    ComponentFinder
    Scheduled Pinned Locked Moved FlexTools
    renderpluginsextensions
    39 Posts 9 Posters 87.4k Views 9 Watching
    • EdsonE
      Edson
      thanks. this is what I had done before. and it worked.
      what is happening is that when I try to instal Component Finder the installer installs the whole package. this installer is ft1.6.1_component_finder_pack_0.6.0. I am probably not being able to download the correct installer. how can I get it?
      http://www.mahfuz.arq.br
      • halroachH
        halroach
        You have the correct RBZ - ft1.6.1_component_finder_pack_0.6.0
        Before installing make sure the C:\ProgramData\F3d_FlexTools folder is gone.
        After restarting Sketchup and reinstalling you should have a toolbar called FlexTools with 2 icons on it.
        It should look like this:
        FlexTools - Super Quick Windows, Doors, Slats...
        • EdsonE
          Edson
          ok. problem solved. there were parts FlexTools in more than one location and I had to delete all of them for the installation to work.
          thanks.
          • halroachH
            halroach
            thanks.
            Ok great. Glad it worked out.
            • sallyS
              sally
              Hello,
              I too have installed the rbz file, have the toolbar and component browser window but can't load any components or folders. I'm on a Mac running Mojave 10.14.1. No messages on the ruby console.
              Thanks, kind regards, Sally
              • EdsonE
                Edson
                @sally said:
                Hello,
                Depending on the number of components you have in your computer, it seems to take a long time to load them.
                • halroachH
                  halroach
                  @sally said:
                  Hello,
                  Hi Sally,
                  1. Was ComponentFinder(CF) working at any point in time, or it wouldn't work when you first opened it?
                  2. Is the CF screen completely gray, or do you see the interface normally?
                  3. Please check if purging the model (Window > Model Info > Statistics > 'Purge Unused') helps in any way.
                  • sallyS
                    sally
                    Hello Yoni (?)
                    1 it has never worked
                    2 I see the interface normally
                    3 purging made no difference
                    When I click on add folder, I can navigate to the folder I want, but all the SKP files within the folder stay greyed out. And nothing loads. I think I will uninstall and re-install the rbz file.
                    Thanks, Sally
                    • halroachH
                      halroach
                      @sally said:
                      Hello Yoni (?)
                      Thanks, Sally
                      What versions of Sketchup is it on?
                      Can you please post a screenshot?
                      Yes, this is Yoni
                      • sallyS
                        sally
                        Hi Yoni,
                        when I looked at the CF screen and clicked on all the icons, (I think it was the eye one) I saw a message saying please re-start SU to rebuild the toolbar. So I restarted and voila, there they all were. I had 6 lots of the same folder, presumably they had loaded each time I had tried but just didn't show. Su version 18.0.16976 by the way.
                        Happy bunny now, looks like a great tool. Many thanks, best, Sally
                        • halroachH
                          halroach
                          @sally said:
                          Hi Yoni,
                          Not sure what caused the folders not to show, but great to hear it's working fine now 😄
                          • halroachH
                            halroach
                            Glad to announce ComponentFinder was updated to version 0.8.0 😄
                            The highlights:
                            • Folder scanning depth is now increased from 5 levels deep to infinity! (and beyond...)
                            • The maximum number of components in an open folder tab is now up to 6000!
                            • When opening a new folder tab, the scanning will be going on in the background so you can continue working while it's scanning. Components will be added as they are discovered.
                            • You can now cancel the scan anytime.
                            • Faster loading of open folder tabs during CF startup.
                            • An additional larger zoom level was added.
                            • You can click on the folder name and it then shows the full path instead.
                            • When hovering over components, a tooltip appears with the full path.
                            • The annoying bug where components' thumbnails would suddenly break? Squashed! 👊
                            To see the full list of release notes => https://flextools.cc/release-notes/
                            How to update => https://flextools.cc/learn/updates/
                            • halroachH
                              halroach
                              @jkoll66 said:
                              Hello, Component Finder is a great extension. In a future release could you please allow a way to see the file path somewhere?...
                              Done! 😎
                              Check the 2nd and 3rd points before last in the previous post.
                              • pbacotP
                                Does this show components in model or only saved libraries?
                                • halroachH
                                  halroach
                                  Currently only saved libraries. ‘In model’ is on our list...
                                  • halroachH
                                    halroach
                                    Here is a new video explaining ComponentFinder by TutorialsUp:
                                    • halroachH
                                      halroach
                                      Good news!
                                      You can now browse and search through your In-Model Components and Groups with ComponentFinder!
                                      Read more details on the FlexBlog.
                                      https://flextools.cc/wp-content/uploads/2019/01/CF_In-model_01_05-800.gif
                                      • P
                                        pibuz
                                        Hi Halroach! Thank you for your wonderful plugin!!! It's extremely useful!!
                                        I have a small issue though: sometimes the "loading you rlibrary" phase doesn't stop, so basically I can't use the plugin. If I restart the pc, everything works fine.
                                        I'm rurring on a SU2018...
                                        WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                                        • halroachH
                                          halroach
                                          I have a small issue though: sometimes the "loading you library" phase doesn't stop, so basically I can't use the plugin. If I restart the pc, everything works fine.
                                          Hi Pibuz,
                                          Are you able to pinpoint in what situations this happens? Does it happen if specific folders were open in a previous session? Does the loading phase happen in the middle when you're working or only when Sketchup starts?
                                          • P
                                            pibuz
                                            Hi Hal! Thanks for your reply!
                                            I'm actually using the plugin to visualize one single folder (with all its subfolders obviously) and I have about 60 models to report, not so much. I still haven't mapped the cases in which I encounter the issue, but I will in the next days! I'll let you know immediately!
                                            Thank you so much!
                                            • 2 / 2
