    Animator and VRay
    renderpluginsextensions
    45 Posts 23 Posters 98.0k Views 23 Watching
      dihe
      I made test on slower PC borh have Vray 3.6.03 first SKP 2018 secound SKP2017. On slower animator/vray only build light chach and want't render. On faster I made a few more tests and even I made slower resolution test render stop in 3/4. Maybe it is timeout? Have you any idea how to fix it?
      I don't know why it render scene correctly with material override? Maybe some kind of material crush vraya. But in normal work evrything is OK.
      Thank you in advanced.
      Jarek
        dihe
        Highest resolution which finished correctly is 1270x714px. If 1280x720 is setting up vray leave one squere with no rendered pixels... if resolution grow numbers of not rendered pixel is higher...
        Btw. If I setup in Animator 1270x714px the resolution in vray asset editor also change. But when i made it 1920x1080 resolution in asset editor didn't change... 😄
          snop2205
          Hello Fredo!
          Thank you for all your Hard work!
          I have the same problem with the plugin as dihe have.
          The computer stops in the middle of rendering at high resolution and does not save the image.
          in low-resolution the computer finishes rendering and saves
          Is there a time out for each render?
            snop2205
            @fredo6 said:
            @dihe said:
            Hi there,
            I prepare whole animation. view port size is 1541x891 px. When I made it smaller evtyhing is OK but when i made it 1920x1080 all frames are render but file want save. Have you any idea why, and how to fix it?
            https://preview.ibb.co/jZWZ0e/2018_08_08_19_19_07_KX90_bateria_pod_okno_3_anime3_Sketch_Up_Pro_2018.png
            Can you try the Test Image button, to see if the file is generated
            Hello Fredo!
            • fredo6F Offline
              For info, this was due to a time out set for VRay at 2 minutes for rendering.
              With LibFredo6 v8.5f, I have increased the time to 10 minutes.
                dihe
                Hi Fredo,
                could you add rendering exact frame fe. 165,166,175...
                I have problem because now I need to render fram in "secounds" time, and somtimes when I render something simultaneously with animation render I have time out and freame wan't save.
                • I Offline
                  Immortalis
                  I have a problem with rendering with vray.
                  When I render an animation, it never lets it finish the rendering. After prepass 1of1 is finished, and actual rendering should start, animator just ends the rendering of that frame and continues on another frame. And happens for every frame, until it is stuck on one frame, and after that frame is finished rendering, another frame can't start render.
                  How to solve this?
                    pejot11
                    Hello Fredo,
                    thank you for this great extension.
                    Is it possible to set the time out higher than 10 minutes?
                    I would like to render in higher resolution, but every time
                    a frame needs more than 10 minutes this frame is not saved.
                    Thank you.
                    pejot
                    • W Offline
                      williamj
                      Hi Fredo6,
                      Love your work firstly. Your extensions are really useful.
                      Can I echo the same as a couple of people on here? I'm using SU2018 and Vray 3.6(something)
                      1. Im trying to render an animation where the frames take longer than 10 mins. Is there a way to change the timeout manually, or, is there a reason why were limited to 10 mins?
                      2. Being able to stop a big render and start again at the exact frame that it left off would be amazing, is there a way to do this?
                      Keep up the good work and thank you again.
                        Macon
                        Bonjour
                        Je viens de découvrir ce qu'il était possible de faire. Je trouve cela fantastique, un grand merci à tous ceux qui ont pris le temps de faire une chose pareille!
                        Une petite question cependant: est il possible de réaliser l'animation d'animator à un moment précis d'une animation de scènes Sketchup? Par exemple Lors d'une visite virtuelle d'une maison, nous traversons un couloir (scènes SU ) avant d'arriver devant une porte qui s'ouvre (animation Animator) et continuons la visite (scène SU). En passant le tout dans Vray....
                        Un grand merci à tous ceux qui pourront me répondre!
                        Cordialement
                        • fredo6F Offline
                          This is a feature that is planned. Actually, I introduced the concept of 'Visitor' in earlier versions, but this needs a lot more work to make it usable. SO it is deactivated for the time being.
                            Macon
                            Merci à toi en tous cas!
                            Pour ce plugin, et pour les autres!
                              Sidneysalmeronborrell
                              Hello, a pleasure
                              I have a problem and that is when I tell Animator to do the animation through VRAY it does not work. It stays stuck in the render when it finishes and does not advance. If I put it other than Vray if it works. It is not interact
                                cyrilc
                                Hello Fredo,
                                For some reasons, Vray only renders the first frame of the animation many times, while I see animator running properly.
                                I am using Sketchup 2020 and Vray 4.20.01
                                I have checked everything I could find on forums and youtube. I saw that other users seem to have the same problem.
                                Any idea why ?
                                Best regards, and congrats for all the work,
                                Cyril
                                  safak
                                  I am having the same problem.
                                  I can create videos with animator, which means I have got working "films" in the animator. I can render my scenes in Vray. When I open the generator tab of the animator, I am able to see the Vray option and I can do my settings accordingly. So everything is fine so far. However, when I generate a video I get an 18 seconds video of the very first image. Nothing is moving. Does anyone happen to know why?
                                  Thanks in advance.
                                  Edit: Actually I tried it with another model file, which is very basic, and it worked. But still can't make it on my real file.
                                    Serge73
                                    Cyril
                                    Similar issue.
                                    The animator does not transmit frames, all png images are from the first frame only.
                                      Calcifer
                                      Hello Fredo,
                                      First, thank you very much for your fantastic plugin. I have been using it extensively for the past 18 months.
                                      I also have the same problem described in previous posts when using V-Ray with Animator. It only renders the first frame. I thought my project was too complex so I tried with a very simple one: a moving cube. Still did not work. I use SU 2020 and V-Ray 4.20.01
                                      However, I tried on my laptop with SU 2017 and V-Ray 4.10.01 and it surprisingly works wonderfully. I don't know anything about technical stuff but I thought it was worth mentionning that.
                                      Thank you very much again!
                                        PopBen
                                        Again, thank you for your fantastic plugins. They've revolutionised the way I produce my models.
                                        I too am having the same issues. I'm running SketchUp 2017 with V-Ray for SketchUp 4.20.02 on a Mac.
                                        When trying to render the animation only the 1st frame is repeatedly rendered.
                                        When I process without VRay it works fine and also the preview in SketchUp displays fines.
                                        Thanks you in advance.
                                          changh198
                                          Hi Fredo,
                                          Thank you for the amazing plugin.
                                          However i am having the same issue on sketchup 2020 with Vray 4.2002.
                                          It keeps rendering the first frame.
                                          How can i fix this?
                                          Thank you for your effort!
                                          • fredo6F Offline
                                            The problem with VRay 4.2 rendering should be fixed with LibFredo6 v10.9a.
                                            • 2 / 3
