    [Plugin Library] LibFredo6 - v15.8b - 12 Jan 26
    2.2k Posts 571 Posters 4.1m Views 573 Watching
    • fredo6F Offline
      NEW RELEASE: LibFredo6 v8.6n - 05 Dec 18
      LibFredo6 8.6n fixes occasional problems in Orbiting, in FredoTools::ThruPaint and possibly in some others of my plugins.
      • fredo6F Offline
        NEW RELEASE: LibFredo6 v8.6p - 05 Dec 18
        LibFredo6 8.6p fixes a random bug in Animator when using Movement Along Path.
        • fredo6F Offline
          NEW RELEASE: LibFredo6 v8.7a - 18 Dec 18
          LibFredo6 8.7a is a maintenance release providing adjustments to several of my plugins.
          • OxerO Offline
            Oxer
            Hi Fredo,
            I installed the last version of LibFredo v8.7a, there is an issue, I can't access to your plugins through the icons, it appears the options window and it disappears immediately. When I access through plugins Menu or Contextual Menu they work.
            When the tool (ex. JointPushPull) is running and I push the Tool Settings icon it happens the same, the settings window appears and it disappears immediately.
            macOS 10.13.6 & SU2017
            • fredo6F Offline
              @oxer said:
              Hi Fredo,
              Can you open the Ruby Console.
              • fredo6F Offline
                Do you have the problem with the button palette of my plugins (like JointPushPull or FredoCorner) or is it just for the dialog boxes?
                • OxerO Offline
                  Oxer
                  Nothing in Ruby Console. 😲
                  I open for example Window Menu> LibFredo Options> Check Updates for Plugins and the window appears but it closes immediately.
                  EDIT: After that I can use another Skechup Tools but if I press Cmd+Q (exit SU on Mac) SketchUp doesn't close, I have to force the exit.
                  • OxerO Offline
                    Oxer
                    It's with the dialogs (popup windows) only, the palletes works fine.
                    How I said you before to access to yours plugins I can do this through the Tool & Extensions Menu or Contextual Menu only.
                    • fredo6F Offline
                      Is it for all popup dialog boxes ?
                      • pbacotP Offline
                        I have loaded this plugin but my Fredo tools don't work. I get several prompts on opening SketchUp. According to the Plugin Manager I have the latest plugin.
                        • fredo6F Offline
                          Seems to be something quite old, because there is no longer a reference to LibFredo6 6.3 in the latest version of my plugins. Can you check for TopoShaper.
                          Also, ff you run LibFredo6 8.7a, could you send me the trace file (Windows > Library Settings > Trace Log File...
                          Another user has signaled me an anomaly with popup messages.
                          • pbacotP Offline
                            I choose "View Trace Log Files..." and nothing happens. Let me try updating. I know most plugins are recent updates, but some like TopoShaper may not be.
                            • pbacotP Offline
                              hmm... check for updates doesn't work either.
                              • fredo6F Offline
                                Same problem as Oxer. You are on Mac, and there seems to be a problem with Web dialog boxes.
                                Since you have FredoTools installed, could you check if
                                • the Quick Launcher works
                                • if Solid Volume displays a dialog box
                                • pbacotP Offline
                                  Ok updating several Fredo6 plugins allows me to open without prompts and FredoTools and Fredo Collection seem to be in place as before!
                                  Still when I choose "View Trace Log Files..." sometimes a window flashes on and off but nothing else happens.
                                  FredoTools Launcher doesn't do anything.
                                  Solid Volume flashes a window briefly.
                                  • fredo6F Offline
                                    @oxer, @pbacot,
                                    Can you tell me which version of Safari you run on your Mac.
                                    It seems that Safari does not like a change I made in my code related to dialog boxes.
                                    • OxerO Offline
                                      Oxer
                                      Yes, have you probe anther options like Defaults Options..., Translate Language.., etc?
                                      To me, with all these options the popup window appear and disappear immediately.
                                      macOS High Sierra 10.13.6 & SU2017
                                      • pbacotP Offline
                                        I have Safari 12.0.2 (13606.3.4.1.4)
                                        • OxerO Offline
                                          Oxer
                                          • fredo6F Offline
                                            NEW RELEASE: LibFredo6 v8.7d - 20 Dec 18
                                            LibFredo6 8.7d fixes a major bug preventing dialog boxes to display on MAC
                                            • 75
                                            • 76
                                            • 77
                                            • 78
                                            • 79
                                            • 108
                                            • 109
                                            • 77 / 109
