    [Plugin] FloorGenerator ( Updated 6-Apr-2017)
    331 Posts 109 Posters 393.0k Views 109 Watching
    • jenujacobJ Offline
      jenujacob
      this saved my backside today! thanks Sdmitch!
      • F Offline
        filipeoconde
        Firstly, thanks a lot sdmitch! Excellent plugin!
        I'd like to suggest a feature - or maybe ask for help if I'm not using it properly!
        When using a material with a bump image (in V-Ray), the FlrGen tends to rotate the texture but not its bump. Is it right? Should I've been doing something different?
        Thanks a lot,
        filipeoconde.
        • jujuJ Offline
          juju
          Thanks a lot,
          filipeoconde.
          I may be wrong, but as far as I know SU only handles a single texture per surface. If you have bump maps linked to a texture, that is normally handled by the rendering software you use, in which case the problem probably isn't with FloorGenerator, or SU for that matter, but rather with your rendering software?
            dimashariyanto
            where i can download this plugin? i have been download from the site http://sdmitch.blogspot.com/ but wan't work.. thanks
            • sdmitchS Offline
              sdmitch
              I have removed the plugin from the blog and plugin store because I have received a complaint regarding Copyright infringement.
              • Q Offline
                qishta
                Thanks a lot sdmitch, the plugin seems to be very powerful!! but how could we get it.
                • utilerU Offline
                  utiler
                  Really, copyright infringement??? I don't know of any other plugin that does this, Sam... that's disappointing that you have to do this.
                  Where has the complaint come from??
                  Just Curious...
                  • sdmitchS Offline
                    sdmitch
                    Apparently from Trimble and I still have no idea why or what the complaint is about.
                      Why not email Chris Fullmer at SketchUp, and ask him to investigate this...
                      Apart from my earlier comments about you not implicitly crediting one of the several authors of the 'copied' VoronoiXY code, I can see no reason to consider any Β© infringement...
                      • W Offline
                        Wolfarelli
                        While this gets sorted out, would someone upload the last version somewhere, please?
                          jenujacob
                          what bollocks!!!!!
                          copyright infringement - bah humbug!
                          nothing that a conversation over a cold beer couldnt solve i am sure!!!!
                            cariothida
                            Sad, wanted to download it. If someone have an RBZ file please email me at cariothida @ gmail . com
                              kendyfox
                              Please am new here, how can I get this floor plugin? Please help
                                kendyfox
                                I wanted to download it but to no avail. If someone have an RBZ file please email me at kendyfox @ gmail . com
                                  Liewe
                                  How sad that this plugin can no longer be downloaded. 😞 😞
                                  Does anyone have an alternative plugin that can do the same thing?
                                  Or can I find the floorgenerator in another way?
                                  • jujuJ Offline
                                    juju
                                    Something similar, but different in a number of ways at the same time:
                                    OOB LAYOUTS
                                    The unfortunate thing is sdmitch has always been helpful with plugins / extensions, this incident has triggered something and the subsequent cause (I believe) of him "hanging up his coding gloves".
                                      Liewe
                                      Thanks a lot for the tip of OOB Layouts. It seems a good solution for what I need.
                                      Is it possible to 3D print the house, when this plugin was used?
                                      • jujuJ Offline
                                        juju
                                        πŸ‘ I have no experience with 3D printing, so unfortunately cannot help / comment in this regard.
                                          dbalex
                                          Can someone send me the plugin?
                                          http://www.bocostudio.com
                                            adi196
                                            acnpolska@gmail.com
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 15 / 17
