    [Plugin] LSS Matrix
    69 Posts 25 Posters 69.1k Views 25 Watching
      Very cool new functions "Scale"! πŸ‘
      (you have written "Scan" πŸ˜‰
      Seems you win your personal challenge! 😎
        Ah tricky "Scan"! β˜€
          kirill2008
          Not yet... The current version has a lot of limitations and very unstable. It's not able to process complex geometry and even sequence of user actions matters (it is necessary to make goup, group copy, then launch 'LSS Matrix' dialog, then edit group and group copy contens, then refresh results). It is necessary to stick to such sequence, because 'LSS Matrix' numerates faces and edges inside initial and copy group after 'Apply' click to be able to track geometry changes properly later during refreshing.
          Also it is necessary to edit group contents very carefully: if any face will be broken as a result of editing, then 'Scan' will fail to analyse such changes (entities count has to be equal in initial and copy groups).
          So it is far from finish πŸ˜„
            Courage! πŸ˜„
            • guanjinG Offline
              guanjin
              @kirill2008 said:
              Here is a demonstration of new LSS Matrix feature 'Scan for changes inside groups'.
              [flash=640,360:7zkd1r1a]http://www.youtube.com/v/lfbb8gyH7BA?version=3&hl=ru_RU[/flash:7zkd1r1a]
              It has a lot of limitations and it is unstable and is able to process only simple geometry for now... Anyway I decided to share this stage: http://dl.dropbox.com/u/44695539/lss_matrix/lss_matrix_1_1_alpha.zip
              I am unable to download this file
              • U Offline
                unclex
                can not work with SketchyPhysics3
                could u fix it?
                • plot-parisP Offline
                  plot-paris
                  Hi Kirill,
                  absolutely magnificent plugin!
                  Are you still working on it? It is already tremendously powerful. But there are still so many cool possibilities πŸ˜‰
                  Like the smooth transition you already mentioned (in addition to the linear one as is the case today).
                  Or another one: right now if I understand it correctly, you can define up to three axes for the array (does make sense in a 3D-environment πŸ˜„ ).
                  However, I would very much like to see what one could to with several "key-frame"-groups along one axis (see image below). That would add a great deal of control to the tool (and unquestionably a great deal of work for you... a challenge!)
                  Anyway: Thank you very much for this great plugin. Its a lot of fun to play with!!!
                    Seems you can make that in 2 pass no ?
                    Green Yellow
                    then
                    Yellow red
                      plot-paris
                      Yes indeed you can. In fact, thats how I did this mock-up. But imagine you just needed two clicks... πŸ˜„
                      And if you have two or more different key-frame groups in more than one direction... then it gets really tricky...
                        Yes but so there is no limit !
                        Why not 10 or 100 inbetweeners modules !:)
                        • N Offline
                          niko_monkey
                          Hi everyone,
                          I just download LSS Matrix. Im using a Sketchup 2017 and it just does not work. It doesnt let me set up any copy or original...
                          Any help??
                          • ArcA Offline
                            Arc
                            This plugin was dead.
                            • ArcA Offline
                              Arc
                              • jujuJ Offline
                                juju
                                @niko_monkey said:
                                Hi everyone,
                                Any help??
                                If you consider the last active post, before the quoted above, is from 2013 and take a look on Extension Warehouse the last release of LSS Matrix was 20 May 2013 and only listed as compatible with SU version 2013 last.
                                My guess is if you're using anything newer than SU2013 you shouldn't expect this to work at this time.
                                  crayonal
                                  Why, this plugin was really great, and your work there helped many people...
                                    kidus firew
                                    hey whats up am new here and my lss matrix isnt working properly after i group the first model and copied it when i try to select after i click the initial pick button it wont select it whats the problem plz help me thank you
                                      Jade272
                                      daer all
                                      any idea why I can't pick the the initial instance , and when the matrix Dialogue the green tick never exit
                                      [img]file:///C:/Users/jade/Desktop/Capture.JPG[/img]
                                        @jade272 said:
                                        any idea why I can't pick the the initial instance...
                                        Your profile says you are using SketchUp 2017. Read the first paragraph of the original post.
                                        @kirill2008 said:
                                        Small Announcement (29-Jan-2017)
                                        Note that currently there are no plans to continue development of LSS Matrix extension so it is highly recommended look for some other alternatives, which have a similar functionality and compatible with recent versions of SketchUp.
                                        This extension hasn't been updated since 2013 so it shouldn't be surprising that it doesn't work in SU2017.
                                        By the way, in order for your image to show you need to upload it. It doesn't work to link to a file on your computer.
                                          Jade272
                                          ANYONE CAN HELP, THIS PUGIN SOUND GREAT BUT CAN'T PICK THE INITIAL INSTANCE, THERE ARE NO GREEN BOXES OR GREEN TICK AS THE DEMO SHOW? CAN PICK THE I ANY OBJECT.
                                            As the author wrote in his first post, and I repeated in my previous reply to you, this extension is not updated to work in later versions of SketchUp. As the author said, you should find another extension.
                                            • 3 / 4
