    [Plugin] FloorGenerator ( Updated 6-Apr-2017)
    331 Posts 109 Posters 411.5k Views 109 Watching
    • sdmitchS Offline
      sdmitch
      @traxxx said:
      At least I tried ! πŸ˜„ And what about the gaps ? Can I avoid them to happen on the planks smallest sides ? Like continuous planks from floor to roof ? Or does it have to be necessarily linked to the longest sides gaps value ?
      Yes, the gap is the same on all sides.
      http://sdmitch.blogspot.com/
        awei711
        it's good, thanks!
          Kuzmic
          The Rand Tex Material Picker isn't letting me select materials from a folder or the model.
          • sdmitchS Offline
            sdmitch
            Operator error obviously.
              CreaVivaCity
              Why, I can't load plugin in SU 2018 (Unrestricted)
              Can Anyone help me?
              • jenujacobJ Offline
                jenujacob
                this saved my backside today! thanks Sdmitch!
                • F Offline
                  filipeoconde
                  Firstly, thanks a lot sdmitch! Excellent plugin!
                  I'd like to suggest a feature - or maybe ask for help if I'm not using it properly!
                  When using a material with a bump image (in V-Ray), the FlrGen tends to rotate the texture but not its bump. Is it right? Should I've been doing something different?
                  Thanks a lot,
                  filipeoconde.
                  • jujuJ Offline
                    juju
                    Thanks a lot,
                    filipeoconde.
                    I may be wrong, but as far as I know SU only handles a single texture per surface. If you have bump maps linked to a texture, that is normally handled by the rendering software you use, in which case the problem probably isn't with FloorGenerator, or SU for that matter, but rather with your rendering software?
                      dimashariyanto
                      where i can download this plugin? i have been download from the site http://sdmitch.blogspot.com/ but wan't work.. thanks
                      • sdmitchS Offline
                        sdmitch
                        I have removed the plugin from the blog and plugin store because I have received a complaint regarding Copyright infringement.
                        • Q Offline
                          qishta
                          Thanks a lot sdmitch, the plugin seems to be very powerful!! but how could we get it.
                          • utilerU Offline
                            utiler
                            Really, copyright infringement??? I don't know of any other plugin that does this, Sam... that's disappointing that you have to do this.
                            Where has the complaint come from??
                            Just Curious...
                            • sdmitchS Offline
                              sdmitch
                              Apparently from Trimble and I still have no idea why or what the complaint is about.
                                Why not email Chris Fullmer at SketchUp, and ask him to investigate this...
                                Apart from my earlier comments about you not implicitly crediting one of the several authors of the 'copied' VoronoiXY code, I can see no reason to consider any Β© infringement...
                                • W Offline
                                  Wolfarelli
                                  While this gets sorted out, would someone upload the last version somewhere, please?
                                    jenujacob
                                    what bollocks!!!!!
                                    copyright infringement - bah humbug!
                                    nothing that a conversation over a cold beer couldnt solve i am sure!!!!
                                      cariothida
                                      Sad, wanted to download it. If someone have an RBZ file please email me at cariothida @ gmail . com
                                        kendyfox
                                        Please am new here, how can I get this floor plugin? Please help
                                          kendyfox
                                          I wanted to download it but to no avail. If someone have an RBZ file please email me at kendyfox @ gmail . com
                                            Liewe
                                            How sad that this plugin can no longer be downloaded. 😞 😞
                                            Does anyone have an alternative plugin that can do the same thing?
                                            Or can I find the floorgenerator in another way?
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 15 / 17
