    [Plugin] LSS Matrix
    69 Posts 25 Posters 70.0k Views 25 Watching
    • N Offline
      niko_monkey
      Hi everyone,
      I just download LSS Matrix. Im using a Sketchup 2017 and it just does not work. It doesnt let me set up any copy or original...
      Any help??
      • ArcA Offline
        Arc
        This plugin was dead.
        • ArcA Offline
          Arc
          • jujuJ Offline
            juju
            @niko_monkey said:
            Hi everyone,
            Any help??
            If you consider the last active post, before the quoted above, is from 2013 and take a look on Extension Warehouse the last release of LSS Matrix was 20 May 2013 and only listed as compatible with SU version 2013 last.
            My guess is if you're using anything newer than SU2013 you shouldn't expect this to work at this time.
              crayonal
              Why, this plugin was really great, and your work there helped many people...
                kidus firew
                hey whats up am new here and my lss matrix isnt working properly after i group the first model and copied it when i try to select after i click the initial pick button it wont select it whats the problem plz help me thank you
                  Jade272
                  daer all
                  any idea why I can't pick the the initial instance , and when the matrix Dialogue the green tick never exit
                  [img]file:///C:/Users/jade/Desktop/Capture.JPG[/img]
                    @jade272 said:
                    any idea why I can't pick the the initial instance...
                    Your profile says you are using SketchUp 2017. Read the first paragraph of the original post.
                    @kirill2008 said:
                    Small Announcement (29-Jan-2017)
                    Note that currently there are no plans to continue development of LSS Matrix extension so it is highly recommended look for some other alternatives, which have a similar functionality and compatible with recent versions of SketchUp.
                    This extension hasn't been updated since 2013 so it shouldn't be surprising that it doesn't work in SU2017.
                    By the way, in order for your image to show you need to upload it. It doesn't work to link to a file on your computer.
                      Jade272
                      ANYONE CAN HELP, THIS PUGIN SOUND GREAT BUT CAN'T PICK THE INITIAL INSTANCE, THERE ARE NO GREEN BOXES OR GREEN TICK AS THE DEMO SHOW? CAN PICK THE I ANY OBJECT.
                        As the author wrote in his first post, and I repeated in my previous reply to you, this extension is not updated to work in later versions of SketchUp. As the author said, you should find another extension.
                        • pyrolunaP Offline
                          pyroluna
                          is there any up-to-date plugin that has similar functionality to this one?
                            Take a look to TGI3D Amorph (free) or use an old version of Sketchup! πŸ˜‰
                            • 4 / 4
