    [Plugin] FloorGenerator ( Updated 6-Apr-2017)
    331 Posts 109 Posters 461.3k Views 109 Watching
    • sdmitchS
      sdmitch
      @kuzmic said:
      The Rand Tex Material Picker isn't letting me select materials from a folder or the model.
      Operator error obviously.
      http://sdmitch.blogspot.com/
      • C
        CreaVivaCity
        Why, I can't load plugin in SU 2018 (Unrestricted)
        Can Anyone help me?
        • jenujacobJ
          jenujacob
          this saved my backside today! thanks Sdmitch!
          • F
            filipeoconde
            Firstly, thanks a lot sdmitch! Excellent plugin!
            I'd like to suggest a feature - or maybe ask for help if I'm not using it properly!
            When using a material with a bump image (in V-Ray), the FlrGen tends to rotate the texture but not its bump. Is it right? Should I've been doing something different?
            Thanks a lot,
            filipeoconde.
            • jujuJ
              juju
              Thanks a lot,
              filipeoconde.
              I may be wrong, but as far as I know SU only handles a single texture per surface. If you have bump maps linked to a texture, that is normally handled by the rendering software you use, in which case the problem probably isn't with FloorGenerator, or SU for that matter, but rather with your rendering software?
                dimashariyanto
                where i can download this plugin? i have been download from the site http://sdmitch.blogspot.com/ but wan't work.. thanks
                • sdmitchS
                  sdmitch
                  I have removed the plugin from the blog and plugin store because I have received a complaint regarding Copyright infringement.
                  • Q
                    qishta
                    Thanks a lot sdmitch, the plugin seems to be very powerful!! but how could we get it.
                    • utilerU
                      utiler
                      Really, copyright infringement??? I don't know of any other plugin that does this, Sam... that's disappointing that you have to do this.
                      Where has the complaint come from??
                      Just Curious...
                      • sdmitchS
                        sdmitch
                        Apparently from Trimble and I still have no idea why or what the complaint is about.
                          Why not email Chris Fullmer at SketchUp, and ask him to investigate this...
                          Apart from my earlier comments about you not implicitly crediting one of the several authors of the 'copied' VoronoiXY code, I can see no reason to consider any Β© infringement...
                          • W
                            Wolfarelli
                            While this gets sorted out, would someone upload the last version somewhere, please?
                            • jenujacobJ
                              jenujacob
                              what bollocks!!!!!
                              copyright infringement - bah humbug!
                              nothing that a conversation over a cold beer couldnt solve i am sure!!!!
                              • C
                                cariothida
                                Sad, wanted to download it. If someone have an RBZ file please email me at cariothida @ gmail . com
                                • K
                                  kendyfox
                                  Please am new here, how can I get this floor plugin? Please help
                                  • K
                                    kendyfox
                                    I wanted to download it but to no avail. If someone have an RBZ file please email me at kendyfox @ gmail . com
                                    • L
                                      Liewe
                                      How sad that this plugin can no longer be downloaded. 😞 😞
                                      Does anyone have an alternative plugin that can do the same thing?
                                      Or can I find the floorgenerator in another way?
                                      • jujuJ
                                        juju
                                        Something similar, but different in a number of ways at the same time:
                                        OOB LAYOUTS
                                        The unfortunate thing is sdmitch has always been helpful with plugins / extensions, this incident has triggered something and the subsequent cause (I believe) of him "hanging up his coding gloves".
                                        • L
                                          Liewe
                                          Thanks a lot for the tip of OOB Layouts. It seems a good solution for what I need.
                                          Is it possible to 3D print the house, when this plugin was used?
                                          • jujuJ
                                            juju
                                            πŸ‘ I have no experience with 3D printing, so unfortunately cannot help / comment in this regard.
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 15 / 17
