...
            Having non-ASCII characters in user-names used to be a recipe for an error in Ruby; however, more recent versions are much better in forcing UTF-8 from such strings.
            Typically using this in the Ruby Console:
            ENV['USERNAME'].encoding
            or
            ENV['HOME'].encoding
            Returns this:
            Windows-1252
            Which is then converted to the required encoding of UTF-8 in the Ruby processing.
            What do you get returned for those ENV tests ?
            Perhaps Fredo can strengthen his code to force that encoding ??
              modoleinad
              Error Loading File Fredo6_!LibFredo6.rb
              c:/users/dan/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:806:in match' c:/users/dan/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:806:in block (2 levels) in load_from_config'
              c:/users/dan/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:805:in each' c:/users/dan/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:805:in block in load_from_config'
              c:/users/dan/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:803:in foreach' c:/users/dan/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:803:in load_from_config'
              c:/users/dan/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1218:in block in load_all_plugins' c:/users/dan/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1218:in each'
              c:/users/dan/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1218:in load_all_plugins' c:/users/dan/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:252:in startup'
              C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:in process' C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in module:LibFredo6_Loader'
              C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in <top (required)>' Error Loading File Fredo6_FredoScale.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in -'
              C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require'
              C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_FredoScale.rb:47:in module:Fredo6'
              C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_FredoScale.rb:26:in <top (required)>' Error Loading File Fredo6_FredoTools.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in -'
              C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_FredoTools.rb:47:in module:Fredo6'
              C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_FredoTools.rb:26:in <top (required)>' Error Loading File Fredo6_JointPushPull.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in -'
              C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_JointPushPull.rb:47:in module:Fredo6'
              C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_JointPushPull.rb:26:in `<top (required)>'
              Can anyone help me understand what this error means?
              • fredo6F Offline
                @modoleinad
                Usually, this problem comes when you installed Sketchup without Administrator rights.
                So I am afraid you need to uninstall SU2018 and reinstall.
                  smeehanla
                  I tried to download FredoTools and Toposhaper yesterday. My current LibFredo6 version is 8.5. I got a message saying that I need LibFredo6 version 86 for FredoTools and LibFredo6 version 87 for Toposhaper. The extension manager doesn't give me the option of updating my 8.5 version. Do I need to uninstall version 8.5 and then install version 8.7? Or do I leave 8.5 in the manager and just install 8.7?
                    No need to uninstall the earlier version[s].
                    The new installation will overwrite any equivalent files/version etc as needed.
                    But you should restart SketchUp after finishing the installation[s] to ensure everything gets synced...
                    • guanjinG Offline
                      guanjin
                      cannot be set in sketchup2015, all Chinese is empty.
                      • fredo6F Offline
                        Can you be more explicit for the problem.
                        I do have the Chinese in SU2015
                        • guanjinG Offline
                          guanjin
                          [attachment=1:18r21dr6]<!-- ia1 -->LibFredo6 - plugins load chinese.png<!-- ia1 -->[/attachment:18r21dr6]
                          [attachment=0:18r21dr6]<!-- ia0 -->LibFredo6 - About Chinese.png<!-- ia0 -->[/attachment:18r21dr6]
                          Found that your version is 8.7h, I installed 8.7f
                          • fredo6F Offline
                            v8.7f is the latest release. v8.7h is an internal release on my own laptop.
                            • fredo6F Offline
                              • fredo6F Offline
                                NEW RELEASE: LibFredo6 v8.7k - 14 Feb 19
                                LibFredo6 8.7k fixes various bugs and the accuracy of the hand cursor over button palettes
                                  Puco
                                  Hi Fredo one question, I installed SU 2019 and the first thing that I freshly install is LibFredo6-v8.7K but when I go to Windows/LibFredo6Settings/Check for updates it gives info that 8.7j is actually installed and needs an update to 8.7k... I tried everything to fix this, fresh install and everything and after several attempts to install 8.7k, it gives a result as if I have installed 8.7j and needs an update. Any help?
                                    You must restart SketchUp to ensure the latest installed version is loaded.
                                    But if the issue continues after that, then come back...
                                      Puco
                                      Did restart SketchUp, and my pc to be entirely sure that everything is set correctly, but no luck, 8.7j is installed instead of 8.7k. Checked the download folder if I accidentally have the wrong version downloaded, but no, everything is ok, 8.7 K is what I have downloaded and installed, and yet, SketchUp even upon restart of the program and pc says that I need to actually update to 8.7 k 😞
                                      • fredo6F Offline
                                        This is my own error in the parameterization of the release. You definitely have the good version. So don't worry.
                                          Puco
                                          Thank you for the quick response to this concern. As long as you are saying that it is just some minor issue regardless the version number only, I won't be supper paranoic to cry for the same issue πŸ˜„ all over again, except this time it gives like I have version 8.7 L installed and need to update to 8.7 M ... I will avoid that notification that I don't have the latest version, as long as you said already that is just a parametrization, not the actual extension/plugin problem! Thank you once again!
                                          • fredo6F Offline
                                            NEW RELEASE: LibFredo6 v8.7m - 15 Feb 19
                                            LibFredo6 8.7m fixes various bugs and aligns the release reference (misaligned with previous v8.7k)
                                            • 80
                                            • 81
                                            • 82
                                            • 83
                                            • 84
                                            • 109
                                            • 110
                                            • 82 / 110
