    Can't create horizonatal guides
    11 Posts 4 Posters 4.9k Views 4 Watching
      I see all sorts of horizontal guidelines in your file and four guide points positioned vertically above the corners of the rectangle.
      What do you see? Show us a screenshot.
        As DaveR says.
        Works fine for me making new guides in all directions.
        To make a vertical guide-line you can click on the drawn rectangle corner and the guide-point***, alternatively set Axes to visible in View and drag from the blue-axis to make the vertical guide-line.
        ***Remember you can toggle between line/point creation using a modifier key ??
        If that doesn't work for you you might have a graphics-card issue - try to update its driver...
        See if that helps...
        Or perhaps you have not installed SketchUp properly, try Repairing it thus...
        While logged in as your normal user-account, close SketchUp if it's open.
        Find the SketchUp installer's exe file - in Downloads ?
        Select its icon, right-click > context-menu > "Run as administrator"...
        When prompted choose "Repair"
        This will not adversely affect an custom settings or plugins etc.
        After it completes restart SketchUp and see if that helps.
        Installing SketchUp in any other way [e.g. by double-clicking the installer's icon to 'Run' it], then that can cause all kinds of unexpected and weird things to happen later.
        These usually relate to file permissions, opening plugins, and [mis]remembering user settings etc.
        I not known it to mess up guide creation... but you never know !
        • G
          geoffs
          Thanks for the answers, attache dis what I can see on the example file I provided.
          Regards
          Geoff
          • G
            geoffs
            Attached is what I can see in the sample file I previously provided.
            Regards
            Geoff
            • G
              geoffs
              Some further details on my system.
              I'm running Sketchup Pro 2016 16.0.19911 32 bit on Windows 7 under VMplayer under Linux (Ubuntu 16.04)
              VMplayer is a recent replacement for VMware Wprkstation.
              Regards
              Geoff
                Most of the lines running left to right in your screen shot are guidelines and they are running horizontally.
                If you were to turn on the Axes in your model, they would give you a frame of reference. If you need more reference than that, edit the style and turn on the sky or select a style with Sky turned on already.
                • G
                  geoffs
                  I can see those vertical guides but not the (many) horizontal ones. This would indicate that it's not a graphics driver/card issue - I assume I wouldn't see any dotted lines.
                  I guess I was hoping that someone would say 'You dummy, you need to select option X!'
                  I just had a closer (actually first) look at the screen shot I provided and noticed the horizontal lines do appear. Doh!
                  I have windows 8 under VMware for Fusion 360 so I might try installing Sketchup on that to see if it makes a difference.
                  Regards
                  Geoff
                    I think it is due to your graphics arrangement. You are using SketchUp with an unsupported operating system and graphics setup, after all.
                    • G
                      geoffs
                      Dave R,
                      You're right! I went through the graphics settings in VMplayer and I had an option set that is normally used for DirectX9 (accelerate 3D graphics). One I turned that option off, my guides appeared.
                      I wouldn't have thought to change graphics settings as I could see some (vertical) guides, thanks for the suggeestions.
                      While not perhaps a supported option, I've found Skectchup at various levels to work very well under VMware. Mind you, I'm not exactly a power user!
                      Regards
                      Geoff
                      • jgbJ
                        jgb
                        A tip....
                        Change the color of your guidelines to something not normally used in SU, like a medium orange. Not green, blue nor red. Yellow is hard to see as well.
                        Being black and dashed they tend to hide.
                        It would be nice if the guidelines could be 2 pixels wide, but, that ain't gonna happen.
                        jgb
