    [Plugin] FloorGenerator ( Updated 6-Apr-2017)
    331 Posts 109 Posters 424.6k Views 109 Watching
      awei711
      it's good, thanks!
        Kuzmic
        The Rand Tex Material Picker isn't letting me select materials from a folder or the model.
        • sdmitchS Offline
          sdmitch
          Operator error obviously.
          http://sdmitch.blogspot.com/
            CreaVivaCity
            Why, I can't load plugin in SU 2018 (Unrestricted)
            Can Anyone help me?
            • jenujacobJ Offline
              jenujacob
              this saved my backside today! thanks Sdmitch!
              • F Offline
                filipeoconde
                Firstly, thanks a lot sdmitch! Excellent plugin!
                I'd like to suggest a feature - or maybe ask for help if I'm not using it properly!
                When using a material with a bump image (in V-Ray), the FlrGen tends to rotate the texture but not its bump. Is it right? Should I've been doing something different?
                Thanks a lot,
                filipeoconde.
                • jujuJ Offline
                  juju
                  Thanks a lot,
                  filipeoconde.
                  I may be wrong, but as far as I know SU only handles a single texture per surface. If you have bump maps linked to a texture, that is normally handled by the rendering software you use, in which case the problem probably isn't with FloorGenerator, or SU for that matter, but rather with your rendering software?
                    dimashariyanto
                    where i can download this plugin? i have been download from the site http://sdmitch.blogspot.com/ but wan't work.. thanks
                    • sdmitchS Offline
                      sdmitch
                      I have removed the plugin from the blog and plugin store because I have received a complaint regarding Copyright infringement.
                      • Q Offline
                        qishta
                        Thanks a lot sdmitch, the plugin seems to be very powerful!! but how could we get it.
                        • utilerU Offline
                          utiler
                          Really, copyright infringement??? I don't know of any other plugin that does this, Sam... that's disappointing that you have to do this.
                          Where has the complaint come from??
                          Just Curious...
                          • sdmitchS Offline
                            sdmitch
                            Apparently from Trimble and I still have no idea why or what the complaint is about.
                              Why not email Chris Fullmer at SketchUp, and ask him to investigate this...
                              Apart from my earlier comments about you not implicitly crediting one of the several authors of the 'copied' VoronoiXY code, I can see no reason to consider any Β© infringement...
                              • W Offline
                                Wolfarelli
                                While this gets sorted out, would someone upload the last version somewhere, please?
                                  jenujacob
                                  what bollocks!!!!!
                                  copyright infringement - bah humbug!
                                  nothing that a conversation over a cold beer couldnt solve i am sure!!!!
                                    cariothida
                                    Sad, wanted to download it. If someone have an RBZ file please email me at cariothida @ gmail . com
                                      kendyfox
                                      Please am new here, how can I get this floor plugin? Please help
                                        kendyfox
                                        I wanted to download it but to no avail. If someone have an RBZ file please email me at kendyfox @ gmail . com
                                          Liewe
                                          How sad that this plugin can no longer be downloaded. 😞 😞
                                          Does anyone have an alternative plugin that can do the same thing?
                                          Or can I find the floorgenerator in another way?
                                          • jujuJ Offline
                                            juju
                                            Something similar, but different in a number of ways at the same time:
                                            OOB LAYOUTS
                                            The unfortunate thing is sdmitch has always been helpful with plugins / extensions, this incident has triggered something and the subsequent cause (I believe) of him "hanging up his coding gloves".
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 15 / 17
