    Girls Best Friend - New Images
    13 Posts 9 Posters 4.1k Views 9 Watching
      Great, Agreed on the glass tube rather than the brass one.
      • kimi kimiK
        kimi kimi
        Looks too artificial too me, but I can't tell exactly what's the reason. Maybe try to move that black away from absolute black, I think that's messing up the light. Also, some depth of field effect might be nice, since it's a small object. If you're really into experimenting, try some bump and dirt maps for the bottle and ground.
        • tuna1957T
          tuna1957
          Really appreciate the comments and critiques. In that spirit posting two new images. Made some very minor adjustments to the bump maps of some of the textures. Biggest change was adding a noise map for the glass tube, strength of that map set very low. First image has the same hdri setup as the originals. Second image I rotated the hdri around 160 degrees . If any ones interested the hdri is out of the sketchUcation studio pack #001. It's a multi light setup. Experiments showed the diamonds render best under multiple lights. Forgot to mention all renders done in Twilight. Original images post pro in Gimp. Second set of images very minor post pro in Affinity ( just downloaded it last night ). Second set of images any better...... darned if I know.
            Much clearer images, brilliant.
            • tuna1957T
              tuna1957
              Thanks Mike.
              • Bryan KB
                Well done!
                • tuna1957T
                  tuna1957
                  Thanks Bryan.
                  • G
                    garystan
                    tuna1957 :
                    I like the way the diamonds are rendered. garystan
                    • duanekempD
                      duanekemp
                      Very nice to see. And the second set of images really are good. Bravo.
                      Duane Kemp
                      Kemp Productions
                      Puidoux, Switzerland
                      Gallery:
                      https://duanekemp.artstation.com/
                      • marked001M
                        marked001
                        πŸ‘ πŸ‘ πŸ‘
                        http://www.revision21vis.com
                        instagram: revi21on
                        • Bob JamesB
                          Bob James
                          The final one is "picture perfect" πŸ‘
