    Triple click not working with outliner open
    12 Posts 7 Posters 2.3k Views 7 Watching
    • F Offline
      Flion
      I just tried to save a model and got this message:
      Results of Validity Check.
      *** Problems were found that could not be fixed! ***
      The entity at address 84c9fc00 has an invalid id (0) destroyed (0)
      The model can be saved even without fixing the issue.
        How about sharing the SKP file so we can see what you've got?
        • F Offline
          Flion
          Architecture detail.rar Here's the file.
          • BoxB Offline
            Hang on, you said it was less than one meg but you have to compress it to upload, and you have used rar. I guess you don't want help.
              slbaumgartner
              When I opened your file on my Mac, SketchUp wanted to fix issues with a lot of invalid object ids. But regardless of whether I let it fix them or not, the only cases in which triple-click did not select all was when the component contents consisted only of nested components. In that case the third click would select the nested component at the location of the click. Is that what you were referring to? Having outliner open vs closed made no difference for me.
              • F Offline
                Flion
                @Box. It was less than 1MB in the middle of the work. Meanwhile I carry on the work and came to around 2MB.
                I don't get this?
                @slbaumgartner In the meanwhile I saved a model without fixing the issue. When I opened it again it doesn't report any problems but the triple click (and outliner blinking) problem is still present.
                • jujuJ Offline
                  juju
                  I don't get this?
                  meaning the file is small enough to upload directly and that RAR isn't a very popular compression format
                  • F Offline
                    Flion
                    I'm sorry for my ignorance. What do you suggest? ZIP? 7zip?
                    • jujuJ Offline
                      juju
                      1MB or 2MB should be small enough to upload directly (without having to compress it in RAR / ZIP / whatever)
                      • sketch3d.deS Offline
                        sketch3d.de
                        ZIP is the standard, a 10% better compression of ARJ or 7Z typically irrelevant... besides giant video files maybe.
                        • oceanembersO Offline
                          oceanembers
                          Can't replicate here, using 2018.
