Triple click not working with outliner open
I'm working in a file that's less than 1mb in size. It's a model with with 1200 components and 45 groups. At one point I noticed that triple click is not working - not selecting the whole connected geometry. Double click does work. It is worth mentioning that outliner and the contents blink on every mouse click. What's more interesting is that triple click works when I minimize (close) outliner.
I opened a new blank drawing and everything works fine. I assume there's something in the model causing this behavior. Any ideas?
SU Pro 2017
I just tried to save a model and got this message:
Results of Validity Check.
*** Problems were found that could not be fixed! ***The entity at address 84c9fc00 has an invalid id (0) destroyed (0)
The model can be saved even without fixing the issue.
How about sharing the SKP file so we can see what you've got?
Architecture detail.rar Here's the file.
Hang on, you said it was less than one meg but you have to compress it to upload, and you have used rar. I guess you don't want help.
When I opened your file on my Mac, SketchUp wanted to fix issues with a lot of invalid object ids. But regardless of whether I let it fix them or not, the only cases in which triple-click did not select all was when the component contents consisted only of nested components. In that case the third click would select the nested component at the location of the click. Is that what you were referring to? Having outliner open vs closed made no difference for me.
@Box. It was less than 1MB in the middle of the work. Meanwhile I carry on the work and came to around 2MB.
@unknownuser said:I guess you don't want help.
I don't get this?@slbaumgartner In the meanwhile I saved a model without fixing the issue. When I opened it again it doesn't report any problems but the triple click (and outliner blinking) problem is still present.
I don't get this?meaning the file is small enough to upload directly and that RAR isn't a very popular compression format
I'm sorry for my ignorance. What do you suggest? ZIP? 7zip?
1MB or 2MB should be small enough to upload directly (without having to compress it in RAR / ZIP / whatever)
ZIP is the standard, a 10% better compression of ARJ or 7Z typically irrelevant... besides giant video files maybe.
Can't replicate here, using 2018.
