    1.3k Posts 299 Posters 2.6m Views 297 Watching
    • fredo6F Offline
      NEW RELEASE: Curviloft v1.7d - 31 May 18
      Curviloft 1.7d is a maintenance release fixing a bug in the automatic ordering of contours for the Spline tool.
      See Plugin Page of Curviloft for Download (or use the Sketchup PluginStore plugin for auto-installation.
      Main post of this thread
        rv1974
        Unprecedented responsiveness Fredo,many thanks!
        I'll test the update later today.
        Another imperfection (?, - maybe I just can't find right buttons) I encountered with Loft by spline is that
        the inter-medial segments can't keep exact dimensions of initial profiles (lowest and highest ones in attached example 12X81m*, storey height is 3.5m). Another issue is that segments are slightly OFFXY Plane.
        Is it possible to develop some special mode that'd keep segments exactly parallel to the input profiles, and if initial profiles are equal it'd keep their dimensions?
        • P.S. In this particular case of 50+ storey towers PlayitItAgain script helped a lot.
        dddd.skp1.skp2.skp
        • fredo6F Offline
          This seems to be a problem of geometry which you can simulate manually.
          If you wish to keep the junction straight, then the intermediate profiles do not keep the same dimensions.
          Also, the intermediate sections are parallel to the initial profiles. Do you have something different?
            rv1974
            With prussian pedantry I took all horizontal segments, run make faces and...
            it did it all πŸ™‚ which proves you are right- they are horizontal. What misleads is "~" sign in measurements, must be some SU glitch.
              rv1974
              No, what is needed is intermediate segments to preserve initial dimentions of the profile.
              In attached file the red body is OK (all horizontal segments keep right sizing),
              and the blue one (lofting with 51 intermediate segments) misbehaves.
              dddd.skp1.skp21.skp4.skp
              • fredo6F Offline
                @rv1974 said:
                No, what is needed is intermediate segments to preserve initial dimensions of the profile.
                Then, Curviloft is not adapted, and you should use FollowMe Rotate or TIG Grow extensions.
                With rotated profile, line joining the begin and end profile corner does not meet the corner of the intermediate profiles.
                In your red shape, you can see that the short segments joining stores are not aligned and do not form a big straight line.
                  rv1974
                  Thanks for mentioning those alternatives- I'll check them. I'm so glued to your tools that completely forgot others πŸ˜„
                  BTW the straight line on a blue tower shows the horizontal segments don't sit perfectly on it. The gap is ridiculously small in real life scale (~0.3cm in the middle floors, but big enough to spoil the model
                    rv1974
                    Fredo could you take a look please
                    messy result with a newest version (loft)
                    • fredo6F Offline
                      I need to consider this case of indetical profiles more seriously, which Curviloft did not really do.
                      So I'll come with something more robust.
                        Architure
                        Hi there,
                        When selecting more than 3 edge curves, and choosing for junction by orthogonal bezier curves, the surfaces do not get the reach the right spline method result.
                        Here is what the ruby console shows
                        Error: #<ArgumentError: Cannot create unit vector from zero length vector>
                        c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6profile.rbe:119:in axes' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6profile.rbe:119:in compute_by_offset'
                        c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6profile.rbe:58:in compute_by_vectors2' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6profile.rbe:86:in compute_by_normals'
                        c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:357:in block in spline_profiling_construct' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:351:in each'
                        c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:351:in each_with_index' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:351:in spline_profiling_construct'
                        c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:249:in spline_junction_construct' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:497:in generic_junction_construct'
                        c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:1418:in junction_construct' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in block in link_construct_all'
                        c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in each' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in link_construct_all'
                        c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:396:in link_calculate_all' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:530:in option_set_prop'
                        c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:206:in option_set_prop' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftpalette.rbe:773:in call'
                        c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftpalette.rbe:773:in block in pal_family_spline_method' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3963:in call'
                        Just ask me for the file if needed!
                        Cheers
                        Manuel
                        • fredo6F Offline
                          Yes the file would be useful, as this seems to be a special case.
                            Architure
                            Hi there,
                            Sorry for my late reply. Here is the attached 2018 skp file . You can see that the selected mode is only applied between the first 3 curves.
                            Let me know if I can provide more information.
                            Cheers
                            seat back.skp
                            • fredo6F Offline
                              NEW RELEASE: Curviloft v1.8a - 31 Oct 18
                              Curviloft 1.8a is a maintenance release for bug fixing.
                              • Z Offline
                                zswseu
                                Looking forward to another excellent work.
                                  rv1974
                                  In 99% of of lofting uses I have to straighten borders connnecting ends of segments afterwards(thanks Thom there're Edge tools so it's not manual). Could there be an optionto keep them straight when creating?
                                  • fredo6F Offline
                                    Not too sure what you mean by 'straighten'.
                                    Maybe an example would be helpful.
                                      rv1974
                                      Edit: Only after posting I figured out 'junction by connected lines' in 'spline method' fixes this problem' πŸ˜„
                                      • fredo6F Offline
                                        I really need to refresh the plugin with more explicit control of the different options (and maybe selecting a few ones which make sense). Currently, Curviloft rather exposes the options that come from the algorithm, up to the user to find out what is appropriate. That's why I still leave it in Beta after all these years!
                                        • jgbJ Offline
                                          jgb
                                          I wholeheartedly agree, but please also update your last 32 bit version as well.
                                          I cannot run 64 bit apps on my old PC. I'm still running Make V.13.
                                          jgb
                                            Loft along the path: can we modify the path after launch the plugin?
                                            I don't see it! (the path)
                                            • 57
                                            • 58
                                            • 59
                                            • 60
                                            • 61
                                            • 65
                                            • 66
                                            • 59 / 66
