    [Plugin] LSS Matrix
    69 Posts 25 Posters 74.1k Views 25 Watching
      Courage! πŸ˜„
      • guanjinG
        guanjin
        @kirill2008 said:
        Here is a demonstration of new LSS Matrix feature 'Scan for changes inside groups'.
        [flash=640,360:7zkd1r1a]http://www.youtube.com/v/lfbb8gyH7BA?version=3&hl=ru_RU[/flash:7zkd1r1a]
        It has a lot of limitations and it is unstable and is able to process only simple geometry for now... Anyway I decided to share this stage: http://dl.dropbox.com/u/44695539/lss_matrix/lss_matrix_1_1_alpha.zip
        I am unable to download this file
        • U
          unclex
          can not work with SketchyPhysics3
          could u fix it?
          • plot-parisP
            plot-paris
            Hi Kirill,
            absolutely magnificent plugin!
            Are you still working on it? It is already tremendously powerful. But there are still so many cool possibilities πŸ˜‰
            Like the smooth transition you already mentioned (in addition to the linear one as is the case today).
            Or another one: right now if I understand it correctly, you can define up to three axes for the array (does make sense in a 3D-environment πŸ˜„ ).
            However, I would very much like to see what one could to with several "key-frame"-groups along one axis (see image below). That would add a great deal of control to the tool (and unquestionably a great deal of work for you... a challenge!)
            Anyway: Thank you very much for this great plugin. Its a lot of fun to play with!!!
              Seems you can make that in 2 pass no ?
              Green Yellow
              then
              Yellow red
              • plot-parisP
                plot-paris
                Yes indeed you can. In fact, thats how I did this mock-up. But imagine you just needed two clicks... πŸ˜„
                And if you have two or more different key-frame groups in more than one direction... then it gets really tricky...
                  Yes but so there is no limit !
                  Why not 10 or 100 inbetweeners modules !:)
                  • N
                    niko_monkey
                    Hi everyone,
                    I just download LSS Matrix. Im using a Sketchup 2017 and it just does not work. It doesnt let me set up any copy or original...
                    Any help??
                    • ArcA
                      Arc
                      This plugin was dead.
                      • ArcA
                        Arc
                        • jujuJ
                          juju
                          @niko_monkey said:
                          Hi everyone,
                          Any help??
                          If you consider the last active post, before the quoted above, is from 2013 and take a look on Extension Warehouse the last release of LSS Matrix was 20 May 2013 and only listed as compatible with SU version 2013 last.
                          My guess is if you're using anything newer than SU2013 you shouldn't expect this to work at this time.
                          • C
                            crayonal
                            Why, this plugin was really great, and your work there helped many people...
                            • K
                              kidus firew
                              hey whats up am new here and my lss matrix isnt working properly after i group the first model and copied it when i try to select after i click the initial pick button it wont select it whats the problem plz help me thank you
                                Jade272
                                daer all
                                any idea why I can't pick the the initial instance , and when the matrix Dialogue the green tick never exit
                                [img]file:///C:/Users/jade/Desktop/Capture.JPG[/img]
                                  @jade272 said:
                                  any idea why I can't pick the the initial instance...
                                  Your profile says you are using SketchUp 2017. Read the first paragraph of the original post.
                                  @kirill2008 said:
                                  Small Announcement (29-Jan-2017)
                                  Note that currently there are no plans to continue development of LSS Matrix extension so it is highly recommended look for some other alternatives, which have a similar functionality and compatible with recent versions of SketchUp.
                                  This extension hasn't been updated since 2013 so it shouldn't be surprising that it doesn't work in SU2017.
                                  By the way, in order for your image to show you need to upload it. It doesn't work to link to a file on your computer.
                                    Jade272
                                    ANYONE CAN HELP, THIS PUGIN SOUND GREAT BUT CAN'T PICK THE INITIAL INSTANCE, THERE ARE NO GREEN BOXES OR GREEN TICK AS THE DEMO SHOW? CAN PICK THE I ANY OBJECT.
                                      As the author wrote in his first post, and I repeated in my previous reply to you, this extension is not updated to work in later versions of SketchUp. As the author said, you should find another extension.
                                      • pyrolunaP
                                        pyroluna
                                        is there any up-to-date plugin that has similar functionality to this one?
                                          Take a look to TGI3D Amorph (free) or use an old version of Sketchup! πŸ˜‰
                                          • 3 / 4
