    Searching for Plugin "Add Bitmap to Materials (Mats)"
    13 Posts 5 Posters 1.7k Views 5 Watching
    • HornOxxH Offline
      HornOxx
      Hi all
      I'm searching for this plugin but can't find it again.
      It adds an additional small bitmap to any material library color in the material editor to improve the color display. I am happy about every hint 😄
      never trust a skinny cook
        Any idea where you might have seen it mentioned?
        • HornOxxH Offline
          HornOxx
          Hi Dave - it's so weird, I've been using this good plugin for a long time and last week it ran flawlessly. Suddenly it refuses the work and I wasn´t able to reconstruct or find it entirely, neither in my plugin directory nor in the web ...
          So thanks for asking me where it might have been mentioned !!! 😉
          Forum Member JQL mentioned it for me first in this thread
          https://sketchucation.com/forums/viewtopic.php?f=15&t=67172&hilit=+bitmap
          and here it is:
          http://sketchucation.com/forums/viewtopic.php?t=48714
            So now it's found! Any idea why it suddenly quit working? Have you tried running it with the Ruby Console open?
            • HornOxxH Offline
              HornOxx
              ... that´s what I get of information only
                Username characters with accents or anything?
                It might be that the author needs to revise the extension to accept the characters. Other authors have had to do that.
                • HornOxxH Offline
                  HornOxx
                  Thanks! No, special characters in my user name are not given - So i'm trying to research about the plugin author himself, and will report here if i learn anything new 😄
                    slbaumgartner
                    I took a quick look at the extension code. There is a single error handler (rescue clause) for the entire sequence of processing. The message box you showed is posted by this handler. The text up to "Original error message:" is hard-coded, evidently on the assumption that a bad folder path is the only thing that can possibly go wrong (!). The text after that is the actual message from the exception that occurred. In your example it is saying that some (unstated) material name was a duplicate, which is not allowed. I would guess that there is a bug in the processing that attempts to create "safe" names to assign to the materials, causing it to create a duplicate.
                    If you manage to contact the original author, he should be able to diagnose the issue. But if you can't find him, let me know and I'll help.
                      TBoy
                      @slbaumgartner said:
                      .... let me know and I'll help.
                      Please give a temporary solution. May be a replacement strings inside code until the author makes changes.
                      • HornOxxH Offline
                        HornOxx
                        I took a quick look at the extension code... ...But if you can't find him, let me know and I'll help.
                        👍 😄 thank you slbaumgartner for your investigations and the so possible conclusions. Yes, I will try to find contact to the author and report of course here. Thanks for your offer to help here and I will not hesitate to ask you then 😄
                          slbaumgartner
                          I prefer to let authors fix their own plugins rather than usurp their ownership, so I'll wait until you cannot find him before posting any code here. I will just say that I can't reproduce the error @HornOxx saw on my computer, but I can see some dubious aspects of the plugin that might be responsible.
                          • F Offline
                            faust07
                            In the PluginStore is a version RamTools_BmpMats_v0.3 from 2017 - don't know if it is improved compared to the version in the original post of Rami_Ipm.
                              slbaumgartner
                              Thanks @faust07, I hadn't bothered to check for an update! @HornOxx, you can try the newer version to see whether it helps. If my theory is correct about what is happening, it will still fail the same way. I noticed in the comments on the new version the author says he created it for use when importing into Lumion, but as of Lumion 3 it isn't needed any more.
