    Girls Best Friend - New Images
    13 Posts 9 Posters 3.5k Views 9 Watching
    • tuna1957T Online
      tuna1957
      Well you know what they say....... Have played about with this off and on for awhile now. Think I finally got something decent. Remodeled the diamonds a couple of times. Finally found a drawing of how diamonds are actually faceted and tried to get the model as close to that as I could. Lit the render with a "studio" hdri. It took some messing about to not get weird reflections. Wasn't real sure what to expect. Think I like the "glass" tube a little better than the "brass" one. Enjoy. πŸ‘
      • HornOxxH Offline
        HornOxx
        "...Enjoy" - yes I do, very much πŸ‘ πŸ˜„
        the little stones sparkle and reflect like real ones - and the detailing of the black cap is well done also! An impressive work & thanks for sharing
        never trust a skinny cook
          Great, Agreed on the glass tube rather than the brass one.
          • kimi kimiK Offline
            kimi kimi
            Looks too artificial too me, but I can't tell exactly what's the reason. Maybe try to move that black away from absolute black, I think that's messing up the light. Also, some depth of field effect might be nice, since it's a small object. If you're really into experimenting, try some bump and dirt maps for the bottle and ground.
            • tuna1957T Online
              tuna1957
              Really appreciate the comments and critiques. In that spirit posting two new images. Made some very minor adjustments to the bump maps of some of the textures. Biggest change was adding a noise map for the glass tube, strength of that map set very low. First image has the same hdri setup as the originals. Second image I rotated the hdri around 160 degrees . If any ones interested the hdri is out of the sketchUcation studio pack #001. It's a multi light setup. Experiments showed the diamonds render best under multiple lights. Forgot to mention all renders done in Twilight. Original images post pro in Gimp. Second set of images very minor post pro in Affinity ( just downloaded it last night ). Second set of images any better...... darned if I know.
                Much clearer images, brilliant.
                • tuna1957T Online
                  tuna1957
                  Thanks Mike.
                  • Bryan KB Offline
                    Well done!
                    • tuna1957T Online
                      tuna1957
                      Thanks Bryan.
                        garystan
                        tuna1957 :
                        I like the way the diamonds are rendered. garystan
                        • duanekempD Offline
                          duanekemp
                          Very nice to see. And the second set of images really are good. Bravo.
                          Duane Kemp
                          Kemp Productions
                          Puidoux, Switzerland
                          Gallery:
                          https://duanekemp.artstation.com/
                          • marked001M Offline
                            marked001
                            πŸ‘ πŸ‘ πŸ‘
                            http://www.revision21vis.com
                            instagram: revi21on
                            • Bob JamesB Offline
                              Bob James
                              The final one is "picture perfect" πŸ‘
